  #16
Old 08-31-2009, 06:52 PM
SIKDMAX's Avatar
SIKDMAX SIKDMAX is offline
Highway Burnouts!
Default
Quote:
Originally Posted by Whitetail Addict View Post
Engine oil 10qt or 2 1/2gal (not sure metric equivalent) 15w-40 or equivalent synthetic.
10qt for a change, any idea on an overhaul? Going to get oil now.
__________________
Matt...2008 Chevy DMax CCSB 4x4 LTZ LMM
Carillos, Mahles, ARP 625s, SoCal Cam, Stage 1 Heads, 60% sticks, PPE Dual CP3, HTT 66SS/GT4718R Stainless Steel Twins, PPE High Flow Intake Manifold, Up Pipes and Headers. 6" MBRP single stack. Mike L. Suncoast 4 w/ 1057
  #17
Old 08-31-2009, 06:56 PM
KEVINL KEVINL is offline
Default
Paint how much do those cans in your avatar hold
  #18
Old 08-31-2009, 06:57 PM
SIKDMAX's Avatar
Highway Burnouts!
Default
__________________
  #19
Old 08-31-2009, 09:10 PM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
9.5 litres
__________________
07 RC/LB 2wd
A/D lift pump,Tunes from Josh H, BD Manifold and custom up pipes, P&I supports, PPE tie rod sleeves
05 CC/LB
EFI ,A/D lift pump,Cognito 7"lift /P&I supports / Banks air and exaust /ARP head studs/ Mike L stage 4 trans / EPR twins. SOLD
Abby 01 RC/LB 10.28@144mph
Arias pistons/ Howards rods / S475 & PBK twin turbos from EPR/PPE 2 CP3 / SoCal stg 2 heads & cam / 100 over sticks /Socal flexplate & dampner & girdle /DPR oil pump / 47RE /BD intercooler / Ted at MPL / Turbo blankets from Levi FOR SALE
  #20
Old 09-01-2009, 09:49 AM
PhilsLB7's Avatar
PhilsLB7 PhilsLB7 is offline
Way Better Than Facebook
Default
Quote:
Originally Posted by RayMich View Post
I let them both drain for over a 1/2 hr while I lubed and greased the rest of the truck.
Speaking of, can someone clearly show where all the grease points are on our trucks? If there is already a thread out there, please point me in the right direction. This is something I need to do soon.
__________________
Phillip
02 Chevy 2500HD CC/SB 4X4 LB7 w/Allison Trans
Just stock
  #21
Old 09-01-2009, 10:06 AM
66FLH's Avatar
66FLH 66FLH is offline
Been to Hell and back!
Default
Quote:
Originally Posted by LBZ View Post
Can we get this in english as well? WTF is a quart??
I like Pints myself!
__________________
04 LB7 w/ worked Allison.PPE Hot +2 Silverline 4" straight piped.6" Fabtech w/Nitrogen reservoir shocks.18" KMC Monsters w/325/65-18"Cooper STT's.
If corn oil is made from corn, and vegetable oil is made from vegetables, what's baby oil made from?
Freedom is not free...but the U.S. Marine Corps will pay most of your share!
For FREE money,click hereX Not responsible for your cheap computer not opening up the free money link!
  #22
Old 09-01-2009, 10:37 AM
SIKDMAX's Avatar
Highway Burnouts!
Default
Coolant capacity?
__________________
  #23
Old 09-01-2009, 10:49 AM
MadMaxx61's Avatar
MadMaxx61 MadMaxx61 is offline
Devilmaxx
Default
Quote:
Originally Posted by SIKDMAX View Post
Coolant capacity?
LMM/LBZ Cooling System, Initial Fill..........25.0 quarts
LLY Cooling System, Initial Fill..........24.0 quarts
LB7 Cooling System, AT Initial Fill..........20.0 quarts
for us not in the USA 1 quart, ≡ 1.1365225 L
__________________
Steve
2008 2500HD 4X4 LTZ Z71 6.6L LMM
Mods: EFILive, MBRP 4" DPF Delete, BD Manifold, SD Manifold, SD Center Link, SD Sleeves, S&B Intake, FS-2500, PPE Trans Pan, Bushwacker fender flares, PPE Oil Centrifuge, And other non-go-fast things.
Things still need to put in: PCV Re-Route,Air Dog AD-200.
1984 GMC Jimmy 2-Door
1998 Buick Century Limited
Sold It will be missed. 1985 Mercedes 300SD - Running still need work.
Sold It will be missed. 1995 C/K 3500 4X4 Dually 6.5L
Mods: K&N air intake, 80Hp chip, 97 cooling, twin fans, #9 Resistor, FSD Heat-Sync, Full Pillar 3 Gauge (EGT, Boost, Transmission),
  #24
Old 09-01-2009, 11:03 AM
SIKDMAX's Avatar
Highway Burnouts!
Default
Thank you sir that helps tons!
__________________
  #25
Old 12-01-2009, 11:59 PM
RayMich's Avatar
RayMich RayMich is offline
Gearhead
Default
What's the capacity of the 2006 Allison Transmission?
Drain & Fill:
Overhaul:
Thanks.
__________________
Ray
2006 GMC 2500HD - SLE1, EC/SB, 4x4, (LBZ) Duramax HO; (MW7) Allison 6-spd auto trans; (G80) Eaton Locking Rear Diff; (DPN) Camper Outside Mirrors; (VYU) Snow Plow Prep Pkg; GoodYear Wrangler Silent Armor LT265/75R-16E on 3500 SRW 16"x7" Chrome Steel Wheels; GMC Bug Deflector & Mud Guards; GM Tailgate Lock; All-4-On Headlight Mod; Line-X Over the Rails Bed Liner; ARE cab-high Cap; Stanadyne Performance Formula Fuel Treatment; Garmin StreetPilot 2720.
  #26
Old 02-04-2010, 11:17 AM
lotsofmiles lotsofmiles is offline
Father of the Van
Default
Drain & Fill:
Overhaul:
Thanks.
x2- buying fluid today
__________________
Quote:
Originally Posted by Jeremy Clarkson View Post
Some say he was conceived in a cargo van
  #27
Old 02-04-2010, 12:54 PM
Father of the Van
Default
bought 4 should be enough
__________________
  #28
Old 02-04-2010, 03:50 PM
MadMaxx61's Avatar
Devilmaxx
Default
Automatic Transmission, 1000 Initial Fill......................7.4 quarts
Automatic Transmission, 6 speed 1000 Total Fill ..........12.7 quarts
Automatic Transmission, 5 speed 1000 Total Fill ..........12.7 quarts
__________________
Steve
  #29
Old 01-30-2011, 04:01 PM
nmeyer414's Avatar
nmeyer414 nmeyer414 is offline
Gearhead
Default
Ok, so I have a late model 06 (manufactured NOV 06) Chevy with an 07 LBZ under the hood. My concern is that I have this grinding noise coming from underneath my rig. I originally thought it was the brakes, but when I pulled off the tires I heard and found nothing unusual. I got a wild idea and thought I would check my front and rear differentials, and found that they were low on fluid. I am enroute to the parts store to get the 75W90 that it requires. Should I be changing my transfer case fluid as well or?? I also read a thread on here about pump knock, should I be concerned about this with an 06 or forget about this?
  #30
Old 01-30-2011, 04:09 PM
coldLBZ's Avatar
coldLBZ coldLBZ is offline
Default
It wouldn't hurt to change the T case fluid. I think GM recommends 2 qts of ATF in the T case, but there are lot's of threads on here about guys running 3 qts of 5w30 syn. I have the pump rub upgrade in my case and I also run 3qts of syn 5w30. Also if it was me I would change the front and rear diff fluid too since you're picking it up anyway. 2qts front and 4qts rear. I'm not saying this will fix the grinding sound though.
Edit: Here's a thread about running 5w30 in the T case:
http://www.duramaxdiesels.com/forum/...ad.php?t=16312
__________________
Dan
2006 Chevrolet 2500HD 4x4 CC/SB LBZ Allison
PPE Hot+2 ET, S&B Cool Air Intake, MBRP 4", PCV Reroute, BD Manifold, SD Manifold, SCIV/PPE-Precision Converter/Pump Rub Fix/T-Case Brace/SoCal Diesel Flexplate By Ted @ MPL
2014 GMC 1500 4X4 RC/SB 5.3L
2008 GMC 1500 4x4 CC/SB 6.0L 4L70E - GONE
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
