  #1
Old 12-27-2012, 07:05 PM
DirtymaxLbZ2006's Avatar
DirtymaxLbZ2006 DirtymaxLbZ2006 is offline
FNG
Default EGR blocker plate or delete kit?
Is the egr delete kit that much better than just using the cheap blocker plate???
  #2
Old 12-27-2012, 07:36 PM
LWATSON's Avatar
LWATSON LWATSON is offline
future trans limpers
Default
I used the blocker plate until I upgraded to a fixed charger. I think the gains are minimal at best doing the full delete over the blocker plate.
__________________
Landon-2006 Silverado CCSB 4X4 LBZ
Rebuilt engine by Burkett Racing Engines
LBZ rods,.20 over LB7 pistons, head studs, balanced rotating assembly.
Exergy 12 mil stroker pump/ Exergy 200 overs
S475/88 hybrid compounds, turbos specked by Mark @ Danville Performance, Kit built by myself and Moparkxracer "Shade Tree Triples"
Cylinder Pressure/Dyno tuning by Danville Performance
Trans built by Diesel Addiction/ 1072-2 Limitless Diesel converter
  #3
Old 01-17-2013, 10:40 PM
Justin jelley Justin jelley is offline
FNG
Default egr
hi im new to this dont know how or were to post this but ill just ask i have 05 lly bone stock and i want to get egr blocker plate will it throw codes or check engine light if i do if so how can i stop it
  #4
Old 01-17-2013, 10:48 PM
blk smoke lb7's Avatar
blk smoke lb7 blk smoke lb7 is offline
<-----Lots of green $
Default
Quote:
My vote is to delete it,your probably going to do more mods in the future and it will be in the way or you will want better flow on the cold side (were the egr delete is)
Quote:
Yes it will but if you get efi live your tuner will be able to turn those check engine lites off for you.
__________________
04 LB7 CC/SB EFI live, S366,S483 , Born again 08/10/2011 11.64@117
Some wicked tuning by Bo-Bo (Bob olson) Thx Bob
Quote:
Originally Posted by flyinelvis11
i'll let you use anything i got except my wife and my truck; it's too easy to throw a rod in either one):h
Quote: Carter 44
Boost is like a hot girl with an STD...you know you want to hit it but your afraid of the consequences
rollncoal07:Twining is wining
Quote:
Originally Posted by McRat View Post
You come off as a Timeshare Condo salesman on this site.
If you were helping folk with problems, or asking for input on your problems, it might be different, but from where I see, you are only a little different than the Russian spammers selling iPads that we delete.
Act like more of a human, and less like a spambot, and you'd probably catch less heat. This is "family", and it's our corner bar, and a group of guys with grease all over them leaning over fenders of somebodies truck that ain't making the right boost.
It's also one of few sites with more hardcore wrenches and racers than wannabees.
You're welcome to be a member here, and post about your build, but don't expect people to shower you with roses yet. That comes with seat time on the site, and on the track.
  #5
MadMaxx61's Avatar
MadMaxx61 MadMaxx61 is offline
Devilmaxx
Default
Yes it will you will need a tuner or a finger stick.
__________________
Steve
2008 2500HD 4X4 LTZ Z71 6.6L LMM
Mods: EFILive, MBRP 4" DPF Delete, BD Manifold, SD Manifold, SD Center Link, SD Sleeves, S&B Intake, FS-2500, PPE Trans Pan, Bushwacker fender flares, PPE Oil Centrifuge, And other non-go-fast things.
Things still need to put in: PCV Re-Route,Air Dog AD-200.
1984 GMC Jimmy 2-Door
1998 Buick Century Limited
Sold It will be missed. 1985 Mercedes 300SD - Running still need work.
Sold It will be missed. 1995 C/K 3500 4X4 Dually 6.5L
Mods: K&N air intake, 80Hp chip, 97 cooling, twin fans, #9 Resistor, FSD Heat-Sync, Full Pillar 3 Gauge (EGT, Boost, Transmission),
  #6
Old 01-17-2013, 11:48 PM
Cornell's Avatar
Cornell Cornell is offline
LBZ for life
Default
I did the blocker plate the first time. I could never get it to seal properly and soot got all over unter the hood.
I like the full delete. Cleans up the engine bay quite a bit.
__________________
Daily Driver 2017 Sierra Denali 2500HD
Hot Rod 2007 Sierra 2500HD / Reg Cab Short Bed / Danville 68mm STG2R / DHD Cast Bridge and 3" Cold Pipe / MBRP Boost 3" Tube / SDP 3" Downpipe / Magnaflow 5"/ PPE Up Pipes and Manifolds / Airdog 150 / Trans by Mike L / Cognito 4-6" / Custom Pearl White / SLT Interior With Ipad Headunit
  #7
Old 01-18-2013, 07:16 AM
Texas Chevy's Avatar
Texas Chevy Texas Chevy is offline
Default
Big advantage of a blocker plate is if you have to emissions testing.
__________________
07 silverado classic. CCLB sold
2011 LML 2500hd CC/LB LTZ. H&S xrt pro. auto meter boost and pyro guage. Big thanks to Jake@Diesel Mafia
  #8
Old 01-18-2013, 12:18 PM
FNG
Default
No emission tests so ill prob just do a delete what one is good and can I just use a fingerstick to keep away the codes. Tryin to stay away from a tuner
  #9
Old 01-18-2013, 12:37 PM
Default
Why do you want to stay away from a tuner?
Tuners are your friends
__________________
  #10
Cornell's Avatar
LBZ for life
Default
My crew cab has the RDL delete and 3inch y bridge. I'm putting an SDP kit on my regular cab
__________________
  #11
Old 01-18-2013, 12:47 PM
FNG
Default
couple of my buddys have them on theres and if they turn them up they will go into limp mode or low fuel pressure i just wanna build mine first
  #12
Old 01-18-2013, 12:50 PM
FNG
Default
intake,exhaust,exhaust manifold, intercooler and tubes just stuff like that for now.how much hp can the tranny handle safely without slippage
  #13
Old 01-18-2013, 02:31 PM
arneson's Avatar
arneson arneson is offline
Default
6speed is 80-100hp on average depending on the driver and how its driven. I drove 40k on a 120rwhp tune stock trans, no limps ect. Pulled trailers to. Nothin wrong with a tuner tho, just dont crazy. U could always throw on the trans go jr for alittle help. But definitely savin for the build is a smart way.
__________________
2009 chevy crew cab ltz lmm 71k miles
many things to come.
2015.5 gmc denali lml deleted (sold)
2007 chevy classic ccsb 4x4 ltz twins ect (sold)
  #14
Old 01-18-2013, 08:49 PM
Bigcat350's Avatar
Bigcat350 Bigcat350 is offline
Caution May Blow Smoke
Default
If you have an FE9, more then likely you'll be ok. All fingerless trucks will throw a code, but an FE9 will not illuminate the CEL when this happens which is why most FE9's can run blocked and fingerless.What is a FE9 - Emissions code, you'll find it on the spec list in the glovebox. There are a few different packages, California emissions and Northeast emissions to name a few. Basically if you have anything other then Federal Emissions (FE9), your probably gonna need a fingerstick
__________________
05 GMC SLE CC/SB LLY: Tie Rods Sleeved, MBRP 5" Turbo Back, Moto Metal 959 wheels with Nitto T/G LT285/65R/18's E-Rated, LBZ M/P, EGR Blocked, Shimmed FRPV, Ported Fuel Rail, BT Lockup Box , AD2-165, CTS with EAS, Tranny Built by Punkin, And tuned with some Shine.
  #15
Old 01-18-2013, 08:53 PM
Default
Justin fill out your sig so we can see what your working with and what you have done.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
