  #1
Old 04-30-2013, 05:54 PM
minime88's Avatar
minime88 minime88 is offline
FNG
Default installing rear main seal
Do I need an installer tool for installing a rear main seal on a lb7? Also do I need to replace the flywheel bolts with new ones?
__________________
03 lb7
Moonshine!
Suncoast stg v w/1056
Fass(soon to be matusa)
5in single stack
1, 2, or 3 turbos???
Etc....
Everything done by me
  #2
Old 04-30-2013, 06:18 PM
dirty_max's Avatar
dirty_max dirty_max is offline
Default
it is best to use the install tool, merchant automotive sells one. you can also pick up new flywheel bolts from there. i would replace them since they are a torque to yield bolt
__________________
2004 chevy lly with a handshaker
Originally Posted by coker6303
My trucks not a whore...she doesn't lift her skirt for just anyone!
But she is a prostitute...she will do anything for money
  #3
Old 04-30-2013, 06:30 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
Yes and no.
__________________
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.72 @ 150.
06 Cummins cc/sb EFI by Hardway.
Tailgate Member #1 I prefer the backdoor
  #4
Old 04-30-2013, 06:42 PM
minime88's Avatar
FNG
Default
Ok well thanks to both of yall. I'm gonna see if I can make an installer tool then...
__________________
03 lb7
Moonshine!
5in single stack
Etc....
  #5
Old 04-30-2013, 07:03 PM
MAXX IT OUT's Avatar
MAXX IT OUT MAXX IT OUT is offline
<<<IT WORKS
Default
Some one was saying that you could use a hammer and tap them in? Amy insight one this?
__________________
2001 2500HD Red on Black.
ATS Dual CP3, 4 inchIntake and S366, ARP 625 head studs and main studs, LBZ Rods, Delipped pistons, Hamilton valve Spring, 30 over injectors, 5in Turbo Back exhaust, ATS Transmission, Fass 150, and Running on Moonshine.
DIED AND NOW HAS BEEN RAISE FROM THE DEAD
1971 C10 Restoration/ProTouring Project, Hoping for a Dmax
  #6
Old 04-30-2013, 07:05 PM
x MadMAX DIESEL's Avatar
x MadMAX DIESEL x MadMAX DIESEL is offline
<<<< No Horsepower
Default
I tapped mine in with a mallet, as I have before on any other engine. Just oil the outside and work around it and you'll be fine.
Sent from my PC36100 using Tapatalk 2
__________________
Ben
LBZ Stock Charger
12.26@108.8
7.78@87.7
2.5 puller in the Mecca!!
Manual Mafia
Quote:
Originally Posted by BgBlDodge View Post
Al gore invented driving the turbo.
  #7
Old 04-30-2013, 07:11 PM
minime88's Avatar
FNG
Default
Well that saves me from doing more work then necessary. I just wake to ensure for no leaks.
__________________
03 lb7
Moonshine!
5in single stack
Etc....
  #8
Old 04-30-2013, 07:17 PM
blk smoke lb7's Avatar
blk smoke lb7 blk smoke lb7 is offline
<-----Lots of green $
Default
If its wrong your going to kick your self,If you want to paypal me a deposit for the tool ill send you mine to help outyou will have to pay the shipping both ways.
__________________
04 LB7 CC/SB EFI live, S366,S483 , Born again 08/10/2011 11.64@117
Some wicked tuning by Bo-Bo (Bob olson) Thx Bob
Quote:
Originally Posted by flyinelvis11
i'll let you use anything i got except my wife and my truck; it's too easy to throw a rod in either one):h
Quote: Carter 44
Boost is like a hot girl with an STD...you know you want to hit it but your afraid of the consequences
rollncoal07:Twining is wining
Quote:
Originally Posted by McRat View Post
You come off as a Timeshare Condo salesman on this site.
If you were helping folk with problems, or asking for input on your problems, it might be different, but from where I see, you are only a little different than the Russian spammers selling iPads that we delete.
Act like more of a human, and less like a spambot, and you'd probably catch less heat. This is "family", and it's our corner bar, and a group of guys with grease all over them leaning over fenders of somebodies truck that ain't making the right boost.
It's also one of few sites with more hardcore wrenches and racers than wannabees.
You're welcome to be a member here, and post about your build, but don't expect people to shower you with roses yet. That comes with seat time on the site, and on the track.
  #9
Old 04-30-2013, 07:54 PM
elliottw's Avatar
elliottw elliottw is offline
Default
I f*****g hate rear main seals and all they stand for!! sorry had to get that out there, just really annoying job haha
__________________
2009 LMM- DSP5 by ATP, supporting mods SOLD
2005 LLY- DSP5, built tranny, supporting mods SOLD
2007 LBZ- Moonshine DSP5, supporting mods
  #10
Old 04-30-2013, 08:00 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Default
Replace the bolts. They are like you factory head bolts. Good for one use only. Go with oem gm or get arps
__________________
2006 ccsb Lbz Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples
  #11
Old 04-30-2013, 08:27 PM
<<<< No Horsepower
Default
I think I got the gold ones from the Allison dealer.
__________________
Ben
LBZ Stock Charger
12.26@108.8
7.78@87.7
Manual Mafia
  #12
Old 04-30-2013, 08:38 PM
<<<IT WORKS
Default
What if the bolts are after market? I have an ATS flex plate, are those reusable.
__________________
  #13
Old 04-30-2013, 11:04 PM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
Use the friggin installer tool! Are you guy's nuts? Its to much work to go back and fix it... If Scott is willing to loan you the installer, do it! Way to be a stand up guy Scott
__________________
04.5 CCSB ole blue, built trans, mpi twins
03 Reg Cab ZF 6
05 CCSB ole crappy, built eng, built trans, mpi twins
  #14
Old 04-30-2013, 11:47 PM
AubleAK's Avatar
AubleAK AubleAK is offline
Default
Quote:
X2.. Do it once and done. Using the installer it takes 30 seconds. Not worth f-ing 2 minutes of work for 6 hours of possible replacement down the road
__________________
2001 Chevy Ext. Cab Short Bed
EFI Live by SS Diesel Tuning -
thanks Steve!
LBZ rods, ARP Head Studs, 475 over stock twins
4 Inch Turbo Back Straight Pipe
3 inch Downpipe
20" XD Monsters
Suncoast Gmax and Precision ML Converter - Built By Me
Airdog 165
Died 9/13/12 - broken valve
Born Again 12/16/12
Died again 1/9/13
2011 GMC Sierra SLT LML
stock- and staying that way
  #15
Old 05-01-2013, 06:42 AM
dansdieselp's Avatar
dansdieselp dansdieselp is offline
Diesel Tuner
Default
X2 on using the install tool. I have a few DIY customers that tried the hammer and 2x4 or punch. They almost always leak and we've had to fix them. Seal ain't cheap either so use the tool and do it right.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
