Old 09-19-2018, 04:34 AM
Gello's Avatar
Gello Gello is offline
Default Shocks
Hey guys
I know Iím probably beating up old threads. My new 3500 LTZ came with rancho shocks and they ride like a brick!! I think I Made a mistake and put bilstein 4100 series in it. Had them in my 04 and actually loved the ride. The bilsteins do ride better unloaded however with the fifth wheel hooked up and coming to a stop I feel like thereís no shocks in the truck ( bounces bad ) any advice on a good all around shock that wonít loosen my teeth unloaded or should I just throw the ranchos back in for the once a year towing event?
Thanks!
04 LB7, Duramax tuner,Rickson wheels with Goodyear 14ply tires,banks exhaust brake,banks inter cooler,4in Banks with muffler, PPE boost valve, edge CTS for gauges, MBRP down pipe, Banks CAI with super scoop,Fass 150 titanium lift pump, DRP intake horn, driver side exhaust manifold, helwig front and rear sway bars,bilstein shocks,Ppe rear dif cover and transmission pan, centric slotted rotors with act brake pads,stainless brake lines,transfer case brace,kryptonite tie-rods,stock trans and turbo.
Old 09-19-2018, 05:13 AM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Most guys like Rancho 9000. Theyíre adjustable so you can dial them to whatever your needs are
2006 LLY CC/SB LT3 mostly stock maybe for sale?
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s.
2011 Yamaha YFZ450X
2018 GasGas XC300
Old 09-19-2018, 06:34 AM
BoiseRob's Avatar
BoiseRob BoiseRob is offline
I too recently replaced my 10 year old Bilstein HD's with the 5100's. Ride empty is very nice but my wife hates the ride when we're towing our 10k pound TT. On less than perfect roads like we have in our Idaho mountains, the ride is significantly more "bouncy" than the HD's, her words, not mine. Bouncy to the point that she has to hold her "jiggly girl parts" while towing our trailer.
If on the other hand you don't tow, or your significant "other" is an A or B cup, they're an upgrade...
Old 09-19-2018, 07:04 AM
DuramxMan's Avatar
DuramxMan DuramxMan is offline
Gearhead
I also like the Rancho 9000, run on 3 empty and put rears on 9 loaded!
2004 Chevy 2500HD CC 4WD LB7, Studded Heads , DTS 67 mm turbo, 10mm Stroker Pump, 45 over injectors, FASS 150, MBRP 3" Downpipe, 4" MBRP Exhaust, DTS Built Trans, Suncoast 1073 Torque Convertor, Tie Rod Sleeves and Solid Centerlink, QA1 Shocks Best 1/4 mile 11.38 at 118mph 60 ft 1.611
Old 09-19-2018, 08:00 AM
Chevy1925's Avatar
i run rancho 9000's on the rear. around town i run 3 or 4. loaded down i run 6-8 depending on whats in the 5th wheel (determines my pin weight). i run no air bags and it rides nice and smooth.
James
best time to date: 12.39
Tailgate Crew Member #4
Old 09-19-2018, 08:28 AM
coker6365's Avatar
coker6365 coker6365 is offline
Coker6303's ***** Daddy
Rancho 9000 are a great all around shock that gives you some adjustment to fit the bill. Look on the Rancho website and you wait for their buy 3 get 1 free sale.
Sent from my SM-G930V using Tapatalk
2015 Denali CC/SB LML, Farm Truck
2013 EC/SB LML, The Test Rig
2013 RC/LB LML, The Beater
2006 RC/LB LBZ, Tow Mirror Killer. Under the knife again and looking for more horsepuppies.
Big thanks to Josh Harris, Josh Chambers, and my brother Russell Coker for all the help with the LBZ.
Old 09-19-2018, 09:59 AM
Gello's Avatar
Thanks guys !! And boiserob im still lmao on your reply
Old 09-19-2018, 10:34 AM
OregonDMAX's Avatar
NOT IN OREGON
To be clear the ranchos that came on it new are shit because GM orders a specific valving that will never compare to what rancho sells to the aftermarket so the 9000 will absolutely ride better
Sean
02 CCSB
Moonshine tunes, Mike L trans
Mike L secret squirrel converter
supporting mods
  #9
Old 09-19-2018, 10:43 AM
Gello's Avatar
Great thanks
  #10
Old 09-19-2018, 10:52 AM
zakkb787's Avatar
<thatís not me...
Same
Other toys:
2011 Yamaha YFZ450X
2018 GasGas XC300
