Do your manifolds work with OEM style up-pipes or is the flange size and orientation different?
C Chilly Member Dec 4, 2018 101 3 18 Dec 9, 2018 #1 Do your manifolds work with OEM style up-pipes or is the flange size and orientation different?
R RickDLance Active member Feb 14, 2007 1,276 14 38 Dec 10, 2018 #2 No. The flange on the manifold has been moved outward for more clearance on the bellows. You must use the up pipes designed for the manifolds.
