  #1
Old 11-06-2008, 02:55 AM
ripmf666's Avatar
ripmf666 ripmf666 is offline
Truck: 2006 2500 HD ex cab
Engine: Duramax 6.6
Transmission: Automatic
Default 01 Fuel Injection Pump Replacement
Service Information
2001 Chevrolet Chevy K Silverado - 4WD | Sierra, Silverado, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Engine | Engine Controls - 6.6L | Repair Instructions | Document ID: 739906
Removal Procedure
  1. Caution: Unless directed otherwise, the ignition and start switch must be in the OFF or LOCK position, and all electrical loads must be OFF before servicing any electrical component. Disconnect the negative battery cable to prevent an electrical spark should a tool or equipment come in contact with an exposed electrical terminal. Failure to follow these precautions may result in personal injury and/or damage to the vehicle or its components.
  2. Disconnect negative battery cables from both batteries.
  3. Remove the air intake duct between the air cleaner and the turbocharger inlet housing. Important: Cover the air intake pipe end with duct tape to prevent the infiltration of dirt.
  4. Drain the coolant. Refer to Cooling System Draining and Filling .
  5. Remove the upper fan shroud. Refer to Engine Coolant Fan Upper Shroud Replacement in Engine Cooling.
  6. Remove the fan blade assembly. Refer to Fan Replacement in Engine Cooling.
  7. Remove the serpentine belt.
  8. Remove the bolt holding positive battery cable junction box and bracket and move out of the way. Important: Remove only the air conditioning/power steering bracket. Do not discharge the A/C or remove the A/C and power steering lines.
  9. Remove the A/C compressor. Refer to Air Conditioning Compressor Replacement in HVAC.
  10. Remove the power steering pump. Refer to Power Steering Pump Replacement in Power Steering Systems.
  11. Position the A/C compressor and power steering pump aside.
  12. Remove the oil filler tube. Refer to Oil Filler Tube Replacement in Engine Mechanical.
  13. Remove the air conditioning/power steering bracket.
  14. Remove the alternator. Refer to Generator Replacement in Engine Mechanical.
  15. Remove the thermostat housing bracket, wiring and fuel test port, and two nuts.
  16. Remove the positive crankcase ventilation (PCV) catch tank from the PCV bracket and bolt below holding lower line, and move to the side.
  17. Remove the alternator bracket. Refer to Generator Bracket Replacement in Engine Electrical.
  18. Remove the turbo cooling hose return line clamp and hose.
  19. Remove the upper radiator hose at the outlet pipe. Remove the bracket and support the bracket at the valve cover, and swing out of the way.
  20. Remove bolt holding wiring support bracket at thermostat housing.
  21. Move the main wiring harness by disconnecting the following:
    The fuel pressure regulator connector on the fuel injection pump
    The fuel injection control module connectors
  22. Flip the wire harness and harness tray towards the back and set aside.
  23. Disconnect the heater pipe bolt and temperature sensor wire from the thermostat housing.
  24. Remove the air intake pipe. Refer to Air Intake Pipe Replacement .
  25. Remove the water crossover assembly. Refer to Thermostat Housing Crossover Replacement in Engine Cooling.
  26. Remove the hose to the turbo water feed line. Refer to Turbocharger Coolant Hoses/Pipes Replacement in Engine Cooling. Important: Cap all of the open fuel connections with suitable plastic plugs in order to prevent infiltration of dirt.
  27. Disconnect all high pressure fuel lines and remove supply pipe and hose at the fuel injection pump and function block. Refer to Metal Collar Quick Connect Fitting Service .
  28. Remove the supply hose from the fuel injection pump.
  29. Remove the fuel return hose from the fuel injection pump.
  30. Remove the high pressure line from the injection pump to the junction block. Important: Be careful not to damage any mating surfaces.
  31. Remove fuel injection pump from the block using two screwdrivers to work the pump from the block towards rear of engine keeping the pump straight.
  32. Remove fuel injection pump.
Preparing Fuel Pump
  1. Hold the fuel pump by the drive gear in a vice with copper jaw liners.
  2. Loosen the gear nut until the nut is even with the end of the gear shaft.
  3. Remove the gear from the tapered shaft of the pump.
  4. Separate the pump and adapter by removing the three bolts and spacers.
  5. Inspect the O-ring for damage on pump adapter and replace, if necessary. Lubricate the O-ring with clean engine oil.
  6. Clean all mating surfaces.
  7. Install the adapter on the pump. Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  8. Using the three bolts and spacers, reassemble the pump. Tighten
    Tighten the bolts to 20 N·m (15 lb ft).
  9. Install the gear and nut. Tighten
    Tighten nut to 70 N·m (52 lb ft).
Fuel Injection Pump Installation
  1. Install the fuel injection pump. Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  2. Install the fuel injection pump mounting bolts from the front of the engine front cover. Tighten
    Tighten the fuel injection pump mounting bolts to 20 N·m (15 lb ft).
  3. Reconnect the fuel return line banjo bolt at the junction block. Tighten
    Tighten the banjo bolt to 15 N·m (11 lb ft).
  4. Install the fuel supply hose and hose clamp to the fuel injection pump.
  5. Install fuel return hose and hose clamp to the fuel injection pump.
  6. Install the high pressure lines from the injection pump to the junction block. Tighten
    Tighten the high pressure lines to 44 N·m (32 lb ft).
  7. Install the fuel pressure sensor connector at the junction block.
  8. Replace hose to turbo water feed line. Refer to Turbocharger Coolant Hoses/Pipes Replacement in Engine Cooling.
  9. Install water crossover assembly. Refer to Thermostat Housing Crossover Replacement in Engine Cooling.
  10. Install air intake pipe. Refer to Air Intake Pipe Replacement .
  11. Install the heater pipe using the following procedure:
    11.1. Install new O-ring lubricated with clean engine oil.
    11.2. Install the heater pipe bracket bolt.
    Tighten
    Tighten the bracket bolt to 20 N·m (15 lb ft).
    11.3. Install the heater pipe to water crossover bolts.
    Tighten
  12. Connect the engine wiring harness.
  13. Install upper radiator hose at outlet pipe using the following procedure:
    Install upper radiator hose mounting bolts and brackets.
    Tighten
    Tighten the bolts to 10 N·m (89 lb ft).
    Install the upper radiator hose clamp.
  14. Install turbo cooling hose return and clamp.
  15. Install the left idler pulley and bolt.
  16. Install PCV catch tank, hose clamp and bolt to the right front of the engine.
  17. Install the thermostat housing bracket, wiring, fuel test port and nuts.
  18. Install the alternator. Refer to Generator Replacement in Engine Electrical.
  19. Install a new O-ring to the oil fill tube and lubricate the O-ring with clean engine oil.
  20. Install the oil fill tube. Refer to Oil Filler Tube Replacement in Engine Mechanical.
  21. Install air conditioning/power steering bracket and bolts. Tighten
    Tighten the air conditioning and power steering bracket bolts to 46 N·m (34 lb ft).
  22. Install the power steering pump. Refer to Power Steering Pump Replacement in Power Steering System.
  23. Install the air conditioning compressor. Refer to Air Conditioning Compressor Replacement in HVAC.
  24. Install the positive battery cable junction box and bolt.
  25. Install the serpentine belt. Refer to Drive Belt Replacement in Engine Mechanical.
  26. Install the fan blade assembly. Refer to Fan Replacement in Engine Cooling.
  27. Install the upper fan shroud. Refer to Engine Coolant Fan Upper Shroud Replacement in Engine Cooling.
  28. Refill the coolant. Refer to Cooling System Draining and Filling in Engine Cooling.
  29. Install the air intake duct between the air cleaner and the turbocharger inlet housing.
  30. Reconnect the negative battery cables to both batteries.
  31. Replace all of the hold down ties.
  32. Start the engine and check for leaks or noises.
  33. After the engine warms up, refill coolant reservoir to proper level.
© 2008 General Motors Corporation. All rights reserved.
__________________
Devil Girl 2006 2500HD LBZ Ex-Cab 4x4
EFI Live tuned by IdahoRob,MPI twins intalled by BigDipper,PPE dual cp3,PPE lift pump,BigDipper 30% injectors, BigDipper Trans Precision ML converter.
Alot Of thanks To George aka BigDipper,Guy at Socal Diesel.
RIP LBZ 6/1/08@5:44pm she was strong
She's Alive again
Born on July 27, 2008, 11:59:02 PM
Post Whore #5
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
