  #16
Old 09-21-2015, 01:32 PM
ty_LBZ's Avatar
ty_LBZ ty_LBZ is offline
Camaro killa
Default
You can trade me for my stock turbo...it will quiet down
__________________
LBZ CCSB 4x4. deleted. re-routed. shimmed. EFI by Kory 4" MBRP downpipe-back w/Corsa. Alligator trans cooler hoses. 3" Pro-Fab downpipe. Transgo Jr. Banks ram air intake. MA pump rub fix. Rare Parts tie rods. Fumoto Valve. AirDog 150. Nicktane CAT filter adapter. SoCal 3388AF. ProFab charge pipe & Y-bridge. Mahle +0.020 pistons. Keyed cam & crank. ARP head studs, main studs, flywheel. Rotating assembly balanced. Merchant Auto motor mounts.
10/30/14- cracked piston
03/14/15-Back from the dead
  #17
Old 09-22-2015, 04:56 PM
POWER Freak's Avatar
POWER Freak POWER Freak is offline
Gearhead
Default
Quote:
You can have my turbo if you swap our cams
__________________
Early 07 Chevy 4x4
Mahle Race Cast, Carillo Rods, Billet Caps, Girdle, Main/Head Studs, ATP Tuning, Exergy 60%s, Dual CP3s, Danville STG2R, and all of the other standard stuff...
  #18
Old 09-22-2015, 05:29 PM
ty_LBZ's Avatar
Camaro killa
Default
Quote:
Hahaha! How do you like the turbo? I been eyeball'n that same turbo, whenever I get my motor build paid off. Driveability? EGTs? Towing?
__________________
  #19
Old 09-22-2015, 06:25 PM
Gearhead
Default
Drivability truly is just like a stock turbo. As far as EGTs go my 680hp tune will get up to 1500ish. I don't tow anything super heavy, but with the 7000lb trailers that I do pull it does great.
Honestly, the only thing I didn't like was trying to get it tuned. ATP did the tuning and after a couple of different tunes it drives MUCH better. I do believe that Mark has changed the vane plate in the turbos made after 7/1/15 to make them easier to tune. That being said, I would assume that this potential downside doesn't apply anymore.
All in all I feel like I got a lot of bang for my buck and I like how it's a drop in replacement. If you're looking for a 700hp turbo, give or take, I say go for it.
__________________
Early 07 Chevy 4x4
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
