  #1
Old 07-24-2012, 08:00 AM
Devon's Avatar
Devon Devon is offline
broke my curse
Default Intermittent vibration at idle?
Ok, I know there has been a few topics like this before, but I would like to know why a lot of lly's have a motor shake at idle. It will go smooth for a few seconds then shake a faint bit and so on. Done this ever since I have had the truck, rail pressure is normal and doesn't jump at at all. Does anyone know for sure why this does this? My 06 Lly never had a intermittent vibration at idle. I see a lot of other people that have this issue as well. All with 04.5-05 lly's.
__________________
04.5 CC/SB LLY SLT
DJM/McGaughy 2/4 drop,BigDipper Stage IV Trans kit!w/precision converter,S472 single turbo,Tuned by Tony Martino(moonshine)
12.95@103.5 1.79 60'(stock turbo)
  #2
Old 07-24-2012, 08:49 AM
Trotorx2's Avatar
Trotorx2 Trotorx2 is offline
Default
My LBZ has a vibration at idle that kind of goes in waves...it vibrates for a couple of secs...goes away for a sec then starts again. Sounds a lot like what you are describing.
__________________
Ed
2011 GMC Sierra 2500HD Denali Crew Cab. Flo Pro 4" full delete exhaust, EGR blocked, S&B Intake, PPEI tuned.
2006 Silverado ECSB LBZ Suncoast Stage 3 w/ ML Converter Allison Deep pan, EFI Live DSP5, Castflow Manifolds, Profab up pipes with Blocker plate, Profab VVT Downpipe, Profab egr delete, MBRP 4 exhaust, Air Dog 100 with shimmed FPRV, S&B intake, Isspro Gauges, Sleeves, All Seasons centerlink brace, Rancho 9000 shocks, Sulastic Shackles, Boulder H2s, BF Goodrich Rugged Trail T/A 265/70-17
Died 12/4/2013 RIP
Semper Fi
  #3
Old 07-24-2012, 08:59 AM
blk smoke lb7's Avatar
blk smoke lb7 blk smoke lb7 is offline
<-----Lots of green $
Default
Same here my lb7 does it at start up, but after warm it seams to go away
__________________
04 LB7 CC/SB EFI live, S366,S483 , Born again 08/10/2011 11.64@117
Some wicked tuning by Bo-Bo (Bob olson) Thx Bob
Quote:
Originally Posted by flyinelvis11
i'll let you use anything i got except my wife and my truck; it's too easy to throw a rod in either one):h
Quote: Carter 44
Boost is like a hot girl with an STD...you know you want to hit it but your afraid of the consequences
rollncoal07:Twining is wining
Quote:
Originally Posted by McRat View Post
You come off as a Timeshare Condo salesman on this site.
If you were helping folk with problems, or asking for input on your problems, it might be different, but from where I see, you are only a little different than the Russian spammers selling iPads that we delete.
Act like more of a human, and less like a spambot, and you'd probably catch less heat. This is "family", and it's our corner bar, and a group of guys with grease all over them leaning over fenders of somebodies truck that ain't making the right boost.
It's also one of few sites with more hardcore wrenches and racers than wannabees.
You're welcome to be a member here, and post about your build, but don't expect people to shower you with roses yet. That comes with seat time on the site, and on the track.
  #4
Old 07-24-2012, 09:56 AM
Devon's Avatar
broke my curse
Default
Yeah I mean once it's warm it's there still but not bad at all. I wonder if it's just normal?
__________________
04.5 CC/SB LLY SLT
  #5
Old 07-24-2012, 10:41 AM
DuramaxPowered's Avatar
DuramaxPowered DuramaxPowered is offline
Pushing my luck....
Default
My LMM has done this since it was new. I have 92k miles on it without problems. I loaded a 500+RWHP tune at 2K miles, compound turbos at 26K.
sent from my LG "Stupid" phone, using Tapatalk
__________________
07.5 LMM CC/SB 4wd
Compound Turbos - S475/stock
Exergy 100% over sticks
PPE Dualfuelers
  #6
Old 07-24-2012, 11:09 AM
07keo02's Avatar
07keo02 07keo02 is offline
Default
I had this problem for a while too with my lb7. I found my crank pin was bent so I fixed that but to my surprise it still had a slight shake at idle. One thing I was always curious about that could cause a slight imbalance at idle is the fact the drivers side manifold is so restricted compared to the passenger side. I have read some people's truck idled smoother after doing a full bore manifold. I know it's a long shot to be the problem but just a thought.
  #7
Old 07-24-2012, 11:19 AM
07keo02's Avatar
Default
I should add that I think the stock mounts (atleast mine) allow a lot of travel. I upgraded to the MA mounts and now it's more of a slight buzz than a shake. I was concerned of vibrations after the MA mounts because they're more solid but actually made it smoother for me. If I had the money right now I would try an LML manifold as I'm very curious to see if it would smooth out the idle at all.
__________________
2017 Ram 2500 Tradesman CCSB 4x4 6.7
2002 Silverado 2500LS CCSB 4x4 Auto (Sold)
2003 Silverado 2500LS CCSB 4x4 ZF6 (Sold)
  #8
Old 07-24-2012, 04:46 PM
GeneralTJI's Avatar
GeneralTJI GeneralTJI is offline
Turbo Todd
Default
I thought the TC can cause a vibration at idle too. I know triple discs are more prone to this, but my DPC single created a slight vibration that cycles at idle...
__________________
2006 4x4 ecsb 6spd: Self built / tuned sideways s366 setup | DPC Converter / ATS co-pilot | hood stack | homebuilt lowering setup w/coilovers | Kennedy/BD filter | 951's | 250psi inj | Autometer/ISSpro | deep pan | sleeves | roll pan
12.61 @ 105.6mph - 5800ft (stock trans) this pass video
Parted out my car for a Pilot's License!!! Best decision I've made in a long time!
GravityKnightFlying
  #9
Old 07-24-2012, 08:26 PM
Default
I have rdl manifolds and uppipes so i dont believe thats going to make a differance as mine is still doing it
__________________
  #10
Old 07-24-2012, 09:17 PM
07keo02's Avatar
Default
Quote:
Yeah I figured it wouldn't be that easy I had just read a review where a guy said his truck idled smoother after a full bore manifold so it was a thought. I thought it might of been from my single mass flywheel but it's obviously happening in allison trucks too. The only other thing I had read was a bad belt tensioner can cause a shake as well but mine was replaced and its bearing was shot and I saw no difference.
__________________
  #11
Old 07-24-2012, 09:34 PM
arneson's Avatar
arneson arneson is offline
Default
Vibrations from what or where are u noticing it? I cant say i have ever had a vibration. Idles smooth and doesnt change. Im super picky and pick up on noises easy. I hate them. But im kinda lost on this one being there are so many of u guys having this issue. I have triple disc, twins, ect and dont notice a thing?
__________________
2009 chevy crew cab ltz lmm 71k miles
many things to come.
2015.5 gmc denali lml deleted (sold)
2007 chevy classic ccsb 4x4 ltz twins ect (sold)
  #12
Old 07-24-2012, 10:22 PM
07keo02's Avatar
Default
Quote:
Mine was more of a slight shake, like something out of balance. Could see the engine move side to side at an idle and my shifter (zf-6) was wobbling back and forth more than usual. Still did this with a new balancer/pin, new injectors and new fpr. What fixed it for me was the ma mounts. Obviously they didnt fix an unbalance but are more solid than stock and dont allow the engine to move much and in turn the shifter stays put.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
