  #1
Old 09-13-2013, 06:18 PM
smarquis's Avatar
smarquis smarquis is offline
Triple Turbo LBZ
Default Rear Brakes Wear Fast
Does anyone else have a problem with their rear brakes wearing ridiculously fast? I get about 15,000 miles out of mine rear brakes and 50,000 out of my front brakes. Also, when I go to change the pads, the rear rotors are usually cracked from the excessive heat. Even the after market ones I got 80,000 miles ago that were slotted were cracked so badly that the shop refused to put new pads on them. I have after market bigger brakes and rotors on the front that I have only changed once since that time, but i have replaced the rear about 4 or 5 times. I have now resorted to just buying new rotors/pads at Pep Boys because they are really cheap - rotors are only about $35 a piece - but still it is a pain in the rear.
So, obviously, I kind of drive fast (or like a "bat out of hell" to quote my wife). However, I still don't think the rear brakes should wear so quickly. Anyone else have this problem? Any suggestions? I have the motor out to get rebuilt now so it may be a good time to look into the issue.
Thanks!
__________________
2006 Chevy 2500 HD CCSB EPR Triple Turbos with a Cheetah 68, Turbosock, Air Dog II, Snow Performance MPG Max, EFI Live Tuning by Idaho Rob/Trent Nell, magnaflow converter, 4" Exhaust, EPR Stage Transmission with a SunCoast converter, and trans cooler from SunCoast/Mike L, Brake-man larger brakes up front with Brake man rotors/pads in the rear; 4" Cognito Lift with UCAs, heavy duty tie rods, front anti-sway bar, Pitman/Idler Arm Support Kit and steering braces, Zulastic shackles, Atlas Rear springs, air bags, and 285/65R20 BFG A/Ts on 20x9 BMFs.
  #2
Old 09-13-2013, 06:45 PM
Cknight199's Avatar
Cknight199 Cknight199 is offline
Default
Sounds like something is defiantly wrong with your brake system. Can you get the fronts to lock up? Do they all lock up together or rear first?
__________________
"Relentless" 2007 LBZ CC/SB
Plenty of Air and Fuel
Huge thanks to Custom Auto, and Starlite Diesel
  #3
Old 09-13-2013, 07:12 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is online now
Default
How rusted are the sliders?
__________________
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #4
Old 09-16-2013, 10:36 AM
smarquis's Avatar
Triple Turbo LBZ
Default
I can't get any of my brakes to lock (truck has anti-locks).
Rusted sliders may be an issue elsewhere, but not here in Las Vegas. I did find, however, that on my last change, that the slider grease was essentailly fried onto the slider. I guess that is just the excessive heat (and I may have used a cheaper grease without realizing it. Still doesn't change the fact that I have seen at least a couple of rotors spirdercrack does it? Would the heat from a pad that was wearing unevenly be sufficient to do that? Thanks.
__________________
  #5
Old 09-16-2013, 10:42 AM
MACKIN's Avatar
MACKIN MACKIN is offline
Smell My Finger...
Default
It's pretty apparent that the rear brakes are dragging. Isn't there a way to test the ABS system with a TECH II? Thought I seen something like that but not 100%
Friend with a Dodge has the exact same issue but with the front. Never did figure it out
__________________
I have nothing want nothing because what I have cost me to much to have.
01 Big Dually (Gone but not forgotten)
05 Fat-Boy (gets it done)
83 CJ7 (slug but cool)
07 Audi A4 ( I like German Girls they're HOT!!)
LIFES JOURNEY IS NOT TO ARRIVE IN HEAVEN SAFELY IN A WELL PRESERVED BODY,
BUT RATHER TO SKID IN SIDEWAYS,
TOTALLY WORN OUT, SHOUTING,HOLY SHIT WHAT A RIDE!
  #6
Old 09-16-2013, 10:55 AM
Chevy1925's Avatar
Default
Only thing i can think of is sticking calipers but you would notice that when you compress the piston to put new pads in. something isnt letting the rear brakes release pressure after hitting the brakes. whens the last time the system had the brake fluid flushed?
__________________
James
  #7
Old 09-16-2013, 11:25 PM
redrob redrob is offline
Gearhead
Default
Do you tow with a trailer brake controller or not?
  #8
Old 09-17-2013, 01:24 AM
Kappa9012's Avatar
Kappa9012 Kappa9012 is offline
MAN.... I Broke it again.
Default
doing burnouts??? I'd find it hard to believe both rear brakes are dragging together, unless its something upstream, and if it's enough to make the pads wear that fast you shouldn't be able to spin the wheel freely if the ass end was off the ground. Try jacking up the rear and spinning the tires.
could be the ebrake be hung?
__________________
07 Lmm CC/SB
Built ally w/1057
Exergy 60 overs
Dual Cp3's
Billet S480 over stock from Wehrli
The man behind the tuning is Idaho Rob
  #9
Old 09-17-2013, 01:42 AM
lifteddirty's Avatar
lifteddirty lifteddirty is offline
Gearhead
Default
if your master cylinder is bad it could be pushing all of your fluid to the rear brakes, if you feel like bleeding your brakes you good take the lines off of it and see if it sprays evenly.
__________________
superchevy01 lb7 8" lift, ECLB, 37" tires, Warn bumper, 5" exhaust into a single stack, Cold air intake, ported Fuel rail, boost valve, EFI Live DSP2 (MPG and HOLY S***), insight CTS, Fabtech tierods, cognito solid centerlink, pitman and idler arm braces
Future mods: Trans, Twins, 800+ horsepower......
  #10
Old 09-17-2013, 03:57 AM
jlawles2 jlawles2 is offline
Default
It sounds like your master cylinder is not releasing completely. Both front and rear. I have 160k on one truck (not a lot of trailer pulling) and 120K on my other both on original brakes and both still look new.
You could also have water in the master cylinder which is causing issues during and after braking.
__________________
Silver Birch Metallic 2004.5 GMC K2500HD with 265/75's
Banks super scoop, tubing, intercooler, and cat back with the IQ on the Window (for now). BD driver side Exhaust manifold.
Airdog 150 on frame rail. Amsoil synthetics for lubrication, and dual Amsoil filters on the driver frame rail. PPE centrifuge install.
EGR blocked. PCV rerouted. Resonator blocked (reinstalled for looks). Bladerunner installed. Dead kitty by MBRP (front pipe) and down tube replaced with the MBRP (heat wrapped from the turbo down to the front pipe).
Performax Gauges by ISSPRO in pod over mirror and overhead console (console pod by PPE). Mike L Transmission.
----Looking to do an onboard air with a set of truck air horns. Want Nathan K5LA's but not in the budget at the moment.----
06 GMC CCSB 2WD LBZ SLT package. Traded for '17 Denali
18 Denali CCSB 2500 4WD Mineral Metallic with Cocoa/Dark Sand Interior
  #11
Old 09-17-2013, 06:06 AM
Cknight199's Avatar
Default
The e brake doesn't utilize the same surface as the brake pads. Instead of using the rotor it uses the inside of the rotor, similar to a drum brake. If it was hung it wouldn't be noticeable because you would go through the e brake pads in a very short time. I don't believe he is changing e brake pads just normal pads.
__________________
  #12
Old 09-17-2013, 09:22 AM
MACKIN's Avatar
Smell My Finger...
Default
I've seen OLD rubber brake lines cause the caliper to drag but IF you're developing that kind of heat to crack rotors as you describe I'd say the ABS is malfunctioning and holding pressure somehow in the rear. I'd run some ABS system checks.
__________________
  #13
Old 09-17-2013, 09:30 AM
Chevy1925's Avatar
Default
Quote:
this is what im thinking but ive seen a brake fluid flush clean issues like this up.
__________________
James
  #14
Old 09-17-2013, 09:37 AM
Kappa9012's Avatar
Default
Quote:
good to know
__________________
07 Lmm CC/SB
Built ally w/1057
Exergy 60 overs
Dual Cp3's
  #15
Old 09-18-2013, 11:35 AM
smarquis's Avatar
Triple Turbo LBZ
Default
Quote:
Something like this is what I have essentially thought all along. Truck always seemed to stop pretty well, but as I said before I have the bigger brakes on the front so that may have compensated somewhat for not getting sufficient pressure to the front calipers?
I flushed the brake fluid about 1-2 years ago, and it did make a big difference on pedal feel, but I don't think it made any difference on wear.
Thanks to everyone for their suggestions. They are appreciated!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
