  #1
Old 01-26-2013, 07:32 PM
ljackson2644 ljackson2644 is offline
Gearhead
Default Any Alaska members on here?
It anyone where temp drops below 0. Looking for some advice. I bought a 2004 GMC with the LB7. Having trouble starting it when temps dip below 0. For a block heater just don't really have a good place to plug her in. Any other stuff I can do as far as fuel additive or either?
  #2
Old 01-26-2013, 08:09 PM
workin' diesel workin' diesel is offline
factory tuned
Default
Plugging it in is your best bet. I do not have a good place to plug it either, but the other night i hooked all my extension cords together and ran it across the alley to where I have my truck parked and let it sit all night. HUGE difference. it was 5* and it started like it was 50*!
  #3
Old 01-26-2013, 09:06 PM
AKlowriderZ71's Avatar
AKlowriderZ71 AKlowriderZ71 is offline
Default
Yeah, there's a few of us on here. What part of AK are you in?
If everything on your truck is in good working order, and you're running winter blend fuel with an anti-gel additive like Stanadyne or Power Service, you shouldn't be having any problems starting up around 0 degrees.
I remember a GM training video about the Duramax before they were sent to the dealerships. GM required that the engine would start at -15F without use of the block heater, and without using the glow plugs. Both of the LB7's that I've owned started well just like that.
__________________
2001 ECSB 4x4 2500HD, LB7, Stock Allison, Edge CTS Insight w/backup cam, EFI Live tuned by SS Diesel Tuning(thanks Steve!), 4" exhaust.
2001 ECSB 4x4 1500, Blown 5.3 liter. -Sold & Gone-http://youtu.be/ZM2m1bKC1JY
  #4
Old 01-26-2013, 09:38 PM
AubleAK's Avatar
AubleAK AubleAK is offline
Default
make sure all of your glow plug heaters are working and batteries are in good condition. shouldnt have a problem starting.
__________________
2001 Chevy Ext. Cab Short Bed
EFI Live by SS Diesel Tuning -
thanks Steve!
LBZ rods, ARP Head Studs, 475 over stock twins
4 Inch Turbo Back Straight Pipe
3 inch Downpipe
20" XD Monsters
Suncoast Gmax and Precision ML Converter - Built By Me
Airdog 165
Died 9/13/12 - broken valve
Born Again 12/16/12
Died again 1/9/13
2011 GMC Sierra SLT LML
stock- and staying that way
  #5
Old 01-26-2013, 09:40 PM
Default
Weak injectors or weak injector pump could be a problem too.
__________________
  #6
Old 01-26-2013, 09:53 PM
AubleAK's Avatar
Does the truck start well at warmer temperatures?
__________________
thanks Steve!
3 inch Downpipe
20" XD Monsters
Airdog 165
Born Again 12/16/12
Died again 1/9/13
  #7
Old 01-26-2013, 11:41 PM
killian44p's Avatar
killian44p killian44p is offline
Earth Roamer
Default
My problem is the actual flippin computer freezing up affects the stereo as well. When the radio comes on I know she's warmed up. Northern NV. has had some cold weather that seems to finally be moving off. This may sound crazy but I was doing some work in CO. a long long time ago and I noticed that people in Denver would cover there cars with a blanket or even put in a couple strips of house insulation on the engine and then close up the hood. I'd watch them in the mornings uncovering and pulling insulation out and start there vehicles right up. I've done the same here and well I had to use one of those electric blanket snuggies on the wifes car and it worked. The premise is heat always rises from the earth. Does not help the truck tho with a 6" lift an frozen ECM. My block heater has helped a bit but right now she ain't going no where nice an toasty warm in the garage with the ally in pieces.....still waiting on parts.
__________________
2003 LB7....AFE intake, EFI LIVE TUNING, 5000 WATT INVERTER YEP SHE'S A PORTABLE GENERATOR TO BOOT.
  #8
Old 01-26-2013, 11:51 PM
AubleAK's Avatar
Your ecm is not cause of your truck not starting because of it being to cold. I personally have started my truck at 45 below zero not plugged in without any problems. Insulation bay do a little but but not much. Waste of your time in my opinion. Stereos will slow down severely in the cold.
__________________
thanks Steve!
3 inch Downpipe
20" XD Monsters
Airdog 165
Born Again 12/16/12
Died again 1/9/13
  #9
Old 01-26-2013, 11:52 PM
Default
Frozen PCM? That's a new one on me. Lived here in AK for about 23 years, winter temps as low as -45F and never seen that happen. Maybe the Fairbanks boys who see -60F and colder (frequently) can chime in.
I've seen batteries freeze, trans fluid gel, fuel gel, cooling systems freeze, on & on...
__________________
  #10
Old 01-27-2013, 08:32 AM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
Webasto Heater would be your best bet. They offer a couple versions, block heat, cab heat & both. They run off of your fuel tank and keep the cooling system warm while the engine is not running.
You need to have the glow plug and fuel system checked as mentioned above. Synthetic fluids in everything. The Duramax starts amazingly well in the cold weather, better than any other diesel engine I have been around up here. There is a reason Alyeska runs D-max only on the slope
  #11
Old 01-27-2013, 01:34 PM
Gearhead
I'm in the anchorage area. It's -12 this morning says the truck thermometer and she won't start at all. Someone told me the diesel fuel here is already treated to not jell. Is that so or do you guys still buy your own and add it? I have heard of the heater that runs off the fuel. I might look into that. I also been meaning to drop my truck off at Rok's auto I think it's called up in Wasilla for a diagnostic to be run on the injectors and stuff.
  #12
Old 01-27-2013, 01:36 PM
Gearhead
I'm also going to have them check the glow plugs an fuel system. I don't have that much experience working with diesels or else I would do some of it myself in the shop.
  #13
Old 01-27-2013, 01:39 PM
AubleAK's Avatar
Quote:
You should have number 1 fuel, so yes it is treated to not fell. Rok is pretty good guy to deal with. I'd start with replacing te glow plugs and checking the injectors.
__________________
thanks Steve!
3 inch Downpipe
20" XD Monsters
Airdog 165
Born Again 12/16/12
Died again 1/9/13
  #14
Gearhead
Quote:
Yea the truck starts right up when it's 20 degrees out. The closer to 0 and below the harder it starts. It'll turn over fire a couple times unroll it finally takes and stays going. The colder the longer it takes to start.
  #15
Old 01-27-2013, 01:46 PM
AubleAK's Avatar
id start with getting your fuel system looked at and if all checks out replace the glow plugs.
__________________
thanks Steve!
3 inch Downpipe
20" XD Monsters
Airdog 165
Born Again 12/16/12
Died again 1/9/13
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
