Old 12-06-2018, 09:08 PM
The Kansan's Avatar
The Kansan The Kansan is offline
Default LLY Operating System
Is there an lly operating system that is preferred over another currently running 05875871.
-2003 CCSB Silverado-
LB7 Died 6/10/17 3 Bent Rods 1 Cracked Piston
LLY Swapped
LBZ Rods
LB7 Crank & Pistons
Built by me
63mm VGT
Kryptonite
Wagler AF Cam
Built SC Trans 1074
HSP Billet Y Bridge
HSP Intake
HSP Billet Thermastat Housing
Fleece 10mm CP3
Spearco Intercooler
PPE Man & Up Pipes
All Cerakoted by Me
Real Built Motor Coming Soon
Old 12-06-2018, 10:05 PM
The Kansan's Avatar
So i just finished doing an LLY swap and i think im having some issues with what operating system im running. I need an LLY operating system for a crew cab short bed LT with bose and climate control. Any help would be greatly appreciated.
LLY Swapped
LBZ Rods
LB7 Crank & Pistons
Built by me
63mm VGT
Kryptonite
Wagler AF Cam
Built SC Trans 1074
HSP Billet Y Bridge
HSP Intake
Fleece 10mm CP3
Spearco Intercooler
PPE Man & Up Pipes
All Cerakoted by Me
Old 12-06-2018, 10:47 PM
THEFERMANATOR's Avatar
LEGALLY INSANE
04 05, doesn't seem to matter once you tune them. With 03-05 you MUST match up the vehicles options as best as possible right down to power windows, locks, push button or floor shift 4x4, radio, ac, ALL of it. They're VERY picky. I'm on my phone so I can't look rough what I have. I would look on autotrader or ebay and find an lly equipped identical to yours, get the vin, look it up on tis2web, and then find a matching tune to it.
Old 12-07-2018, 10:52 AM
The Kansan's Avatar
OK thanks, i will do that right now.
LLY Swapped
LBZ Rods
LB7 Crank & Pistons
Built by me
63mm VGT
Kryptonite
Wagler AF Cam
Built SC Trans 1074
HSP Billet Y Bridge
HSP Intake
Fleece 10mm CP3
Spearco Intercooler
PPE Man & Up Pipes
All Cerakoted by Me
Old 12-07-2018, 11:29 AM
The Kansan's Avatar
Thefermanator i found my exact truck on autotrader with vin 1GCHK23215F926661 and it looks like the OS it has is 15228758. How does someone get a hold of the right OS and calibration. With the operating system i have now the hvac controls dont work right and a couple other things are acting up.
LLY Swapped
LBZ Rods
LB7 Crank & Pistons
Built by me
63mm VGT
Kryptonite
Wagler AF Cam
Built SC Trans 1074
HSP Billet Y Bridge
HSP Intake
Fleece 10mm CP3
Spearco Intercooler
PPE Man & Up Pipes
All Cerakoted by Me
Old 12-07-2018, 12:03 PM
Bdsankey Bdsankey is offline
You download the file from TIS2Web then modify it in efilive to your VIN etc. You will need a subscription.
Current Rides:
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18)
-Built Motor, Billet S475/87/1.00 T4, Modded Exergy 250% Injectors, Exergy 14mm Street Pump/LBZ CP3, Goerend J Converter, Billet Trans w/DEFEO 6 Pinion Planet, Fuelab Supply Pump/Reg, RCD Sump, Front E-Locker, TrueTrac, Yukon 4340 Rear Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
-Bosch Reman Injectors, FASS 150, 3" Downpipe, 4" Downpipe Back, Beans Sump, PPE Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
Old 12-07-2018, 12:19 PM
juddski88's Avatar
juddski88 juddski88 is offline
Freedom Diesel
I have a stock file from a truck with those same options, I can email it to you. Pm me
2001 Chevy 2500HD ECSB
"Sore Subject" - Still don't have time for it.
I would never have learned what I have without George Alexander, Mike Lovrich, David Browning, Matt Handwork, Ben Tyler, Evan Drosehn and countless members of this forum and others.
Thank you.
2014 Jeep Grand Cherokee Limited, Ecodiesel
