  #1
Old 02-12-2013, 03:08 PM
Bustedknuckles's Avatar
Bustedknuckles Bustedknuckles is offline
Honey Badger
Default Redhead steering box.
Anyone have any experience? My steering is pretty sloppy and everything else is good so im thinking of replacing the steering box. A buddy of mine just put a redhead steering box on his cummins and he said there is a night and day difference, he wishes he would have done it when he bought the truck....
__________________
04 lb7: 06 front clip, EPR s366, 30% over injectors, ARP head studs, Idaho-Rob tunes, airdog, PPE trans, Precision ML converter, etc......
  #2
Old 02-12-2013, 04:08 PM
blitzin247's Avatar
blitzin247 blitzin247 is offline
That didn't sound good...
Default
Mine is terrible too, but I'm
Redoing control arms, pitman arm idler arm, and I'm
Just gonna rebuild my factory box...it's leaking terribly, then I will adjust it so it's as good as new, then if I'm still no pleased I'm gonna get the redhead, however instill plan on upgrading my stabilizer with a blistein too. There is a lot going on down there!
__________________
Purchased 11/15/12: Totaled 7/24/14 2004 LB7 CCSB, ATS 4000 turbo, upgraded injectors,complete moog front end, Blistein 5100's, H2'S on 265/70/17 Michelin's Diamond Eye 4 inch turbo back exhaust.
Saving up for a LMM or LML (Lordwilling within a year)
Special thanks to: Brent@LDS, mrmanners@Synthetic Motorsports, and Kory Willis@PPEI.
Jesus loves YOU, Have you asked Him to be your Savior yet?
  #3
Old 02-12-2013, 04:31 PM
dmaxman06's Avatar
dmaxman06 dmaxman06 is offline
Default
where do they sell this steering box would like to look at it my lb7 needs one bad
__________________
06 lbz ccsb
01 lb7 rclb
  #4
Old 02-12-2013, 05:26 PM
05LLY duramax's Avatar
05LLY duramax 05LLY duramax is offline
boostin
Default
www.redheadsteeringgears.com
I been looking into 1 of these for my truck. I have replaced everything in the front end that i possibly could and my steering is still sloppy. It gets kinda scary sometimes because my truck is lifted and it wanders a lot. Has anyone put one of these on a duramax?
__________________
05 LLY
EFI LIVE by nick @ duramax tuner
Cognito 10-12 lift
Custom side exit exhaust
FOX 2.O SHOCKS
KATZKIN custom ostrich interior n door panels
22 inch MAZZI HULKS on 37 inch nittos
Yukon 4.56 gears
Merchant motor mounts
Merchant pump rub kit
Bills custom 4.5 intake and LBZ MP
WEHRLI CUSTOM FAB trussed rear end
WEHRLI CUSTOM FAB ladder traction bars
  #5
Old 02-13-2013, 07:29 AM
Honey Badger
Default
Get one and let us know! You can be the guinea pig.
__________________
  #6
Old 02-13-2013, 09:30 AM
JMK777's Avatar
JMK777 JMK777 is offline
16's, but i keep em clean
Default
I like the quick ratio option
__________________
2001 lb7, suncoast IV-1057 by Inglewood, JMK hidden traction bars and bump stop relocate kit, JMK S/S tie rod sleeves,QA1's, modded waste gate, EFI live ,JMK stinger exhaust, Aeromotive tsunami fuel pump , stock charger 12.71 @ 107mph
2005 lly ccsb 4x4 white all stock with a small tune.soo fresh and soo clean clean
2002 lb7 ecsb 4x4 white needs injectors and fix trans
sheet metal workers local 104
  #7
Old 02-13-2013, 09:34 AM
juddski88's Avatar
juddski88 juddski88 is offline
Freedom Diesel
Default
I think Schulte might've ordered one. I have one to send them too, but have been procrastinating as usual
__________________
2001 Chevy 2500HD ECSB
"Sore Subject" - Still don't have time for it.
I would never have learned what I have without George Alexander, Mike Lovrich, David Browning, Matt Handwork, Ben Tyler, Evan Drosehn and countless members of this forum and others.
Thank you.
2014 Jeep Grand Cherokee Limited, Ecodiesel
  #8
Old 02-13-2013, 10:15 AM
boostin
Default
Quote:
Ok ill be test mule for it.
__________________
05 LLY
Cognito 10-12 lift
FOX 2.O SHOCKS
Yukon 4.56 gears
  #9
Old 02-13-2013, 10:43 AM
WVRigrat05's Avatar
WVRigrat05 WVRigrat05 is offline
Wound for sound
Default
I've heard mixed reviews on them, almost bought one when I did my truck, but didn't want to be the guinea pig, anytime my others got sloppy I changed em til I learned they're adjustable
__________________
Reger
05' Black Chevy CC/SB LT- Blackout Performance built motor/trans/tuning- Gone
The Blessed Hellride- 08' White GMC Sierra SLT CC/SB,
100k miles-FOR SALE/Waiting on a new motor
Wife's ride- 2016 Pearl white Legacy limited 3.6R
Rig ride/new DD-02' Black Eddie Bauer explorer 4.6, -180k, still sporting original trans, outlasted two Duramaxs.
  #10
Old 02-13-2013, 10:48 AM
boostin
Default
Quote:
The factory box is adjustable??
__________________
05 LLY
Cognito 10-12 lift
FOX 2.O SHOCKS
Yukon 4.56 gears
  #11
Old 02-13-2013, 11:38 AM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
To a certain extent yes
__________________
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.85 @ 145
06 Cummins cc/sb EFI by Hardway.
Tailgate Member #1 I prefer the backdoor
  #12
Old 02-13-2013, 12:03 PM
HDdave's Avatar
HDdave HDdave is offline
Default
Yep ^ not many people know that..
I was thinking about one of the boxes too but idk.. Ive got 30k on my suspension setup so its time for a revamp.. Well see I guess.
__________________
08 lmm.. Its white and I dont care
  #13
Old 02-13-2013, 12:15 PM
WVRigrat05's Avatar
Wound for sound
Default
Yep, there's a allen screw on top of the box, I forget the specs for sure, ill look in my gm service manual
__________________
Reger
  #14
Old 02-13-2013, 12:29 PM
THEFERMANATOR's Avatar
THEFERMANATOR THEFERMANATOR is offline
LEGALLY INSANE
Default
The screw in top is for the sector shaft adjustment, and isn't the one that normally needs adjusting. Overtightening it will break the preload spring inside the box and make the steering VERY stiff. The input shaft adjustment is more important, but takes alot more work to do. i did a write up on how to adjust steering boxes on tts.
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, little of this, a little of that,
DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, custom tuning by me, KENNEDY single pump and pump rub kit.
  #15
Old 02-13-2013, 12:38 PM
duratothemax's Avatar
duratothemax duratothemax is offline
<--- slippery roads
Default
Unless you know what you are doing and have messed around with Saginaw recirc-ball steering boxes before.....leave the adjustment screw alone!!! Its super easy to go too far and not only destroy your steering box, but make the truck really sketchy to drive.......
__________________
2012 Denali - R&D testbed for upcoming new products.....
2005 Silverado LT - Blown up/broken too many engines and parts to care about making it fast anymore, so its back to mostly stock - The best names in the industry for parts/advice/help...MikeL.Guy-SoCal.Rob-ATP.Evan-Limitless.McRat.BigDipper.Bobo.Tony-RRDP.Fingers.Eric-MA.EFILive...
BT DieselWorks, LLC - EFILive tuning - Duramax/Allison/gasser STANDALONE HARNESSES - Allison lockup controllers - Allison tapshift kits - Digital DSP-5 switches - full assortment of great electronic improvements and gadgets for your GM truck/SUV
All products available for sale through our online store at www.btdieselworks.com
Be sure to "like" us on Facebook at www.facebook.com/BTDWorks
Be sure to "follow" us on Instagram @btdieselworks
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
