  #1
Old 06-08-2013, 06:38 PM
dracing70's Avatar
dracing70 dracing70 is offline
SH--- GETTING EXPENSIVE!
Default allison fluid leak
So one of my allison trannys is leaking from the shifter linkage. what is the process for fixing this? and how involved is it? or would stop leak prolong the issue.
__________________
Special thanks to Mark, Larry and everyone at Danville.
2004.5 lly 2500 chevy 4x4 very big Danville turbo, efi live, carrillo rods, so cal pistons ,arp studs ,brodix heads . Hsp manifolds and custom intake along with a DR Tuning custom stainless remote mount,very very very very very large exergy sticks,twin modded cp3 pumps. Tranny is obviously built with billet shafts in house by DR Tuning. Plus many other goodies!
also have a 2003 lb7 crew cab dually dark green mostly stock with stage five suncoast, full cognito front suspension semi 10 lug wheel kit with 19.5 alcoa's and s b intake
  #2
Old 06-08-2013, 07:07 PM
03_DMAX's Avatar
03_DMAX 03_DMAX is offline
Default
There is a seal around the shaft behind the nsbu switch.
  #3
Old 06-08-2013, 07:32 PM
slipclutchms's Avatar
slipclutchms slipclutchms is offline
Default
It's not bad to do. Remove the nsbu switch (also pull the front driveshaft ) then drill maybe a 1/8" hole or smaller into the seal. Then take a 90 degree pick and "dig it out". After that use a socket that fits nicely to tap the new seal in.
__________________
2003 GMC CCSB 2wd ZF6 LLY
  #4
Old 06-08-2013, 07:41 PM
Mike L.'s Avatar
Mike L. Mike L. is online now
Default
KD has a tool for this and it is much safer than drilling and prying. Seal is the same as a turbo 350, 400, 700, 4L60E, and 4L80E.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #5
Old 06-08-2013, 08:38 PM
dracing70's Avatar
Default
good to know thanks. ill check out the tool
__________________
  #6
Old 06-08-2013, 09:33 PM
OregonDMAX's Avatar
OregonDMAX OregonDMAX is offline
NOT IN OREGON
Default
Quote:
and that is what i love most about GM, just about everything is interchangeable.
cant tell you how many small blocks iv'e put together not even knowing what CID the parts came out of.
__________________
Sean
02 CCSB
Moonshine tunes, Mike L trans
Mike L secret squirrel converter
Exergy Sportsman, 4/6 drop, LML 20's/420's
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
