  #1
Old 07-26-2012, 09:19 PM
surpriseduramax surpriseduramax is offline
FNG
Default trans cooler line removal
anybody care to share the trick to getting my trans cooler lines off my stock cooler, so i can replace it with a larger after market one.
  #2
Old 07-26-2012, 09:24 PM
Dudgy's Avatar
Dudgy Dudgy is offline
Runaway
Default
Pull the black plastic "ring" back, remove the little metal clip that's in the fitting, and it will pull right out
__________________
Tow - 2006 GMC LBZ CCSB on 38's
Wife - 2015 Jeep GC Summit EcoDiesel
Race - 2006 Chevy LBZ RCSB
  #3
Old 07-26-2012, 11:38 PM
Hot COCOAL Hot COCOAL is offline
May the farce be with you
Default
Cut the rubber part of the line, remove the clip that holds them just in front of the oil pan, the clip is held on w/10mm, but you wont need it so break it and remove the remaing clip base later. Sounds crude but...get er done!
  #4
Old 07-27-2012, 01:55 AM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
Wtf coco thats not at all correct to remove the stock trans cooler...
__________________
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.72 @ 150.
06 Cummins cc/sb EFI by Hardway.
Tailgate Member #1 I prefer the backdoor
  #5
Old 07-27-2012, 03:47 AM
Janimal444's Avatar
Janimal444 Janimal444 is offline
Default
Should be no cutting necessary. Remove the black rubber cap on the line(s) going into the cooler, then with a small flathead pocket screwdriver pry off the metal retainer ring. Be careful and have your other hand there otherwise those things can fly off and be lost.
__________________
Sold: 2007 LBZ 4x4 CCSB EFI Live, Kennedy Twin Lift Pumps, PPE Stage V Trans, 4" MBRP, Stock Engine, Twin turbos S475/stock, 40%nozzles.
  #6
Old 07-27-2012, 09:24 AM
denboy's Avatar
denboy denboy is offline
FNG
Default
I read somewere that one puts a oil seal on the factory fitting and also thread tape, is this correct?Another thing was the thread on the factory fitting to long and hits the fins in the port ERLs?
  #7
Old 07-27-2012, 02:08 PM
Default
Quote:
Haha. Oops. Chit. Thought i read he was tryin to get the trans cooler lines completely off/out ot the vehicle, to install upgraded trans lines, Sorry.
  #8
Old 08-21-2012, 09:42 AM
dieselmike247's Avatar
dieselmike247 dieselmike247 is offline
Gearhead
Default
hahaha I read what coco posted and started laughing. I work in a doctors office so she got pissed! HAHA saying there is no humor in medicine. SHE IS A PROCTOLOGIST!
  #9
Old 08-21-2012, 10:16 AM
Default
It is the fastest way to remove the stock lines from the vehicle thoughhaha
  #10
Old 08-24-2012, 06:44 PM
Kappa9012's Avatar
Kappa9012 Kappa9012 is offline
MAN.... I Broke it again.
Default
she must have a shitty sense of humor.... sorry had to...
__________________
07 Lmm CC/SB
Built ally w/1057
Exergy 60 overs
Dual Cp3's
Billet S480 over stock from Wehrli
The man behind the tuning is Idaho Rob
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
