  #1
Old 07-27-2008, 04:58 PM
psyco66's Avatar
psyco66 psyco66 is offline
Default This is why you block your EGR
My truck only had 30,000 miles when I blocked my EGR. There is about a 1/8 inch of soot built up. Imagine if the truck had more miles.
__________________
JOHN
05 4 door short bed 4x4 chevy LLY
EFI LIVE with McRat tune, DSP5, PPE Lift Pump, 4inch Turbo Back Strait Piped MBRP Duals, EGR block off, AFE stage 2 intake, Turbo resonator blocked off, 6000k HID kit, 305/75/16Super Swampers on stock rims, Auto Meter boost and pyro gauges, Killer sound system, Limo tint all the way around, Tinted tail lights, Suncoast stage 4 built by me.
NO TALKING JUST LINE IT UP
  #2
Old 07-27-2008, 05:03 PM
fast03's Avatar
fast03 fast03 is offline
Default
thats pretty bad. do you do alot of cold weather or short trip driving?
__________________
2011 LML maybe a little not stock
Previous Dmax: 2003,CCLB,4088r,mikel trans and other goodies
Steve
  #3
Old 07-27-2008, 05:07 PM
psyco66's Avatar
Default
No I live in San Francisco the temp is between 60 to 75 year around. When I take my truck out is is a minimum of 10 miles one way and I drive my truck hard.
__________________
JOHN
  #4
Old 07-27-2008, 05:12 PM
GMC_2002_Dmax's Avatar
GMC_2002_Dmax GMC_2002_Dmax is offline
The Still Master
Default
Unfortunately that stuff is in the heads as well.
I wonder if something can be used to break it up while the engine is running, perhaps some water meth for a while would clean it out ???
__________________
2016 Denali LML----> 2012 Denali LML SOLD
2007 GMC "Classic", LBZ, SLE1 ,RC/LB, 4x4
~Powered By "MOONSHINE"
12.525 at 107.07
2002-GMC Sierra 2500HD SLE/CC/SB/4X4~Powered By "MOONSHINE"
12.65 fuel only, 12.00 on some N20
Retired 04/18/2009...................SOLD 01/2014
  #5
Old 07-27-2008, 05:14 PM
psyco66's Avatar
Default
When I pull my motor for the build it will all be gone. This is why people should block the EGR the day they get there truck.
__________________
JOHN
  #6
Old 07-27-2008, 05:44 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
dang john, thats crazy!
__________________
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.85 @ 145
06 Cummins cc/sb EFI by Hardway.
Tailgate Member #1 I prefer the backdoor
  #7
Old 07-27-2008, 05:54 PM
beach_33's Avatar
beach_33 beach_33 is offline
Default
we foresure need to come up with a way to get this out of the motor while it is running
__________________
Sold:efi live. thank you pat and kat.
68mm cheetah
fleece modded regulator
diamond eye down pipe
bd manifold
airdog 150
custom 5in pipe to 6in powdercoated stack
fleece sc stage 4 . thanks again brayden
team borrowed time member #8
cedarfalls raceway- sep/27/09 12.63@107mph
2016 2500HD z71: all stock except rims and tires
2006 Volkswagen Jetta tdi
  #8
Old 07-27-2008, 05:57 PM
psyco66's Avatar
Default
I am not sure how to get it out of the motor. I cleaned the intake runner in my solvant tank it that crap us hard to get out. I do not think anything will get that crap off out of the runners and the valves whale the engine in together.
__________________
JOHN
  #9
Old 07-27-2008, 06:42 PM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Default
Seen some 6.0 Fords that were completly closed off....whole intake manifolds were pulled and hot tanked to clean them out.
Rediculous people have to deal with this on any diesel.
VW's have been having bad issues with it as well.
  #10
Old 07-27-2008, 06:47 PM
Duramax 6.6L Duramax 6.6L is offline
Diesel Nut
Default
I believe that motor vac makes an intake cleaner ystem that is used to fog the intake system. I have not used personally but I have heard it works well. The cleaning agent is claimed to break up the build up and remove it while the engine is running.
__________________
Burn Rubber - Not Your Soul
2015 GMC Denali Crew Cab Diesel
LML Duramax Vin Specific Tuning Files Available
2012 Dodge Crew Cab Dually Cummins
2011 Silverado HD3500 Crew Cab Diesel
2007 Silverado Classic K3500 Crew Cab Dually
EFI Tuned / Tie Rod Sleeves / Steering & Idler Braces
2-Fast 150 Lift Pumps / 5" Exhaust - Muffler Delete
2006 Silverado Crew cab
2001 Silverado Crew Cab
  #11
Old 07-27-2008, 07:18 PM
NWTDIESEL NWTDIESEL is offline
On a Time Out
Default
Nasty!
  #12
Old 07-27-2008, 07:54 PM
turbo-max's Avatar
turbo-max turbo-max is offline
WaaaZaaaa
Default
Quote:
not that it makes a crap of difference now since the truck is gone, but i blocked mine the day i bought my truck...had maybe 15 miles on it, and already had a light haze of soot...i was amazed!
__________________
Jeff ~turbo-max
Turbo Lag is a courteous head start.
Light travels faster than sound. This is why some people appear bright until you hear them speak.
02 GMC Sierra 2500HD CCSB 2x4 6.0L gas
05 silver-a-do 2500 HD ext cab 4x4 * gone *
96 dodge ram 2500 ext cab 2x4 cummins gone...got the HELL outta dodge
"team salad" and defender of the McRat Universe
to the McSwains
  #13
Old 07-27-2008, 08:02 PM
2wd_Sled_Puller's Avatar
2wd_Sled_Puller 2wd_Sled_Puller is offline
Heavy Equiment mechanic
Default
Mineral spirts?? It may clean it while engine is running.
__________________
KURT
2004 f250 lariet 6.0 egr delete head studs sct
1997 dodge 3500 flat bed. 5x16 injectors airdog 165 valair dual disk
  #14
Old 07-27-2008, 08:30 PM
redws6rocket's Avatar
redws6rocket redws6rocket is offline
Default
mine was blocked at 300 miles for that very reason
__________________
2001 ECSB Built Motor/Trans
Special Thanks Mike Bodine, Danville Performance, Lincoln Diesel, Rick Lance, Precision Converters, MPE, Dan's Diesel
  #15
Old 07-27-2008, 08:37 PM
Fingers's Avatar
Fingers Fingers is offline
Village Idiot
Default
Carb cleaner will cut the soot.
Without the oil from the PCV, the soot does not build up nearly as bad.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
