  #1
Old 07-31-2012, 06:28 AM
JustinD's Avatar
JustinD JustinD is offline
Plow Truck
Default Revmax converters?
Just put another stock trans in an 02 2500HD, the truck won't be a race truck or ever see high hp numbers, has a very conservative tune in it, we bought a used Rev Max converter from a friend, wondering if anyone has experience with these?
http://revmaxconverters.com/index.ph...ison-1118.html
__________________
2001
II S366
12.65 @ 105 stock turbo
Thanks to:
Samson
Jeff Toman
Johnny
James Dow
James R
Jeremy and the guys @ WDP
  #2
Old 07-31-2012, 09:27 AM
THEFERMANATOR's Avatar
THEFERMANATOR THEFERMANATOR is offline
LEGALLY INSANE
Default
Pretty sure they make em for TRANSTAR in a single disc which is considered a good stock replacement. No clue as to there triple disc though.
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, little of this, a little of that,
DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, custom tuning by me, KENNEDY single pump and pump rub kit.
  #3
Old 07-31-2012, 09:34 AM
JustinD's Avatar
Plow Truck
Default
Feels great driving the truck, but like I said its a very mild tune no lift pump. But overall happy with it.
__________________
2001
II S366
Thanks to:
Samson
Jeff Toman
Johnny
James Dow
James R
  #4
Old 07-31-2012, 11:35 AM
05chevy's Avatar
05chevy 05chevy is offline
Default
I have used one in a truck and a friend of mine has had great luck with his. Went 12.40 on stock motor with that converter
__________________
05 lly, s475, 40% nozzles, stock cp3. 11.69 @115
685hp/1100ftlb
97 12valve
  #5
Old 07-31-2012, 02:39 PM
JustinD's Avatar
Plow Truck
Default
Awesome!!! Good to hear!
__________________
2001
II S366
Thanks to:
Samson
Jeff Toman
Johnny
James Dow
James R
  #6
Old 07-31-2012, 03:46 PM
02CCSB's Avatar
02CCSB 02CCSB is offline
Built
Default
The do NOT make them for Transtar. Transtars converters are built by RECON.
Bottomline is this, it's probably a decent converter, but I would be hard pressed to deal with Revmax given their history.
They've changed their name atleast 3 times, see this thread: http://www.ls1.com/forums/f6/revmax-...28/index3.html
Well friend ....here are some additional facts on RevMax. How about Phoenix Hard Parts, Alpine Transmission, or Redline Torque Converters.... they are all the same guy. Stays in business for a little bit in one name files bankrupt then starts a new business. Over 300 bad marks on BBB for him......
This is all TRUE. Fact is, they're jumping on the bandwagon.
  #7
Old 07-31-2012, 04:19 PM
JoshH's Avatar
JoshH JoshH is offline
Default
I wasn't going to say anything, but given the information posted above, I'll throw in my experience. We had a truck at work that had a Revmax converter in it. It broke the shaft and needed to be cut open to have the pieces removed from the turbine. When the local company we sent it to cut into it, they informed us that, short of the billet cover and triple disc lockup clutch, it was a completely stock converter. In other words, they didn't do anything to reinforce the fins (no furnace brazing or TIG welding) or change the stall speed. This was on a Dodge torque converter, but it makes you wonder what they do in the rest of their products.
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #8
Old 07-31-2012, 04:39 PM
02CCSB's Avatar
Built
Default
How recent was that josh?
  #9
Old 07-31-2012, 04:42 PM
JustinD's Avatar
Plow Truck
Default
So I guess we shouldn't push this one too much??
__________________
2001
II S366
Thanks to:
Samson
Jeff Toman
Johnny
James Dow
James R
  #10
Old 07-31-2012, 05:19 PM
JoshH's Avatar
Default
Quote:
Just a couple of weeks ago, but I'm not sure how old the converter was.
__________________
  #11
Old 07-31-2012, 05:33 PM
86dmax's Avatar
86dmax 86dmax is offline
86max LB7,PPE Hot Tune,
Default
I ran a revmax and a precision ml and the the revmax worked just as good as the precision you could not tell one from the other.Just because its not a name brand dont mean its junk.
  #12
Old 07-31-2012, 05:57 PM
02CCSB's Avatar
Built
Default
86dmax, it's not that the converter themselves may be any worse than some other name brands, almost all converter builders (other than a handful) use kits and components from either Precision or Sonnax or both.
It's the fact that the owner has repeatedly started up and closed companies and put out inferior products. They literally have one guy trolling the cummins forums all day long looking for sales.
They also claim to have an 850hp capable 68RFE with 'proprietary H&S software'. The whole thing stinks.
As for the Dodge answer Josh posted, was that a gas or a diesel? I'm just curious...
  #13
Old 07-31-2012, 07:10 PM
JoshH's Avatar
Default
It was for a 48RE behind a Cummins.
__________________
  #14
Old 07-31-2012, 07:40 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Revmax is just a changed name for Phoenix transmission wherehouse. They are the biggest rip-off place around. Guess why they changed their name?
You guys go ahead and rave about how good they are and use them. I would not touch them with a ten foot pole. I could tell you guys more, but you would just call me full of shit. Your money, not mine.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #15
Old 07-31-2012, 07:48 PM
JustinD's Avatar
Plow Truck
Default
Good to know, Thanks Mike. Can it be trusted as at least a stock replacement? It won't see anymore than 400hp.
__________________
2001
II S366
Thanks to:
Samson
Jeff Toman
Johnny
James Dow
James R
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
