Parasitic draw
1,718
Sounds more then just parasitic draw. That would be quite a bit of current to kill a set of batteries in two hours. Like burning up the wires. Or glow plugs stuck on
Have you had your alternator checked and batteries load tested?
Reactions: Pure Diesel
3,307
350
What's the point in this thread? Your vehicle should be under warranty.
If you wish to diagnose the problem, use an amp clamp or put a capable meter between the battery post and cable, give the modules a few minutes to shut down and note the amp draw. Start pulling fuses and see where it starts dropping off at
Reactions: 2004LB7
dblnautspi
Feb 24, 2023
Ky
I have replaced batteries and alternator I can remove wire feeding fuse box and it goes away i have pulled all fuses in all fuse boxes but draw is still there have disconnected glow plug controls and most of the connection but draw is still there I’m at a loss any suggestions is greatly appreciated
4,806
383
You could probably leave every power accessory on a vehicle on, and you still wouldn't kill the batteries in 2 hours.... Hell I got a 1000W stereo that barely kills them in 2 hour with the truck off.
