  #1
Old 12-18-2012, 12:16 PM
dracing70's Avatar
dracing70 dracing70 is offline
SH--- GETTING EXPENSIVE!
Default Serpentine belt routing?
Anyone have a belt diagram for routing it with a dual cp3 and also the ac pump all being used?
__________________
Special thanks to Mark, Larry and everyone at Danville.
2004.5 lly 2500 chevy 4x4 very big Danville turbo, efi live, carrillo rods, so cal pistons ,arp studs ,brodix heads . Hsp manifolds and custom intake along with a DR Tuning custom stainless remote mount,very very very very very large exergy sticks,twin modded cp3 pumps. Tranny is obviously built with billet shafts in house by DR Tuning. Plus many other goodies!
also have a 2003 lb7 crew cab dually dark green mostly stock with stage five suncoast, full cognito front suspension semi 10 lug wheel kit with 19.5 alcoa's and s b intake
  #2
Old 12-18-2012, 12:26 PM
TeaBagger2006's Avatar
TeaBagger2006 TeaBagger2006 is offline
Im a Garrett Nut Swinger
Default
Who's kIt?
__________________
Joe
Loosest Tailgater in USA
2006 GMC 3500 D/A LBZ SRW CC/LB SLT 4x4
8" Fabtech lift 37x13.5/20 tires....Mike L trans....some go fast goodies
13.20@106mph
'06 Jetta TDI
  #3
Old 12-18-2012, 12:44 PM
messejme's Avatar
messejme messejme is offline
Jazzy, Me and Max
Default
This is dual alternators i think it is the .
__________________
04.5 LLY dooley CC. EFILive, SC IV, 1058, race valve, Airdog-150, 4" stack, Socal built engine, S480 over GT4094vvt stage 2, 60% overs, arson III CP3, flo pro extreme headers and up-pipes, PPE dual CP3's
  #4
Old 12-18-2012, 01:14 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is online now
Default
use a dual alternator belt and it must be run this way in red
if you try to run it like the dual alt shows, it will be too short to go on as the pulley for the second pump is much bigger than the pully on the second alt.
i asked dan about running the belt as if you had the PPE centrifuge on an LB7 but never heard back on that as there is a bolt on the powersteering pump that gets in the way of the belt
__________________
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #5
Old 12-18-2012, 03:35 PM
dracing70's Avatar
Default
H
Quote:
Originally Posted by TeaBagger2006 View Post
Who's kIt?
it's a crank it up diesel kit
__________________
  #6
Old 06-03-2014, 04:29 PM
TWINDBLACKLMM TWINDBLACKLMM is offline
Gearhead
Default belt
Is this the rght routing for the PPE kit? Looks to be.. My AC has been squaling like a pig the last 2 years, ahve done 3 belts, counting this last one I got from PPE I knew something was wrong!
__________________
2010 Chevy CC/SB Loaded Black Granite LTZ Z71 4x4. Compound Turbos, Studded, 40 overs, Suncoast Trans, CST 8" Dual shock lift, 37" Mud Grapplers, BMF's, Train horns, air bags, Blacked out, 2012 front end, and all sorts of stuff!
  #7
Old 06-04-2014, 07:30 PM
x MadMAX DIESEL's Avatar
x MadMAX DIESEL x MadMAX DIESEL is offline
<<<< No Horsepower
Default
Quote:
Pretty sure that's how I run mine. I would hate to run it over the oil filler like alot of people do. That just gets in the way
__________________
Ben
LBZ Stock Charger
12.26@108.8
7.78@87.7
2.5 puller in the Mecca!!
Manual Mafia
Quote:
Originally Posted by BgBlDodge View Post
Al gore invented driving the turbo.
  #8
Old 06-04-2014, 08:03 PM
DIESELMAFIAPER.LB7's Avatar
DIESELMAFIAPER.LB7 DIESELMAFIAPER.LB7 is offline
<----twinz
Default
Here's mine I hate the ppe belt routing
__________________
2003 GMC CC/SB: billet 66/83mm compounds, dual pumps, exergy injectors, built trans (by me) tune 3 11.61 @ 119 !!
2012 mega cab 6.7: Tuned and deleted (reliable) sold! (should have kept it)
2016 CCSB custom sport lml ltz deleted with sotf tunes by me
  #9
Old 06-04-2014, 08:09 PM
<<<< No Horsepower
Default
Quote:
Yeah thats how mine is. Notice those tick marks on the tensionser puller. By GM that is out of spec, but (like you I'm guessing) I've never had any issues slinging belts running high rpm.
__________________
Ben
LBZ Stock Charger
12.26@108.8
7.78@87.7
Manual Mafia
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
