  #1
Old 02-12-2013, 03:37 PM
durallymax's Avatar
durallymax durallymax is offline
Default Low Oil Pressure
Searching doesn't do much as it just leads you to injector threads.
The crankcase was not overfull and did not smell of diesel at all. Blowby seemed kinda high. I could actually smell it when unhooking the plow, no hint of fuel in it though.
Lately the oil pressure was getting lower and lower like when injectors fail. Warning started coming on. So i just changed it now. On first start it went to 70. Well see what happens over the next few days.
Should I be suspecting the oil pressure switch next?
__________________
Wife:2010 Jetta TDI "Cup Edition" Thunderbunny. Stg 2 Malone, Rawtek Straightpipe
Me:2000 Jetta TDI/5spd VNT-17, DXD S2 Clutch
Sis:2006 Jetta TDI/DSG
Puller:2003 LB7 GMC
Toy:1973 Kenworth W923
Farm:02,11,13 Duramax/Allisons
  #2
Old 02-12-2013, 04:32 PM
BlkMax's Avatar
BlkMax BlkMax is offline
Default
Without starting the oil battle......
What worked for low oil pressure at idle and operating temps was to change to Rotella T full synthetic. I got rid of the dino oil and used the synthetic. I'm sure any synthetic would have been better than the dino penzoil the dealer was putting in. At the time I had the "free" oil change deal....I never set off the light, but it was REALLY close.
I also do not have an auxiliary oil cooler in either truck. Keep in mind I live in Alaska, and my ambient temps are typically lower that what other see.... summer or winter.
__________________
Black Max....
Black Max, the fun truck:
'03 2500 4x4 CC/LB
Bent Rods, now under construction, its time to put all the saved up parts in....
Special thanks to Pat & Kat McSwain, MikeL, Guy, Trent, and others from here-thank you for the great ideas!
EPR triples
Emma, my DD:
'04 2500 4x4 EC/SB
HTT T4 366 74 .91, 65% SAC's from LDS, Trans Kit from Evan, tunes by Zach at Starlite
  #3
Old 02-12-2013, 04:41 PM
delong_1's Avatar
delong_1 delong_1 is offline
<< my work
Default
why not take 5 min and put a mech. gauge on it and know what the pressure actually is?
__________________
2012 ccsb: ATS compounds, built trans, copilot, ATS twin pump kit, fass 150, etc
2001 ecsb: sold
1016. 10-15-11
7.13@100
11.27@105
  #4
Old 02-12-2013, 04:50 PM
baggedLB7's Avatar
baggedLB7 baggedLB7 is offline
Goer
Default
I think the steper motor is going out on mine . The other day I looked up and it was on zero just parked but my insight was reading 22 psi but when I started it up the next time the gauge was fine. But it has been reading funny here and there since.
But I have not had a warning come up for mine though.
__________________
TIM
2004 LB7 CCLB, 4" Straight Pipe, Edge Insight, AirDog 165, EFI, StagelV Trans, Twins.
Trans and Twins by EPR
  #5
Old 02-12-2013, 05:34 PM
WVRigrat05's Avatar
WVRigrat05 WVRigrat05 is offline
Wound for sound
Default
Mine would go to zero too, I got scared at first but the motor sounded the same so I hammered down, got home and did a flush and went to synthetic oil, oil psi was good to go til the motor went last winter. I have an LB7 bottom end now and noticed the sending unit or oil pump shows/has a little lower pressure than the LLY did
__________________
Reger
05' Black Chevy CC/SB LT- Blackout Performance built motor/trans/tuning- Gone
The Blessed Hellride- 08' White GMC Sierra SLT CC/SB,
100k miles-FOR SALE/Waiting on a new motor
Wife's ride- 2016 Pearl white Legacy limited 3.6R
Rig ride/new DD-02' Black Eddie Bauer explorer 4.6, -180k, still sporting original trans, outlasted two Duramaxs.
  #6
Old 02-12-2013, 06:31 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Quote:
Yep...have to do this first before anything else.
__________________
Tom
"BBT" 2003 GMC CC/SB 4x4
12.14@111.15
"Flyin' Brick" 1999 Chevy 1500 RC/SB 2wd -- in progress
2014 Chevy Cruze Diesel -- the DD
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
From mufflerguy on yb,
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!"
  #7
Old 02-12-2013, 10:29 PM
durallymax's Avatar
Default
Quote:
That would be the next step if nothing changes. Just curious what other issues people have seen.
I doubt we'd have issues with one duramax out of the entire fleet, if it was the oil. Could be wrong though.
__________________
Puller:2003 LB7 GMC
  #8
Old 02-13-2013, 02:46 AM
motoking_1990's Avatar
motoking_1990 motoking_1990 is offline
Default
^^^^ what's with the sig bahahaha forgot performance fuel pin
__________________
2014 Chevrolet Cruze 2.0TD Loaded- Stock
2002 LB7 ec/sb
AFE Stage-2 Intake, mbrp intercooler pipes, PPE Boost Valve, EFI Live by duramaxtuner, p&p ihi w/wetzel wheel, bigger style intake horn, gmax 5 with precision tq, 5" MBRP Exhaust,beans sump, fass lift pump, 40% sticks, DP modded lbz cp3, Fuel Maverick w/ Nitto 420S
More fast stuff to come
GO FAST OR GET PASSED
  #9
Old 10-30-2013, 08:43 AM
durallymax's Avatar
Default
Well the truck has pressure, two sending units have been tried and I replaced the ECM.
The truck now has issues communicating with the FICM and died the other day. Massaged the harness and it runs now. I'm dreading this.
I'll be cleaning the block grounds and inspecting the harness closer but I didn't see any immediate obvious issues.
Should I just replace the wiring harness with the extra one I have? Almost tempted to get it reading oil pressure and sell it. 200k on it and its tired. Our 2002 is dying too, lots of issues here and there and I think its just tired too. The LML is nearly at 90k with no issues and they are offering killer deals on new ones right now so I think we are going to go buy another LML and buy some cheap used half tons for running around because they are cheaper to fix.
__________________
Puller:2003 LB7 GMC
  #10
Old 10-30-2013, 08:56 AM
blk smoke lb7's Avatar
blk smoke lb7 blk smoke lb7 is offline
<-----Lots of green $
Default
Mine was low after the rebuild I switched to 20w 50 syn and run it like I stole it.Its still a little low but thats how it is.I installed a new lbz oil pump tried the manual gauge its just on the lower side and thats the way it is for mine.
__________________
04 LB7 CC/SB EFI live, S366,S483 , Born again 08/10/2011 11.64@117
Some wicked tuning by Bo-Bo (Bob olson) Thx Bob
Quote:
Originally Posted by flyinelvis11
i'll let you use anything i got except my wife and my truck; it's too easy to throw a rod in either one):h
Quote: Carter 44
Boost is like a hot girl with an STD...you know you want to hit it but your afraid of the consequences
rollncoal07:Twining is wining
Quote:
Originally Posted by McRat View Post
You come off as a Timeshare Condo salesman on this site.
If you were helping folk with problems, or asking for input on your problems, it might be different, but from where I see, you are only a little different than the Russian spammers selling iPads that we delete.
Act like more of a human, and less like a spambot, and you'd probably catch less heat. This is "family", and it's our corner bar, and a group of guys with grease all over them leaning over fenders of somebodies truck that ain't making the right boost.
It's also one of few sites with more hardcore wrenches and racers than wannabees.
You're welcome to be a member here, and post about your build, but don't expect people to shower you with roses yet. That comes with seat time on the site, and on the track.
  #11
Old 10-30-2013, 10:34 AM
durallymax's Avatar
Default
This one reads 0. We smashed the dinger for the time being.
__________________
Puller:2003 LB7 GMC
  #12
Old 10-30-2013, 11:07 AM
Dallas S Dallas S is offline
Default
My lmm read low one day. Message and ding would pop up for split second at a time. Later that day the crank snapped.
__________________
2006 SLT cc/sb LBZ/Allison/np273c D60 SAS 40x15.5r22
2006 LT RC/SB LBZ 4x4
1980 k1500 lq4/4l80/np205 39.5's on a d44
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
