Harsh downshifting
20dmax08
57
Having some harsh downshifting, trans with harsh downshift to 3 shift back to 4 then go back to 3. Will also downshift hard 2-1. No trouble codes, fluids good, and spin on changed. Any thoughts? Speed sensor in t case?
OleBlackyLBZ
350
85
Sounds like you have the same downshift jerking problem that half the people with built trans I know have. Mine does it bad and has been doing it for over 100,000 miles of 550-650 hp. I have had it to downshift hard enough to squall the tires. No codes, no trans slip nothing, acceleration is smooth as butter.
OleBlackyLBZ
350
85
I have replaced the transfer case speed sensor. I have also replaced the slip yoke with a nickel plated one, nothing helps. I think these built transmission are just tight enough that sometimes on a downshift it suddenly takes up any slack in the driveline causing it to jerk. The weird thing is some of them don't do it, I don't think your ever going to get a straight answer on this.
1,723
I think you may be overblowing the number of built trans with this problem and misleading and scaring the OP. While the people you know may have issues, that doesn't represent the average. Both Mike and Even build transmissions that rarely have issues.
OP, reach out to Even if you used his kit. He has always stood by his products and will take care of you. Alternatively you can call Inglewood transmission and talk to Mike or Even. It will be easier to discuss your issues over the phone then waiting for a reply here
20dmax08
57
Mine never did it for the longest time. Not like this only on the 2-1 downshift intermittently. Will try the speed sensor I think and see. Maybe someone out there has an answer hahaha
OleBlackyLBZ
350
85
I am not trying to mislead anyone, I called Evan himself about mine about a year and a half ago and he told me it was hit and miss and that they were not sure why some of them done it and some didn't. Maybe things have changed since.. again I did not mean any harm I should not have put a percentage on it.
Mike L.
Got Sheep?
15,686
232
Fullerton CA
2 tubes of Lube Gaurd will usually fix the problem. 3 if you have a deep pan.
OleBlackyLBZ
350
85
I'm about to do another transmission double drain and fill. I have ran Walmart Dex III so far and it's worked fine. But should I do something different like suncoasts synthetic trans fluid? I know years ago most builders reccomended Dex III but is that still the standard or is there better?
Mike L.
Got Sheep?
15,686
232
Fullerton CA
Change the internal filter as those clutches tend to shed and restrict filter. Dex 3 is fine.
OleBlackyLBZ
350
85
That's good to know mike, I changed the fluid very soon after it was built and then about every 30-40,000 miles after that, and I change the internal filter every single time. Spin on get's changed about every 15,000.
