  #1
Old 06-07-2013, 07:51 PM
ceide4489 ceide4489 is offline
Gearhead
Default H&S Tuner on my 2013 Duramax
Finally got my tuner installed today. Started truck and first thing coing up is that Im out of DEF (installed without the DPF delete). Quick phone call to H&S solves problem with a file sent to me, but after the new file is installed now the cruise works intermittently and will just drop off after 10-20 miles. I installed without removing speed limiter as it told me if I use my cruise wouldnt work but it doesn't work anyways correctly.
Did a fuel mileage run on a 30mile trip that I do 3-4 times a week so have a pretty good indication of what it used to be. Driving 60 miles an hour and using cruise when I can and reset mileage in truck (which has been very close everytime I checked it so far). Looks like at HWY speed Im losing 2-3miles per gallon of fuel economy when driving as nice as possible, I can imagine how much I would lose if pushing it hard.
Was a little disappointed n this as I thought driving nice I should keep the fuel economy the same or slightly better.
Lastly I noticed there is no where to change settings for metric to imperial measurements. While I realize this isnt a big deal but Im in Canada and young enough that I don't know Fahrenheit and miles per hour.
As of now I have uninstalled the tuner and am quite disapponted in it.
My final question is has anybody used this to run the DPF delete tune yet and can anyone verify the fuel mileage gains of 3-8 miles per gallon I have read about. I bought this tuner hoping to get a small amount of power and decent fuel economy and not sure Im going to get it now.
Any feedback would be appreciated
  #2
Old 06-09-2013, 09:51 PM
8100 Power 8100 Power is offline
FNG
Default
I'm running one with the DPF removed. I can't say my mileage has helped because I removed the DPF about the same time as I installed my lift. My personal opinion you'll see maybe a 2 MPG max gain.
__________________
Jeff
SOLD
06 LBZ
11 LML
  #3
Old 06-10-2013, 06:22 AM
FC5452's Avatar
FC5452 FC5452 is offline
Default
Mileages on these seem all dependent on how hard the truck is being worked. prior to dumping everything I was seeing about 10 around town and 12-13 on the hwy, towing was the same at 10 with 10K tied to her. Afterwords it went up 2-3 mpg on both city/Hwy driving.
I kind of stopped tracking it now, except on long hauls so I can get a feel for fuel costs when making plans. Funny thing about mine is after a weekend down the track the mileage actually increases by 5-6 then settles back down. Still wont complain, it is a truck and all
__________________
LML- With some Stuff added
  #4
Old 06-10-2013, 07:54 AM
FNG
Default
Exactly.. that's why I daily drive my jetta.
__________________
Jeff
SOLD
06 LBZ
11 LML
  #5
Old 06-10-2013, 08:34 AM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Default
From what I have read and heard about the Urea set up actually helps the mileage of the lmls. Lost that dpf and you will notice a good gain.
__________________
2006 ccsb Lbz Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples
  #6
Old 06-14-2013, 11:31 PM
Gearhead
Default
Well the delete is done and have done several mileage test on the same commute as before.
The computer in truck has gone up from reading 17.5mpg to 22mpg. Unfortunately when you calculate it by hand getting about 18-19. So while there was a small gain it was not substantial. Looks like the computer tuning has made it look like your getting better to fool people.
Some minor issues still unresolved but truck is running good. Will do a few more checks over the next few weeks and keep you all updated
  #7
Old 06-15-2013, 07:12 AM
Ne-max's Avatar
I like turtles
Default
Did you hand calculate it stock?
__________________
2006 rclb 6.6
  #8
Old 06-16-2013, 03:59 PM
Gearhead
Default
Quote:
Yes I did a few times and was almost always exactly what truck said.
It used to be exact on amount of liters used for fuel and now its always out a couple
  #9
Old 06-23-2013, 07:05 PM
CDR CDR is offline
Gearhead
Default
HAND CALCULATED I observed 2miles more to the gallon with im very satisfied with. It all depends on what sort of driving you do with the DPF installed if you idle alot it regens alot and burns tons of fuel. If you drive hard tow huge loads on the highway you might notice no difference. But you will never notice worse unless you driving it hard
__________________
Happy owner of a 2003 Chevy 2500HD 4x4!
SOLD
Now the even more happy owner of a 2008 LTZ!
MBRP 4"
EFI LIVE
  #10
Old 06-23-2013, 08:27 PM
DIESELMAFIAPER.LB7's Avatar
DIESELMAFIAPER.LB7 DIESELMAFIAPER.LB7 is offline
<----twinz
Default
install the delete tune you'll get power and mpg, dpf present gets you more power but mpg is not really there as far as the issues i havent had any issues but they will get you set up right.
__________________
2003 GMC CC/SB: billet 66/83mm compounds, dual pumps, exergy injectors, built trans (by me) tune 3 11.61 @ 119 !!
2012 mega cab 6.7: Tuned and deleted (reliable) sold! (should have kept it)
2016 CCSB custom sport lml ltz deleted with sotf tunes by me
  #11
Old 06-24-2013, 01:16 AM
Gearhead
Default
I have tried the 0-60 times as well prior to doing the delete and afetr the delete both on the street setting and almost exact times.
7.7 secs 0-60 and 15.1 @ 90MPH for 1/4 is best I seen with delete kit done. Was now thinking about doing EGR delete as well but know very little about this
  #12
Old 06-24-2013, 06:59 AM
<----twinz
Default
So did you have the egr probe on for both runs? I can guarantee it ran cooler and "should" have run a tick faster put a Fass pump on it as well that help power and mpg try the hot tune as well
The egr delete is a good mod also doing a new downpipe helps alot in response and egts
__________________
  #13
Old 06-25-2013, 10:56 AM
Gearhead
Default
I was told the downpipe upgrade wasnt offered from flo-pro when I ordered the exhaust but have changed from down pipe back.
I dont have an EGR probe as Iwas getting the temp from the truck before the elete but after the delete this no longer works, so need a probe installed. Im haveing trouble finding any info on the EGR delete for the 2013 trucks.
  #14
Old 06-25-2013, 11:07 AM
FC5452's Avatar
Default
Shoot me a pm might be able to help you out in the egr dilemma as far as monitoring egt's after a delete. Your basically stuck adding a probe in the manifold or Replace the the DP with a diamond eye which gives you a post egt port.
__________________
  #15
Old 06-25-2013, 11:27 AM
AubleAK's Avatar
AubleAK AubleAK is offline
Default
Can you delete the emissions with an h&s and leave the truck at stock power? If so if do that and put a power puck on it.. I saw 2-3 mpg better then stock mpg with mine.
__________________
2001 Chevy Ext. Cab Short Bed
EFI Live by SS Diesel Tuning -
thanks Steve!
LBZ rods, ARP Head Studs, 475 over stock twins
4 Inch Turbo Back Straight Pipe
3 inch Downpipe
20" XD Monsters
Suncoast Gmax and Precision ML Converter - Built By Me
Airdog 165
Died 9/13/12 - broken valve
Born Again 12/16/12
Died again 1/9/13
2011 GMC Sierra SLT LML
stock- and staying that way
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
