Old 03-06-2018, 05:17 PM
BIGX's Avatar
BIGX BIGX is offline
Toxic Customs
Default Carillo pistons and rods?
Anyone on here running the Carillo hybrid piston and rod combo?
Old 03-12-2018, 07:43 AM
Bdsankey Bdsankey is offline
Mine is sitting at the machine shop, just waiting for the coated bearings to come in then I can go pick the pieces up to assemble.
I don't know of many people running this hybrid setup.
Current Rides:
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18) - Old 475/87/1.00 setup
-Built Motor, Forced Inductions Billet ETR 480/96/1.10 T6, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend J Converter, Billet Trans, Fuelab Supply Pump/Reg, RCD Sump, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
-Bosch Reman Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, Beans Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
Old 04-10-2018, 06:32 AM
Originally Posted by Max3r View Post
I agree. not many people run with that setup
Hoping to pick it up this week. Had some issues where the bearing coater apparently ruined the bearings (mains/rod/cam/thrust) and I just found out a little over a week ago.
Machine shop ordered Mahle/Clevite performance bearings for everything and are just waiting on the mains to arrive to final polish the crank for 20W50.
They said it was the best balancing duramax rotating assembly they've done.
Hoping this helps my stock crank live.
Current Rides:
Old 05-29-2018, 09:03 PM
BIGX's Avatar
Toxic Customs
what piston to cylinder wall clearance spec are you using?
Old 05-30-2018, 06:41 AM
CP-Carrillo recommended 0.008" piston-to-wall clearance. I had my machinist follow the CP-Carrillo specs on everything.
I got it running and I must say the responsiveness of this engine is insane.
Current Rides:
Old 05-30-2018, 06:30 PM
Robby Avery's Avatar
Robby Avery Robby Avery is offline
GM TECH @ FENDER GMC
Subd what material are the pistons? Standard Carrillo rods I presume?
2006 Chevy 2500HD LBZ Duramax Summit White CCSB Tan (neutral) leather LT3 pkg w/sunroof OEM bra 4x4, ISSPRO EV, ATS Twin CP3's, Built Allison, Eaton E-locker front stock G80 rear, Kennedy Twin pump filter combo kit, Snow Perf Stage 2 w/m injection, 4in to 5in banks tip, HM Big K&N, Mickey Thompson Baja Claw TTC 315/75/16 on stock rims, Rancho RS9000XL, Fabtech HD TR, Cognito P&I Brace kit, DD/Puller/Work Truck
2002 Chevy 2500HD LB7 Duramax Summit White CCSB Grey (neutral) leather LT3 pkg OEM bra 4x4, Kennedy Twin Pump Filter Combo Kit, ISSPRO EV, PPE Boost Valve, DTS Built Allison, MikeL Cooler, ATS Billet Flexplate, DTS 3in DS IC pipe, Bill's 5in CAI (White), Big K&N, 4in to 7in black stack, Mickey Thompson Baja Claw TTC 315/75/16 on stock rims, Cognito P&I Brace kit, Sleeves, Energy Sway bar Kit, DD/Puller/Work truck
Special Thanks: (David) DTS, (Guy) Socal Diesel, (Nick & crew) DuramaxTuner, (Dan) PPE, (John) Kennedy Diesel, (Tony) All Season
Old 05-31-2018, 06:29 AM
The hybrid assembly uses a forged piston with a smaller wrist pin moved up on the piston to decrease overall piston height. This smaller wrist pin and new location also allow for a longer rod. A longer rod, in theory, should help the motor build torque by keeping the piston in the high-pressure zone of the cylinder longer as well as decreasing side load on the crank by generating a better rod to stroke ratio.
It really should shine at higher rpm.
Also, with this wrist pin and piston, they were able to shave 1/2# per cylinder off of the rotating assembly for a massive 4# weight savings overall (they save 12# on the Cummins!!) which is why I believe my motor is so responsive.
Below are the links to the CP-Carrillo announcement/catalog:
Link 1: http://www.cp-carrillo.com/n-12064-h...ow-availa.html
Link 2: http://www.cp-carrillo.com/files/die...nalv3email.pdf
Current Rides:
