Old 11-15-2018, 07:54 PM
Duramax racer 8 Duramax racer 8 is offline
Gearhead
Default Lb7 to Lly swap
I did an Lb7 to Lly swap this past summer. Not seeing the high idle option using the steering wheel controls to scroll though the menu display on the cluster. Is it possible? Bcm re flash? Write it into the tune?
Thanks
Old 11-17-2018, 08:52 AM
rfletes79's Avatar
rfletes79 rfletes79 is offline
Your LB7 had a high idle opltion on the steering wheel controls/ cluster as a factory option? I’ve never seen that...... and now that you’ve done the LLY conversion that option is gone?
Did you change the bcm during the swap? Or just the ecm..... how did you do the conversion? What year is your truck?
j
1970 Chevelle Duramax Hot Rod, '04 LB7/TH400-gear vendor, HTT 67.7 FMW, Wagler street intake, 65% S&S sticks, exergy 10 mil pump, SoCal AF3388, Valve springs, Push Rods, LBZ rods, cut LB7 slugs..... 9 sec cruzer :-)
2002 2500HD LLY 6 speed ally conversion
Old 11-17-2018, 12:33 PM
THEFERMANATOR's Avatar
LEGALLY INSANE
I believe what he's saying is he did an lly swap, but can't find the high idle option in the dic that most lly's have. If that's the case, it's because you still have a lb7 bcm calubration. You would have to have the bcm flashed to an lly, and I don't know if the cluster would need an update or not to acess it via the dic. Your truck still thinks it's an lb7, lly options don't appear unless the truck is setup to show them.
Old 11-17-2018, 04:51 PM
Gearhead
This is exactly what I mean. I figured it still thinks itís a Lb7 as far as the bcm knows. I will try flashing the bcm and go from there. Thank very much.
Old 11-17-2018, 05:03 PM
Gearhead
Originally Posted by rfletes79 View Post
Your LB7 had a high idle opltion on the steering wheel controls/ cluster as a factory option? Iíve never seen that...... and now that youíve done the LLY conversion that option is gone?
I left the Lb7 bcm. Swapped everything from a donor Lly. The truck converted is 03 Lb7.
