  #736
Old 10-19-2018, 01:06 PM
2004LB7's Avatar
2004LB7 2004LB7 is online now
So who's software/firmware is loaded on the new chip? I suspect it is a bootleg GM L5P. I couldn't imagine that HP tuning built one from scratch and managed to get it to talk with all of the other modules in the truck
2008 Chevrolet 3500HD DRW LTZ
  #737
Old Today, 06:38 AM
Cougar281's Avatar
Cougar281 Cougar281 is offline
It's probably running GM's stock programming. I could be wrong and these processors could be different, but think of your home PC - your OS, apps and files don't live on the CPU - they are on your HDD/SSD. The CPU just processes the data and makes it all work. The older LS1 PCMs stored their programming on a small flash chip that has no processing capabilities. The CPUs on the new ECMs may have flash memory onboard, but in the end, it's a CPU. My guess is they are replacing it because the 'feature' that does the signature verification (which is what if the tuning 'speedbump') is a part of the CPU that can't be 'turned off' (once it's on, it's on, or the CPUs are made either with it or without it), so they're replacing the CPU with one that doesn't have the 'feature' enabled. As for why GM's tools would no longer be able to flash the ECM, my guess is the flash process is looking for that signature verification, and if it doesn't get it because it's not enabled in the CPU, it'll fail.
'04.5 2500HD Silverado LT CC/LB, LBZ D/A Dark Grey
Metallic, 05+ HD Hood & Grille, 192k and counting
Mike L Trans built by ME.
EFILive, PPE Race Valve, KD Twin Lift Pumps & Billet Fuel Pickup, MBRP 4" "Cat-Back" T409 straight piped.
300.59' 3rd place first pull
Best 1/4 times:
Truck: 14.067 @ 96.29, weighing in at over 7200#
446.4RWHP/820.2RWTq
Car (95 Cougar 4.6L V8): 14.680 @ 94.00
"The FIRST weapon is the mind, all others are incidental."
"I'd rather be judged by twelve than carried by six."
  #738
Old Today, 09:14 AM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
I agree with Cougar281. My only thought is the new CPU just has a different key loaded, and verifies a different signature. So HPT puts a new CPU on, and signs the stock program with their key, which the new CPU accepts. That would also explain why it won't accept a reflash from GM, since it no longer honors the GM key.
Currently Active Users Viewing This Thread: 4 (3 members and 1 guests)
boostwhore, DuramaxRamRod, N2BRK
