Driveshaft Options?
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
What are the pros and cons with steel vs aluminum?
Can I just get that yoke cut off and have a new one welded on? Like a billet one?
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
I know nothing about welding...Can you weld billet aluminum to non billet aluminum?
5,057
Steel can take much more abuse, only con is the aluminum is lighter.
adding a billet yoke wont make much difference for the center section of tube, thats still the weakest point, you created that weak point due to axle wrap. your issue that caused that damage has been addressed so even a stock yoke would be just fine in its place.
