  #16
Old 08-10-2007, 08:37 AM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
Quote:
Originally Posted by WolfLLY View Post
You might be able to work around it.
I did work around it
Quote:
Originally Posted by duratothemax View Post
how do you have the EGR up-pipe manifold blocked off?
Welding/bolting a plate cover on it will not work. It will vibrate and crack the little flex pipe.
mine did pressure test, but i swapped to a LB7
pipe ( freebie )
Quote:
Originally Posted by Turbotug View Post
It might be worth your time to find a stepped hose for the turbo outlet. It's probably at least 1/4" in diameter larger than the stock charger. I had one hell of a time trying to get it one.
THATS GOOD ADVICE!
You'll also run into a lot of "each truck is different" situations.
OH SO TRUE,NO NEED TO EVEN BEND THE FIREWALL AND USED THE STOCK DIPSTICK
The first test drive makes it all worth it though!
The biggest issue i had was the flange for the BD pedastall was a different
thickness IIRC the LLY was 0.700" and the BD was 0.360"
i would take a second before installing the new pedestal to meausure the pedstall flange thickness,I ended up haveing to shorten the bolts because they where bottoming out on the block or i geuss you could stack some washers.
And get a good 12point 12mm socket
also IMO remove the glow plug bracket
__________________
2017 2.5L D-Max Trail Blazer
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
Abby 01 RC/LB 10.28@144mph
SOLD
  #17
Old 08-10-2007, 04:46 PM
That's better
Default
to anyone who installs this turbo
when you are done you will forget the skinned knuckles and sore knees
I love this turbo!
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #18
Old 08-13-2007, 06:25 AM
mplteddy's Avatar
mplteddy mplteddy is offline
Default
It does make for a fun ride Sweet.....
  #19
Old 08-13-2007, 12:12 PM
duramaxin14's Avatar
duramaxin14 duramaxin14 is offline
Just Keeping Up
Default
I would love to put a turbo on my truck after the tranny install but I'm afaird that i can kiss my motor goodbye. So i don't wanna do this until i have the money saved up for my motor. At this rate im going to live with my mom and dad until im 50. But still have a very rank truck
__________________
2016 crew cab f150 4x4 5.0
  #20
Old 08-13-2007, 01:08 PM
That's better
Default
one more thing about the install
i took the 2 suplied pieces of tinfoil heatwrap blanket thingys and wraped it around the turbo, i didnt know if this was a good idea or bad...so i called HTT
they actually said it was a great idea and should help it retain the heat in the turbo
this should also help with the spooling
just thought i would pass this info on
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #21
Old 08-13-2007, 06:17 PM
WolfLLY's Avatar
WolfLLY WolfLLY is offline
Making Chips
Default
Wow nice. Where can I get more of that stuff
__________________
LMM CCSB LTZ Z71. SoCal motor, s485/68r, 1078 Limitless converter, S&S 200s.
LB7 ECSB 4X4
Thanks to Evan@Limitless, Mark@Danville Performance, Josh Harris@Top Notch, and Corbin(crussel)
  #22
Old 08-18-2007, 10:20 AM
That's better
Default
http://www.designengineering.com/products.asp
they have a heat blanket good for 2000f and lots of other goodies
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #23
Old 03-08-2008, 03:49 PM
LarryJewell's Avatar
LarryJewell LarryJewell is offline
Back with his honey :)
Default
This needed to be easy to find.
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #24
Old 01-17-2009, 10:52 AM
paint94979's Avatar
paint94979 paint94979 is offline
Beer Nazi
Default
this is one hell of an install guide helped us with my GT4094 thanks Ben
__________________
LLY's are COOL
HUGE Thanks to Chris, Mike L., McRat Racing, Total Performance Diesel, PPE, Trent, Wicked Diesel, Mike, Henry of Creatures of the Night, Exergy Engineering and the rest of Team Salad<--My Tailgate's Always open for all of you!!
11.84 @ 115
Tailgate Crew Member #2
  #25
Old 01-17-2009, 11:05 AM
SIKDMAX's Avatar
SIKDMAX SIKDMAX is offline
Highway Burnouts!
Default
holy smokes thanks Paint for bumpin! Think I may need this!
__________________
Matt...2008 Chevy DMax CCSB 4x4 LTZ LMM
Carillos, Mahles, ARP 625s, SoCal Cam, Stage 1 Heads, 60% sticks, PPE Dual CP3, HTT 66SS/GT4718R Stainless Steel Twins, PPE High Flow Intake Manifold, Up Pipes and Headers. 6" MBRP single stack. Mike L. Suncoast 4 w/ 1057
  #26
Old 09-07-2009, 06:23 PM
JD Dave's Avatar
JD Dave JD Dave is offline
In way over my head
Default
I agree, nice write up, thought it needed a bump.
__________________
Special thanks to: HSPDiesel.com, Wagler Competition and S&S Diesel.
  #27
Old 09-07-2009, 06:24 PM
paint94979's Avatar
Beer Nazi
Default
Quote:
Ben did a really good job with this DIY...
__________________
LLY's are COOL
11.84 @ 115
  #28
Old 10-02-2009, 10:09 PM
MRJCSTYLE MRJCSTYLE is offline
FNG
Default
I could not get either links to open,
would you mind e-mailing these turbo install instructions to me?
Thank You
  #29
Old 10-03-2009, 08:05 AM
minisub's Avatar
minisub minisub is offline
6-5/6-6;Whatever It Takes
Default
You need to save both files to a local drive and open them from there.
The BD link seems to have changed, try this one:
http://www.dieselperformance.com/pro...max_Turbo1.pdf
__________________
2006 GMC D/A LBZ CC SB;
--- EFI, SC IV/1058, Silverline 4," Diamond Eye downpipe, cat delete, muffler delete
2006 Jeep Liberty CRD, GDE full tq Eco tuning
RIP - 1995 Tahoe - 6.5TD, Kennedy Exhaust, Heath Remote FSD, Kennedy Chip
  #30
Old 12-09-2009, 06:29 PM
05smoker's Avatar
05smoker 05smoker is offline
I'm officially done!
Default
http://www.dieselperformance.com/pro...rmax_Turbo.pdf
Fixed it.
__________________
2005 2500HD CHEVY CCSB, Blackout VVT, FPE SCIV w/ 1057, 3" lowering shackles, overloads removed, Cooper Zeon LTZs on BMF REPRs. SOLD
Thanks to Fleece, Blackout Performance, Genes Machine Shop, Tim, Bullfrog, Simon, Mark Broviak .......
Remote mount turbo, Electric Water Pump, Cheetah turbo - Member #1
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
LLY HTT install Ben46a LLY 8 03-24-2007 07:14 AM
PPE GT42R LLY Turbo Kit is a serious contender! McRat Pacific Performance Engineering (PPE) Fullerton ca. (714) 985-4825 Dan Grant 22 01-16-2007 01:52 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
