  #16
Old 08-19-2012, 05:39 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Default
Quote:
Originally Posted by Fingers View Post
Die on Board is used for space and heat dissipation.
Speaking of which, I don't see any thermal sinks or traces on the processor board. Not driving much other than signals. Even those look to be clamped and isolated.
True, they are not driving much. However, look at the row of 7 dies closest to the connector (not the bus between boards). Those look very much like FETs to me, and have fairly thick bond wires, as well as moderate pad sizes. The proximity to the connector and bypass caps would indicate these are driving something external to the TCM, at reasonable power levels. Nothing like the drive board.
Now the drive board appears to be driving a fair bit. Note the pin cushion areas. Those are for either hi heat or noise reduction. Considering we can see some drivers soldered to them on this side. Chances are good there is another one the other side of the open pin cushion areas.
Yes, this board is sourcing/sinking a lot of current. Lots of heavily heat-sinked transistors and diodes down near the external connector. I would guess these are what run most of the solenoids in the transmission.
I see what appear to be two large magnetics at the far edge of the board (labeled 88Y15) surrounded by smoothing caps and reasonably large diodes. These appear to be DC-DC converters, probably buck converters. I would guess the small one (near the common bus) is to provided a reference 5V for sensors. Not sure what the larger one is for, unless they are favoring variable DC voltage over PWM for certain solenoids? It looks like it can push a lot of current.
Now that I have looked a little closer I see there are several more Die on Board components than I thought. Two I recognize as dual OP-Amps.
I see what appears to be a general purpose micro, some memory (RAM or Flash, can't tell from the phots), and a more specialized micro (DSP or FPGA?). There really are a lot more, but that clear potting compound makes them hard to see. The ones that have me stumped are all the squares with the squircles (yes, that's a real thing, apparently) inside, and the small bond wire to the squircle on top.
I wouldn't mind getting that TCM under a scope for the fun of it. Or Ben, want to see if you can find something that safely dissolves the potting compound so we can get some better photos? Though the photos you got are remarkably good considering it is through the compound. Thanks for sharing them!
__________________
  #17
Old 08-22-2012, 10:37 AM
Fingers's Avatar
Fingers Fingers is offline
Village Idiot
Default
Quote:
Those are ferrite core inductors.
Pure square with a single center tap is probably a Cap, maybe a resistor.
The Three wire device has me a little stumped. I suspect it is an isolator of some sort.
__________________
But.....What do I know.
'04.5 EC/LB 4x4.
Howard Rods w/ oiler hole.
Oval Chambers and valve reliefs cut in Mahle Cast Pistons. 17.5:1
SoCal Stage 2 heads, 3388 Cam, Billet Flywheel, and harmonic balancer.
Danville 68mm VVT Turbo
100 over injectors.
PPE Dual CP3s
ProFab Castflow headers and uppipes.
100 PSIA MAP Sensor
Kennedy dual lift pump.
Dynoed 690 HP / 1200 TQ
  #18
Old 08-22-2012, 12:29 PM
duratothemax's Avatar
duratothemax duratothemax is offline
<--- slippery roads
Default
The 5-speed TCM simply feeds all of the solenoids with a +12v source that is simply "tapped into" the +12v ignition circuit feeding the TCM. The "12v reference wires" going to the solenoids from the TCM are just internally spliced into +12v ign. And then the TCM provides the "control" via an internal low-side driver. The only solenoids that actually get a dedicated high-side driver are the two trim solenoids, because they are PPC solenoids. (more on that below).
Whereas the 6-speed TCM actually has both high side AND low side drivers to control ALL of the solenoids. The high-side drivers dont really do anything; they basically just supply +12v all the time and the low-side drivers to all of the work. The high-side drivers are just cycled on/off for 6 seconds at each startup/ignition cycle to check the integrity of the drivers and the solenoids/transmission harness wiring. Then, otherwise the high-side drivers just stay energized all the time.
I dont know why Allison did this (there was nothing wrong with just feeding the solenoids straight +12v ign power); probably just for better/more accurate circuit diagnostics...so the TCM can actually isolate and control ALL of the wiring going to the solenoids. And with an actual monitored high-side driver, you the TCM can monitor the circuits for both shorts to +12v and shorts to ground, and open circuits on BOTH sides.
And, the TCC solenoid on the 6-speed is not a standard PWM solenoid. Its a PPC (pressure proportionate to current) solenoid, so the TCM has to precisely monitor and control not only the PWM of the control circuit, but how much current is flowing through the TCC solenoid circuit.
Whereas the way the 5-speed TCM is wired/the way the solenoids are controlled (with the exception of trim a/b), the TCM can basically only run diagnostics on the "control" (low-side) side of the circuit.
I assume those two big square things are the two high-side drivers. They have to source a decent amount of current. The TCC solenoid alone can draw up to 2 amps or so.
__________________
2012 Denali - R&D testbed for upcoming new products.....
2005 Silverado LT - Blown up/broken too many engines and parts to care about making it fast anymore, so its back to mostly stock - The best names in the industry for parts/advice/help...MikeL.Guy-SoCal.Rob-ATP.Evan-Limitless.McRat.BigDipper.Bobo.Tony-RRDP.Fingers.Eric-MA.EFILive...
BT DieselWorks, LLC - EFILive tuning - Duramax/Allison/gasser STANDALONE HARNESSES - Allison lockup controllers - Allison tapshift kits - Digital DSP-5 switches - full assortment of great electronic improvements and gadgets for your GM truck/SUV
All products available for sale through our online store at www.btdieselworks.com
Be sure to "like" us on Facebook at www.facebook.com/BTDWorks
Be sure to "follow" us on Instagram @btdieselworks
  #19
Old 08-22-2012, 01:05 PM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Default
Quote:
Originally Posted by TheBac View Post
...and to think, that TCM probably has more computing power than what took the astronauts to the moon and back. Pretty amazing all the computing power packed into that small case.
I used to have a Core Memory board like what was used for Apollo. This is what I remember (damn, I should have kept it):
It was 1,024 little donut magnets with 3 wires running through each one. It was about 10x10"? and cost over $1000 when new. It held 1024 bits of data, or 128 bytes.
To get as much RAM as is in my phone, would cost about $2 trillion dollars in 1969 currency, and would probably cover 67 square miles?
Dunno. Things change.
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
  #20
Old 08-22-2012, 01:10 PM
<--- slippery roads
Default
yep! core rope memory. Ferrite magnets with wire going through them arranged into various strands, "coded" by hand.
__________________
  #21
Old 08-22-2012, 01:26 PM
Mike L.'s Avatar
Mike L. Mike L. is online now
Default
Quote:
Originally Posted by paint94979 View Post
are we really sure the Apollo 11 mission even landed on the moon ???
Hence no need for an exotic computer.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #22
Old 08-22-2012, 03:52 PM
GMC_2002_Dmax's Avatar
GMC_2002_Dmax GMC_2002_Dmax is offline
The Still Master
Default
I bet a wrist watch could put a man on the moon.
__________________
2016 Denali LML----> 2012 Denali LML SOLD
2007 GMC "Classic", LBZ, SLE1 ,RC/LB, 4x4
~Powered By "MOONSHINE"
12.525 at 107.07
2002-GMC Sierra 2500HD SLE/CC/SB/4X4~Powered By "MOONSHINE"
12.65 fuel only, 12.00 on some N20
Retired 04/18/2009...................SOLD 01/2014
  #23
Old 08-22-2012, 04:57 PM
JRODS*LB7's Avatar
JRODS*LB7 JRODS*LB7 is offline
Default
Quote:
Originally Posted by RPM Motorsports View Post
Looks like a Wallmart parking lot, from an airplane...
hahahha i thought the same thing!
__________________
06 ccsb
efi live dsp5 BT tunes
4"mbrp
Airdog 165
Built Trans (BT DW)
20x12 -44 off fuel Hostages
Rancho 9000 xl
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
