  #31
Old 05-11-2018, 09:20 AM
Hambone's Avatar
Hambone Hambone is offline
Always learning
Itís just adult connect the dots lol
2017 2500 CC/LB "L5P" WT
2005 2500 CC/SB "LLY" LTZ
Typical mods for Longevity
awaiting stuff to go BooM then replace with more go fast parts!
And a few other retired Duramax's
06 360k aka Hog truck
07 320k aka Shop truck
07 340k Flatbed spare welding rig
  #32
Old 05-11-2018, 10:36 AM
weazel's Avatar
weazel weazel is offline
True^ lol!
88 Chevy 1/2 ton- LB7 conversion project
93 Chevy K3500- CR Cummins conversion project
05 Chevy LLY 5" ex, EFI DSP5
  #33
Old 05-11-2018, 10:47 AM
Hambone's Avatar
Always learning
Also just a simple google search of wire diagram symbols will answer what each squiggly line is
  #34
Old 05-11-2018, 03:02 PM
LBZ_Baker98 LBZ_Baker98 is offline
Traced all the wires and couldn't find anything wrong with any of them. Yesterday the key would kill all power like it's supposed to. Now it's back to the dash lights and cablights etc etc staying on after turning key off. The 2 amp DLIS fuse also quit blowing but truck still won't start. I'm at my wit's end.
07 LBZ CCSB EFI Live DSP5 and trans tuning by (Who's ever tunes I decide to run that day) airdog 165, Built trans by Josh H. At Top Notch Garage
  #35
Old 05-11-2018, 03:15 PM
TheBac's Avatar
TheBac TheBac is offline
You can't base wiring condition simply on looks. The leads within the casing could be broken, and you'd never know it from the outside. You'll have to check continuity through the individual circuits.
Tom
  #36
Old 05-11-2018, 03:35 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Almost sounds to me that something is shorting out the BCM and possibly killing it too. You may need to check all of the circuits coming out of the BCM that the DLS fuse powers.
What about putting a light bulb in line with the fuse? Something that will limit the current to a safe level then probe the wires and measure the voltage. When you remove the short or disconnect the bad wire the bulb will drop in brightness or go out.
2008 Chevrolet 3500HD DRW LTZ
  #37
Old 05-11-2018, 04:10 PM
I'll get the light bulb rigged up tomorrow. This has been a going on for almost 2 months. 2 shops have already looked at it and gave up. I'm ready to call it quits but so determined at the same time!
  #38
Old 05-11-2018, 07:21 PM
NC-smokinlmm's Avatar
<<<Future tuna killer
You check the under hood fuse panel? They warp and cause issues or get mice in them...
2010 GMC 1500 RCSB Denali Clone < lifted 22's/33's/ Kooks / Magnaflow / 5.3 / 6l80E / TVS1900 @ 14#'s / BTR Top End / Boosted Bump Stick / Trunion upgrade / 90mm / 10% over / 2.8 griptec / 105 lb ID's / Mayhem built/tuned.
  #39
Old 05-11-2018, 07:22 PM
I've pulled it apart and visually inspected it looked okay. Didn't look for warping though. I'll check it tomorrow! Thanks!
  #40
Old 05-16-2018, 09:54 PM
Just to update everyone. I have put hours on hours into this thing and I'm finally calling it quits. It's going to another shop on Monday that has even agreed to let me shadow the mechanic while he diags and hopefully fixes it. I'll update everyone with the fix. Thank you to everyone who has helped
  #41
Old 05-17-2018, 03:05 AM
gmc502 gmc502 is offline
did this truck come out of a flood?
2002 GMC 2500HD, ECSB, 4WD, LB7,300k miles and still truckin
new style gm exhaust manifold, banks big head wastegate, PPE boost valve, banks air intake,high idle switch in cruise control, stock but not for long
EFI live tuned byMe now,dps5 switch,EGT probe and autometer boost sensor,SoCal 6spd conversion
  #42
Old 05-17-2018, 04:05 AM
I was just thinking the same thing...
  #43
Old 05-17-2018, 07:13 AM
Ron Nielson Ron Nielson is offline
Anyone know where I can get it pay for a wiring diagram
Free wiring diagrams - be sure to press wiring diagrams or you will go to TSB's: http://www.bbbind.com/free-tsb/
Ron Nielson
2008 Chevy Silverado LT, SRW, Crew Cab, LB, LMM/Allison, Rear lowered 2": otherwise, fully stock at this point. Edge Insight CTS
  #44
Old 05-17-2018, 07:48 AM
No, was bought off the show room floor in 2008 never been in a flood and actually been takin Care of pretty good. It has been a work but no flood
  #45
Old 07-05-2018, 04:10 AM
1dmax 1dmax is offline
FNG
Figure this thing out yet?
