  #1
Old 09-06-2018, 05:44 PM
dirty_max's Avatar
dirty_max dirty_max is offline
Default Building a stock turbo puller, need help/opinions
Alright guys, i am in the process of doing some research on building the engine in my dually for the stock turbo class. I would really like to hear some of your opinions on what you guys would do to make the most power out of a stock charger. I was thinking delipped pistons, stock rods, and a cam of some sorts for the bottom end. But I'm not opposed to upgraded parts in the bottom end. Who all sells rebuild kits? How important is it to have everything balanced and does the machine shop have to have the bottom end together to balance it? Any help is appreciated.
__________________
2004 chevy lly with a handshaker
Originally Posted by coker6303
My trucks not a whore...she doesn't lift her skirt for just anyone!
But she is a prostitute...she will do anything for money
  #2
Old 09-06-2018, 08:48 PM
PureHybrid's Avatar
PureHybrid PureHybrid is offline
Isuzu Shakes IT
Default
A legit stock turbo, or stock appearing? I'd probably buy rods.
If you're doing the main assembly, machine shop will need everything in the rotating assembly to balance it. There are a few here that have ran different rods and not rebalanced,.with no failures, but the risk is up to you.
__________________
04 GMC ECSB LLY - Mix breed trans/SC1056 - Profab - PPE - Kennedy twin pumps/pickup - Danville tuning: 531/944
I can't complain, but sometimes I still do
8.17@84mph 1/8mi
Jesse
  #3
Old 09-07-2018, 05:15 AM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Default
If it was me, and I’m cheap, delipped lb7 pistons, lbz rods, some sort of stage 1 AF cam. With Jesse pushing his ZF LLY over 700 horses on stock bottom end, I don’t think there’d be any issues.
__________________
2006 LLY CC/SB LT3 black, charcoal interior, tuned, leveled on 33s, my little piece of heaven
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s.
2011 Yamaha YFZ450X
2018 GasGas XC300
  #4
Old 09-07-2018, 05:26 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Default
If you're going to have the rotating assembly apart, it'd be pretty dumb to not throw a set of rods in it. Unless you on tight budget.... Wagler's as forged rods come to mind....
Sent from my XT1585 using Tapatalk
__________________
Isaac Griffith, formerly 04jimc
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
New DD/Beater: Beat up 06 GMC CCSB w/ 252,000 miles
Current Tow Rig-12 Ram 4500 Crew
'Oughta K
now Better'- PPL Lim Pro Stock 05 3500 Crew Cab 158" WB 2014 PPP 2.6 Champions
Thanks to Blackout Performance
  #5
Old 09-07-2018, 05:46 AM
gmac32 gmac32 is offline
Default
I think you should have everything balanced as well. I balance every engine i build to try keep unwanted vibration and harmonics to a minimum
__________________
2011 denali gmc 5.5 lift, 35" tires, carillos, cut, coated lml pistons, hot cam 63.5 mm vgt over billet s480, fox shocks, profab manifolds and up pipes, intercooler pipes, 10mm cp3, ported heads, valve springs
  #6
Old 09-07-2018, 06:03 AM
ikeG's Avatar
Oughta Know Better
Default
balancing is not an option, it's a requirement, if you're changing any of the parts or the weight of any of the parts in example delipping the Pistons
__________________
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #7
Old 09-07-2018, 06:26 AM
Yngdmax92's Avatar
Yngdmax92 Yngdmax92 is offline
Default
Guys on here really have tossed some rods in an engine and went to the pulls.??
__________________
2003 2500 hd cc/sb (leftovers) MPS 63.5 ihi, built trans, airdog 150, 30 overs..... Sold
New and improved! 2007 classis lbz LS ec/sb
Egr delete, pcv re-route, PIPED, airdog 4g 165,
Danville performance tunes.
  #8
Old 09-07-2018, 06:44 AM
boostwhore's Avatar
boostwhore boostwhore is offline
Drag racer wannabe
Default
If you go back through some of the old build threads it’s pretty crazy what some guys got away with! I remember reading Trent’s build thread where he used a router to de-lip his pistons in the truck
__________________
Chad
2007 lmm: kryptonite front end, full billet trans by Sdp, SoCal engine ovals and Carrillos, 12mm exergy stroker, 100 over exergy injectors, sdp billet 68mm over billet 480, awesome tuning from Aaron at All in trucks.
Best 1/4 to date: 11.06 at 127 in the chase for 10ís.
  #9
Old 09-09-2018, 04:40 PM
dirty_max's Avatar
Default
it will be a true stock charger. this is kind of a budget build, but I have money to throw at it if I want to. I was considering wagler or lbz rods. what are you guys using to pin the crank and cam? I assume the crank gear and damper get pinned? something like a socal 3388 cam sound about right?
__________________
  #10
Old 09-09-2018, 04:44 PM
dirty_max's Avatar
Default
this is why I am asking silly questions. ive rebuilt a lot of diesel engines and never had to have anything balanced. but it is always factory parts going back into it.
__________________
  #11
Old 09-09-2018, 05:12 PM
Default
Quote:
None of the factory stuff is balanced and is typically pretty far off. That is why I balance everything.
__________________
  #12
Old 09-09-2018, 06:01 PM
dirty_max's Avatar
Default
Quote:
I assume you are talking about gm or light duty engines in general?
__________________
  #13
Old 09-10-2018, 04:20 PM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
Default
If you’re running a true stock turbo then just run a stock bottom end. It’ll hold
__________________
03 reg cab. Low and slow
07 crew long classic- stolen
  #14
Old 09-10-2018, 05:32 PM
dirty_max's Avatar
Default
Quote:
Originally Posted by clrussell View Post
If youíre running a true stock turbo then just run a stock bottom end. Itíll hold
I figured a stock bottom end would hold but was somewhat curious if there is anything I could do in the bottom end that would potentially increase power.i know a stock charger is only going to do so much but if there is anything that I can do in the bottom end to help I would like to do it since im rebuilding anyhow. stock turbo and workstock in my area are very competitive and have a lot of strong running trucks in both classes. anything I can do to the engine during rebuild that can give me any advantage I would like to do. from some of the research that I have done really the only thing that can help is pistons and a cam. but im not really sure how much that will even help with a stock charger. also, do you guys see any issue with running egr heads? the engine that I have to rebuild is an egr engine. I was told that egr heads flow a little more than stock but you cant really do anything with them as far as opening up. would a set of socal heads help at all with a stock charger?
__________________
  #15
Old 09-10-2018, 06:31 PM
gmduramax's Avatar
gmduramax gmduramax is online now
Shits broke
Default
Rods are needed. You should be close to 650hp if done right. Anything you can do to lighten the rotating assembly and increase airflow will help.
__________________
2008 GMC duramax crew cab short bed 2500.
10.98@124mph
Thanks to Mike L, SoCal Diesel, and Abel Chevorlet.
Tailgate Crew Member #1
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vB.Sponsors
