  #16
Old 01-09-2013, 02:42 PM
RichLMM's Avatar
RichLMM RichLMM is offline
Default
Quote:
Originally Posted by 05_LLY View Post
If ya take the time to do proper homework on the subject (whatever it may be), there will be lil to no fail!!
my problem is i didn't like homework and have the attention span of a squirrel
__________________
2001 2.6 truck the other woman
2013-2014 shootout productions 2.6 points champ
thanks to caleb baker@blackout performance
  #17
Old 01-09-2013, 03:27 PM
rgullett83's Avatar
rgullett83 rgullett83 is offline
Default
Quote:
We a're running a precision cooler, that has 2 inlets and outlets did u say squirrel. ......lol
Sent from my GT-I9300 using Tapatalk 2
__________________
Riley
Mine: 01 CCSB Siverado frame off restored with various parts from 01-06 built lly motor, built 03 trans, 2xcp3, 100% exergys, billet s366 and much more that I wont fill this space with...
Hers: 07.5 CCSB GMC Sierra SLT LMM, XD Spys, Tuned and deleted
  #18
Old 01-09-2013, 03:36 PM
05_LLY's Avatar
05_LLY 05_LLY is offline
Out-A-Time
Default
Hahaha
__________________
Caleb
Ours~ 15 LTZ CC/DRW Tow Rig ,PPEI tuned
My DD~ 06 D/A Lt3, Grocery Getter~ WCFAB 475/stocker twins, 40's, FPE CP3, Blackout tuned and Trans, 11.92@118mph @ 7400Lbs
Her DD~ 17 Z71 Colorado 2.8 MiniMax
Hers~04.5 D/A CC/SB- 3.0LPSD puller "Girl's Night out"---2015 Power Pulling Productions 2.6 Champion, 2011&2012 USA East 2.6 diesel Champion, 2012 Diesel Motorsports (NADM) 2.6 Champion,
Blackout Performance Built and tuned with help from Diamond Pistons, XSpower, Wagler, WCFab
  #19
Old 01-09-2013, 03:44 PM
RichLMM's Avatar
Default
Hahaha
__________________
  #20
Old 01-10-2013, 04:59 AM
kjp800's Avatar
kjp800 kjp800 is offline
Default
Hahaha
Hahaha....that just made my morning
I am also looking into a setup like this and trying to do my homework, but not finding much. I'd really like to find more on sizing the intercoolers, I know I want roughly a 2000hp core, but want to know why, other than cause its what I was told to get.
__________________
15 Chevy CCSB
05 Chevy CCSB
02 GMC ECLB Limited Pro Stock puller
  #21
Old 01-10-2013, 05:51 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Default
Look at the CFM rating and compare it to what your charger should flow.
__________________
Isaac Griffith, formerly 04jimc
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
New DD/Beater: Beat up 06 GMC CCSB w/ 252,000 miles
Current Tow Rig-12 Ram 4500 Crew
'Oughta K
now Better'- PPL Lim Pro Stock 05 3500 Crew Cab 158" WB 2014 PPP 2.6 Champions
Thanks to Blackout Performance
  #22
Old 01-10-2013, 09:31 AM
05smoker's Avatar
05smoker 05smoker is offline
I'm officially done!
Default
http://www.duramaxdiesels.com/forum/...ad.php?t=40985
Here are some pics of my box and cooler I just sold. I had one of the Rule 3800 gallon pumps submerged and it moved some serious water (we changed the screen on it). The entire center section of the box held ice/water. The intercooler was a PT1800 that we put two extra fittings in so both lines flowed through versus a "U" design. On the dyno the truck was running and warming up and as soon as you hit the button the intercooler would be cold to the touch. My rule of thumb I was told was look for a rating for double your power goals for a diesel. I prefer Precision or Chiseled - look on yellow bullet for used one.
__________________
2005 2500HD CHEVY CCSB, Blackout VVT, FPE SCIV w/ 1057, 3" lowering shackles, overloads removed, Cooper Zeon LTZs on BMF REPRs. SOLD
Thanks to Fleece, Blackout Performance, Genes Machine Shop, Tim, Bullfrog, Simon, Mark Broviak .......
Remote mount turbo, Electric Water Pump, Cheetah turbo - Member #1
  #23
Old 01-10-2013, 02:14 PM
duramaxsandwich's Avatar
duramaxsandwich duramaxsandwich is offline
Default
i run 2 Rule 3700 submersibles also, we talked to Bell IC and got a custom core made by them to what my hp goal is, then jason at wcfab put some end-tanks on it. i run about 100lb of ice per pass. data logger is very handy to have to make sure your intake temps are in check. we ran a home-made data logger last year for the first time and even after logging it on the engine dyno it is surprising to see the difference between a dyno pass and an actual pass down the track.
__________________
2015 GMC 2500 White CC/SB
2001 GMC EC/LB 3.0 puller "MoneyShot"
  #24
Old 01-10-2013, 03:35 PM
ikeG's Avatar
Oughta Know Better
Default
I have IAT logs from pulls last year with banks air-air i/c. Installing air-water now and i am really interested to see the differences!
__________________
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #25
Old 01-11-2013, 08:01 AM
Leadfoot's Avatar
Leadfoot Leadfoot is offline
Needs Bigger Tires!
Default
Quote:
If you could post your results, it would be much appreciated.
__________________
2006 GMC CCSB 4WD McRat EFI Live , Kennedy dual lift pumps, Champion Stage IV tranny, Mike L converter, cooler and C3 oiler, Suncoast Brace, Eaton E-Locker, Caltracs, homemade pulling hitch, homemade limit blocks, H2's and cooper STT's, Predator, MBRP Cool Duals (not kitty or muffler), EGR blocker, Finger Stick, and all on headlight mod.
80 K20ish Reg Cab Long Bed, Full Roller 496, Manual TH400, Torque Converter Techniques converter, 3:1 planetary setup, NP205, High Angle driveshafts, 4.56's, 35's, Lockers F&R, Dakota digital dash, and custom interior.
www.matpa.org
  #26
Old 01-11-2013, 04:37 PM
dracing70's Avatar
dracing70 dracing70 is offline
SH--- GETTING EXPENSIVE!
Default
I run twin 3800 gallon submers. In roughly a 15 gallon box hanging. It's always best to put weight farther forward
__________________
Special thanks to Mark, Larry and everyone at Danville.
2004.5 lly 2500 chevy 4x4 very big Danville turbo, efi live, carrillo rods, so cal pistons ,arp studs ,brodix heads . Hsp manifolds and custom intake along with a DR Tuning custom stainless remote mount,very very very very very large exergy sticks,twin modded cp3 pumps. Tranny is obviously built with billet shafts in house by DR Tuning. Plus many other goodies!
also have a 2003 lb7 crew cab dually dark green mostly stock with stage five suncoast, full cognito front suspension semi 10 lug wheel kit with 19.5 alcoa's and s b intake
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
