  #1
Old 12-03-2008, 01:40 PM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Default BPU List for LLY's
BPU stands for Basic Performance Upgrades. These are modifications that don't require engine disassembly. Here is my list of basic power mods:
  • Tuning - EFILive, PPE, or custom tunes. All can take you to the 500rwhp area, I like starting out with an EFILive tune, then adjusting it on the dyno for a specific truck. This is the ultimate Bang-For-The-Buck mod for LLY's.
  • 4" exhaust - or a 5", it will normally be worth about 15rwhp on a tuning only truck. The biggest restriction will be the factory muffler.
  • Downpipe - While it shows small gains at 2000-3000, by the time you get to 3400, it will show 15hp when using a 4" exhaust.
  • Shimmed FPRV - You will need this to hold rail pressure with big tuning. Period. You can use a race valve to the same effect.
  • EGR blocker - in order to run more than 25PSI boost, you need to keep the EGR valve from being forced open.
  • Lift pump - While it might not show up on a dyno, it is worth .1-.3 seconds off your quarter mile times.
  • Intake - The factory one is pretty good. Pulling the headlight is about as effective as any normal aftermarket filter. But the ram air systems show solid gains at the dragstrip. Banks is the only mfr that I'm aware of.
  • PCV reroute - Jury is out on it's HP effect, but seems to help get big numbers.
  • Ported Regulator - Has show an average 20rwhp on BPU trucks, will show more with big chargers.
  • LBZ intake neck - No drag tests yet, but it is believed it's one of the reasons LBZ's are putting out more power than LLY's.
  • 3" intercooler tubes - Not commercially available yet, nor is data available. They can't hurt, and probably help.
  • Aftermarket intercooler - While I didn't find a 1/4mi improvement, many report lower EGT's.
  • Transmission upgrade - As soon as you pass 400rwhp you are living on borrowed time. You will need a minimum of a converter, C3's, and valving kit.
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
  #2
Old 12-03-2008, 04:28 PM
speedmetal6.6's Avatar
speedmetal6.6 speedmetal6.6 is offline
Dodge Destroyer
Talking What about LBZ's
IS this list the same for LBZ,s or do you recommend other mods ,also what brands do you recommend and why
__________________
2006,6.6 liter LBZ, Ready Lift Leveled, 285 bfg's, AFE stage 2 intake, MBRP 4" straight( no muffler), EGR blocked, EFI LIVE ( SPADE KING TUNER) AND DSP5 switch. PCV re route, PPE rail fitting, Fprv shim kit, Raptor lift pump, Transgo Jr, PPE Gauges, Pyro, Boost, Fuel psi.
  #3
Old 12-03-2008, 05:18 PM
Oilfield_Mafia's Avatar
Oilfield_Mafia Oilfield_Mafia is offline
Im the ONLY Okie..
Default
Thanks Pat, Great info for noobs like me.. I understand all of them, except one
Is this the same as a Ported Fuel Rail Fitting? Like that one PPE offers, and I saw for sale on here that someone had done themselves?
__________________
2007 Classic, LBZ CC/SB 4x4
PPE, 4" Straight, Shimmed, Resonator Delete, PCV Reroute, Custom Airbox, TransGo Jr.
Special Thanks to Jim @ Upstate Diesel, Johnny (Gasuout), 2500HeavyDuty, and everyone else in my ongoing learning process!
Quote:
Originally Posted by Mike L. View Post
No one that drives a Cummins has ever experienced an erection longer than an 1/8 mile. They either crash or break; either way it is deflation.
  #4
Old 12-03-2008, 05:40 PM
McRat's Avatar
Diesel Hotrodder
Default
Quote:
I will make a list for the other trucks too.
If you have a specific part or brand question, I will try and answer it. I've tested many different brands and types of products.
__________________
Pat and Kat McSwain
  #5
Old 12-03-2008, 05:42 PM
McRat's Avatar
Diesel Hotrodder
Default
A Ported Fuel Pressure Regulator plugs in the back of your CP3 to increase max fuel flow from the pump. The ported fuel rail removes a restriction in the rail. I should have listed that also, even though I didn't gain anything when I tested.
__________________
Pat and Kat McSwain
  #6
Old 12-03-2008, 05:44 PM
Im the ONLY Okie..
Default
Thanks Pat! I cant wait to see what you have listed in the LBZs..
__________________
  #7
Old 12-04-2008, 07:10 AM
LarryJewell's Avatar
LarryJewell LarryJewell is offline
Back with his honey :)
Default
Quote:
I did the ported fuel rail fitting at the same time as the 68mm Cheetah, so also was hard for me to tell and I did the fuel regulator about the same time as the 71.5mm Cheetah, so once again, hard to tell how much it helped
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #8
Old 12-05-2008, 09:30 AM
Noreaster's Avatar
Noreaster Noreaster is offline
Default
You could apply these to LB7s plus
Adjustable Wastegate-BD or Banks
BD Manifold
Remove Intake heater
fuel pickup
__________________
02 GMC 2500HD RC/LB "No Shuckin Luck" Totaled 12.26 @ 109
Ridge Runner Diesel Performance, Big Dipper tranny, Profab Performance, Super Diesel, Creatures of the Night, AirDog, BD
02 GMC 2500HD EC/SB WCFab twins
Bay State Diesels
  #9
Old 12-05-2008, 10:59 AM
05smoker's Avatar
05smoker 05smoker is offline
I'm officially done!
Default
I think this is one of the best mods for the $ I have ever done. My truck is much snappier around town and more fun to drive now. It may not be a large increase in overall HP, but it definitely drives better and spools quicker than a stock LLY (the 2 stroke of Dmax's).
__________________
2005 2500HD CHEVY CCSB, Blackout VVT, FPE SCIV w/ 1057, 3" lowering shackles, overloads removed, Cooper Zeon LTZs on BMF REPRs. SOLD
Thanks to Fleece, Blackout Performance, Genes Machine Shop, Tim, Bullfrog, Simon, Mark Broviak .......
Remote mount turbo, Electric Water Pump, Cheetah turbo - Member #1
  #10
Old 09-07-2009, 08:26 AM
WiggyHD's Avatar
WiggyHD WiggyHD is offline
Gearhead
Default
Great list! I've been looking for a shopping list like this. I just ordered the Banks Ram Air w/superscoop and the cat-back Monster Exhaust. I asked them if the cat is still a big restriction, and they said "Not as much as you would think". Would it benefit me to buy a front pipe and down pipe? These are the only things I have done so far. I will be doing EFI or Banks Six-Gun/Economind in the near future. I won't race or pull. I just tow the camper and haul the family.
Mark
__________________
2005 Chevy 2500HD Crew Cab Duramax.
Banks Six-Gun with IQ
Banks Monster Exhaust
Banks Ram Air w/Superscoop
LBZ Turbo inlet
Prodigy, Raider cap, Luvern stainless running boards, Wade window louvers, Wade hood deflector
'06 TSB (complete LBZ intake system) on the shelf
U.S. Air Force Retired/Disabled Vet
  #11
Old 09-07-2009, 09:17 AM
whitetrash21's Avatar
whitetrash21 whitetrash21 is offline
put on da damn helmet day
Default
Not a huge restriction, but I pulled mine few weeks ago and there is a little bit quicker spool and maybe a little better pedal response. Not too mention it sounds 10 times better. No downpipe yet so I cant say anything about that.
  #12
Old 03-17-2010, 04:49 AM
Default
Quote:
We put one on a totally stock truck, with the exception that it has a missing egr, a Fass lift pump and banks boost tubes..........he said no noticeable gain. This is runnning a mild EFI tune (stock transmission)
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #13
Old 04-22-2010, 05:34 PM
dmax84 dmax84 is offline
FNG
Default
Who sells these??
  #14
Old 04-22-2010, 05:51 PM
SSchmi5519's Avatar
SSchmi5519 SSchmi5519 is offline
Pro Tuner Wannabe
Default
The ported rail? PPE sells one.
The modded regulator? Wicked Diesel sells one.
__________________
-Steve- 2005 LLY Inglewood Transmission, EFI Live, PPE, ARP, Crower, BT Diesel, T&B Fab
Email: ASK.SSDT@GMAIL.com
  #15
Old 11-19-2010, 02:26 PM
dirttymaxx's Avatar
dirttymaxx dirttymaxx is offline
Default
you can do the mod to the regulator your self if you dare. . . . .
__________________
04.5 LBZ/LLY dirttymaxx puller
efi live 570 hp 6/11/11 STOCK charger!
down pipe,headers,up pipes,egr removed,locker front and rear,ats tranny,7" bull hauler stacks,custom 3" intercooler tubes,3" intake bridge,lots of polished parts 45% over injectors,head studs,LBZ turbo intake mod,custom 4" air intake with k/n filter,heads ported and polished by ME!,custom solid motor mounts,built cp3 pump from diesel injection
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
