  #1
Old 11-15-2012, 01:12 PM
madmatt's Avatar
madmatt madmatt is offline
Default Allison trans cooler line fittings
has anyone found a fitting that will screw into place of the factory trans cooler line fittings? theyre a m22X1.75 which other then the factory fittings,,, i'm finding nothing on. Running a new cooler setup and all i lack to fire the new engine and trans in some fittings.
BUT if no one can help with that anyone have some old leaking trans cooler lines laying around they'd donate? I'll pay the ride and just need the ends plus about 6" of the hard line that comes out of the trans.
Thanks,
Matt
__________________
BLACK 05 CC/LB LT 3500 SRW,,,,,,
  #2
Old 11-15-2012, 01:18 PM
Hot COCOAL Hot COCOAL is offline
May the farce be with you
Default
Wha...
there are upgraded transcooler lines you can buy, alligator performance sells them in 1/2"id and 5/8" id, i have a set of the 5/8" and they trhredded right into place on the stock cooler and the ppe cooler?
__________________
Jason-
Founding member of the "knows enough to be dangerous" club...
Hey, I'm NORWEGIAN... you try having a SQUARE head full of ROUND thoughts...
  #3
Old 11-15-2012, 01:22 PM
madmatt's Avatar
Default
mmm i'm running 5/8 TOC to -12 fittings. fabbing up a whole different setup. had some m22x1.5 to -12 adaptors but no go. i'm bypassing the factory cooling circuit in the radiator and running just a big remote mount with a fan on it.
__________________
  #4
Old 11-15-2012, 01:26 PM
Default
Hmmm, well if the threads are different than stock idk where you could go, maybe summit or jegs?
Good luck, sounds like it'll be sweet when its done!
__________________
Jason-
  #5
Old 11-15-2012, 01:27 PM
madmatt's Avatar
Default
Joe at PPE has something different threaded into his,, waiting for word back as to what he did or where he got them
__________________
  #6
Old 11-15-2012, 01:31 PM
THEFERMANATOR's Avatar
THEFERMANATOR THEFERMANATOR is offline
LEGALLY INSANE
Default
03+ should be -10 o-ring seal. My radiator fittings are nothing more than a -10 male o-ring to -10 flare. I believe it is a 7/8X16 thread. I'm not aware of any metric sized cooler fittings.
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, little of this, a little of that,
DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, custom tuning by me, KENNEDY single pump and pump rub kit.
  #7
Old 11-15-2012, 01:46 PM
madmatt's Avatar
Default
i'm talking about the fittings in the trans
__________________
  #8
Old 11-15-2012, 01:52 PM
madmatt's Avatar
Default
going from this cooler to the trans,,
__________________
  #9
Old 11-15-2012, 08:05 PM
LEGALLY INSANE
Default
Quote:
Thought the 03+ all used the same fitting in the radiator, trans, and cooler? I know my 01 is a -8, but I don't have an 03+ to check in front of me.
__________________
  #10
Old 11-19-2012, 06:32 AM
Tomz28's Avatar
Tomz28 Tomz28 is offline
Gearhead
Default
the fitting size is 7/8-14 staight thread. call jegs up
__________________
2003 2500HD LB7 T4 S366 double batmo, and a S475tct Head studs, exargy %30 over injectors, LBZ CP3, 4in downpipe, 4 turbo back, ADII 165, UCAs, S&B intake, EGT and boost gauge, All on Mod, Braces, 285/75/16 BFGs/Nittos A/Ts, PPE stage 5 trans(built by me) ML conveter, Tcase brace, MA engine mounts, spring clamps
BIG thanks to Mike L, Dustin @ ATP,
11.38@120 1.62 60 foot
2000 Camaro Z28 twin turbo
9.96@140mph 1.68 60 foot on pump gas and 13psi of boost
  #11
Old 11-20-2012, 09:30 AM
madmatt's Avatar
Default
hmm maybe the idiot at the parker store sent me down the wrong path then,,,,,, i've been chasing a ****ing m22 x 1.75 fitting for over a week,,, i'll run to town and see what i can't come up with tomorrw then thanks.
__________________
  #12
Old 11-20-2012, 09:50 AM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
I would ditch the hose clamps on your cooler.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #13
Old 11-20-2012, 10:24 AM
AubleAK's Avatar
AubleAK AubleAK is offline
Default
Quote:
X2. Go have some made.
__________________
2001 Chevy Ext. Cab Short Bed
EFI Live by SS Diesel Tuning -
thanks Steve!
LBZ rods, ARP Head Studs, 475 over stock twins
4 Inch Turbo Back Straight Pipe
3 inch Downpipe
20" XD Monsters
Suncoast Gmax and Precision ML Converter - Built By Me
Airdog 165
Died 9/13/12 - broken valve
Born Again 12/16/12
Died again 1/9/13
2011 GMC Sierra SLT LML
stock- and staying that way
  #14
Old 11-20-2012, 10:34 AM
madmatt's Avatar
Default
why? how much pressure do they see? We spoke about how much the cooler sees once before and seemed to be within reason of what a barbed fitting and a clamp could hold. not arguing but could i have maybe misunderstood what pressure the cooler sees?
__________________
  #15
Old 11-20-2012, 10:41 AM
Mike L.'s Avatar
Default
The cooler pressure can spike to 200 psi running stock mainline pressure ( 232 psi ). It can get a lot worse running higher mainline like a .130 shim ( 255 psi ). And even worse running my pressure regulator spring which is adjustable from 290 psi- 350 psi. Clamps are scary. Be carefull.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
