Old 03-20-2020, 04:42 PM
jedenbeck's Avatar
jedenbeck jedenbeck is offline
FNG
Default Slicks air pressure
Just bought a set of 30x14 cheaters on 16x10s with tubes in them. Whatís everyone running for air in them? Iíve never ran a slick so Iím starting with no knowledge of them pretty much.
Thanks
2006 LBZ Ccsb stock motor, limitless built trans suncoast 1055, FI 467.7/83/.90, 60% injectors, 10mm pump
Old 03-20-2020, 05:25 PM
SickLL7Crenshaw's Avatar
SickLL7Crenshaw SickLL7Crenshaw is offline
Billy The Kid
I’ve always had great luck with these numbers.
For 6700-7k lbs 28F/22R for 6400-6700lbs 24F/18R. Will have to check/adjust after each pass.
Blake
2001 LB7 312k miles
[email protected] Stock Motor
8LB7s, 7LLYs, 1LBZ , 2LMMs, 2L5Ps
Old 03-20-2020, 05:55 PM
jedenbeck's Avatar
FNG
Originally Posted by SickLL7Crenshaw View Post
Iíve always had great luck with these numbers.
Thanks for the tips. Iíll check them after each pass. Whatís the reasoning for that? They fluctuate a lot? Just curious
Old 03-20-2020, 08:57 PM
Billy The Kid
Tire psi will rise after a pass due to heat, depending how long you wait until you’re next pass pressures can vary. I always check just because I’m OCD about little things like that. Direct sunlight hitting them will cause a psi jump as well.
Blake
2001 LB7 312k miles
Old 03-21-2020, 05:24 AM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
A lot will depend on your race weight. I run mine at 22 in the front and 18 in the back. But I'm not running tubes. With them you can run a hair less then normal. Also power plays a huge roll. I would not run them as low if they are working the same with higher psi.
2013 ccsb Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples, nitrous
Old 03-21-2020, 04:36 PM
1TRIKHD's Avatar
1TRIKHD 1TRIKHD is offline
Country boy Limo.
Can't remember what i ran last year on the 30x14 M&H cheaters but I was a little under 6700lbs so I will try out the 24F/18R this year and go from there.
2006 CCLB LT3 Victory Red
SDP Built Trans w/ Goerend Y billet stator
S472sx-e .87/1.0ar w/ SDP Piping
Wagler street intake
Calvert Racing bars
ADII 165
Full Kryptonite Front end
PPE manifolds up pipes
Special Thanks to:[email protected]
Tuned by:Blake
Best time to date: 11.96 @ 112.50mph
Best 60ft: 1.66
Old 03-25-2020, 06:23 PM
coker6365's Avatar
coker6365 coker6365 is offline
Coker6303's ***** Daddy
22-24 front and 18-20 rear have done well for me a 6400lbs.
Sent from my SM-G965U1 using Tapatalk
2015 Denali CC/SB LML
2006 RC/LB LBZ, SXE472/87/1.0 & FI491/100/1.45, 250% F1 Injectors, Dual 10mm CP3, SoCal Built Engine, JoshH Built Trans, JoshH Tuning. 10.18 @ 140mph, 1487HP 2885TQ Corrected ATS Dyno. 2019 Diesel Power Challenge 1st Place
Big thanks to Josh Harris, Josh Chambers, and my brother Russell Coker for all the help with the LBZ.
