Need help ASAP
Wardiamond2212
Jan 30, 2021
14
I’m in flemington nj any help is greatly appreciated this is the second place it’s been to the first charged me 70 per scan and scanned it 3 times with no results wouldn’t even put the nsbu switch in I laid in there lot and did it Iv never had this type of issue with places before. I got a call from the guy it’s currently with and he claims he hooked up my tcm to his truck and it fine I’m so frustrated
Wardiamond2212
Jan 30, 2021
14
I was talking to someone who had same issues bought nsbu from autozone wouldn’t work then got another from gm and solved problem does it need a gm nsbu?
juddski88
Freedom Diesel
Jul 1, 2008
4,651
116
Chesterfield, Mass.
When the power steering pulley came off, you said it wouldn't shift right after that? I have to assume that the pulley damaged some wiring in the harness from the tcm to the trans and tcase. You said it would drive normal in 4lo? That is still correct?
Reactions: Bdsankey
Nate’s Dmax
177
Hey good thought there. That certainly would be something to check.
Reactions: Bdsankey
3,906
1,074
Neenah, Wisconsin
I agree with this, it's not out of the realm of possibility for it to have damaged something during its exit off the pump.
