Duramax Diesels Forum
Duramax Diesels Forum (https://www.duramaxdiesels.com/forum/index.php)
-   Turbo Performance - contact Levi Lish (208) 251-9141 (https://www.duramaxdiesels.com/forum/forumdisplay.php?f=134)
-   -   New Color Options. Carbon Black and Graphite Gray (https://www.duramaxdiesels.com/forum/showthread.php?t=83373)
Turbo Performance 10-09-2019 04:21 PM
Hey everyone,
Have a couple new color options available. Moving forward these will be replacing the original coated black and silver blankets.
Though the originals will be available by request if trying to match a previous setup.
Blanket performance is every bit as good with these colors as they were before.
Shout with questions! :rockon:
https://i.imgur.com/Q6Qp6wHh.jpg
Burn Down 10-09-2019 07:47 PM
New colors look good Levi:thumb: When I get the single cab up and running Ill bring it up to you for some custom blankets on the turbo plumbing.
Bdsankey 10-10-2019 05:34 AM
Are you planning on incorporating the loop-and-pull through method like these blankets show or the same mounting style as previous?
I'm going to end up needing a set once I get my LB7 back on the road (bearing damage so its getting new main/rod bearings, oil pump etc) with compounds. I do need to hit you up about what is going to be the best option for heat protection on the downpipe.
Turbo Performance 10-10-2019 09:25 AM
Quote:
Sounds good, give me a shout when you're ready! :thumb:
I prefer the anchors shown in the picture. In my experience they're a stronger fastener and put less stress on the blanket over time than the grommet style does. With that being said, I can do whatever a customer wants fastener or style wise.
Shout at me when you get closer to being ready and we'll spend a few minutes on what will work best for you.
hondarider552 10-10-2019 06:44 PM
I need 2 small turbine T4 blankets for my LS :woott:
Turbo Performance 10-11-2019 08:00 AM
Quote:
Small? I figured you had went big on literally everything this time around. :rofl: Build really looks good dude. Send me over some specs on what you need or a measurement and I'll get you hooked up.
KyleC4 01-08-2020 09:46 AM
are these the colors shown on your website as well? I got a new drop-in style turbo for my lb7 and am looking for something like this instead of factory heat shield.
Turbo Performance 01-10-2020 06:09 AM
Quote:
Yes, most of the blankets are shown and available on the website. Though I'm still working on things here and there. If you need something you don't see, just hit me up. Odds are I can make it.
KyleC4 01-11-2020 09:33 AM
Quote:
Thanks. Iíll probably just call you on Monday since I have a few things to run by you for your opinion.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vB.Sponsors
