  #1
Old 06-09-2012, 08:56 PM
Sledhead's Avatar
Sledhead Sledhead is offline
Mountain Pass Machine
Default Engine Oil Cooler DIY
It's been several months in planning and sourcing but I've finally completed my oil temp weapon
Parts List which I filled from Summit Racing for $740:
FLD-DB30618 Fluidyne Oil Cooler
EAR-503ERL Sandwich Oil Adapter with Thermostat (modded by Super Diesel)
EAR-585112ERL Adapter Fitting -12AN (pair)
MRG-F12012 -12 AN 120* Fitting (Qty 3)
RUS-613190 -12 AN 90* Fitting (Qty 1)
MRG-R2512 -12 AN Rubber Hose (25' but only required 10')
The top of the cooler mounted nicely to the frame using 3/4" square aluminum tubing bolted through factory holes. Just be careful to center the cooler with the line fittings installed, there is only 1/2" of clearance. I fashioned the top air dam from black plastic lawn edging.
The grill actually has to go in first. I used expanded aluminum about 27" x 9" and mounted it with the factory plastic fasteners. Super simple, cheap and it looks Nice, Really Nice!
The bottom cooler mounts went through a couple revisions but the end result was 1/2 aluminum tubing bent 90*.
The bottom air dam was more lawn edging.
Be very careful installing the drain plug, the aluminum one I bought decided to gall like a bastard just test fitting it finger tight. I had to chase the threads and clean it all up, then went with a brass plug.
The side air dams were painstaking; I hot-glued doorskin/cardboard templates in place then duplicated the pattern in .030" aluminum.
The lines are header wrapped where they pass under the manifold and to insulate them individually. You need more than 50' of 1" if you want to do them entirely. I recorded the lengths somewhere
Super Diesel ported the sandwich adapter for full flow, thanks Michael! There is nothing less than -12 AN in the entire route.
Thanks to all that contributed to the R&D (Rip-off And Duplicate) of this project; Michael at SD, Hondarider Brian, Trent, everyone in the Oil Cooling threads and even KB.
I'll post results soon as I'm going MIA; Messing In Alberta
__________________
03 CC DRW 4X4 EFI Live, EPR Twins GMax-5
  #2
Old 06-09-2012, 09:23 PM
malibu795's Avatar
malibu795 malibu795 is offline
Default
very nice!
__________________
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
Quote:
smooth seas never made a skillfull salior
  #3
Old 06-09-2012, 09:43 PM
BLKLMM's Avatar
BLKLMM BLKLMM is offline
<<< Slow Mamba
Default
__________________
Mamba
Special thanks to...
Rob @ MK Chevrolet
Mike L. @ Inglewood Transmissions
Dan @ PPE
Kory Willis @ Power Performance
Will Petty @ Troll Performance Tuning
Steve @ SS Diesel Tuning
Ben @ BT Diesel Works
McRats
10.62@134
Born 1/21/12
SOCAL DIESEL TRUCKS
  #4
Old 06-09-2012, 10:32 PM
JMK777's Avatar
JMK777 JMK777 is offline
16's, but i keep em clean
Default
Nice write up
__________________
2001 lb7, suncoast IV-1057 by Inglewood, JMK hidden traction bars and bump stop relocate kit, JMK S/S tie rod sleeves,QA1's, modded waste gate, EFI live ,JMK stinger exhaust, Aeromotive tsunami fuel pump , stock charger 12.71 @ 107mph
2005 lly ccsb 4x4 white all stock with a small tune.soo fresh and soo clean clean
2002 lb7 ecsb 4x4 white needs injectors and fix trans
sheet metal workers local 104
  #5
Old 06-09-2012, 10:57 PM
LBZrcks's Avatar
LBZrcks LBZrcks is offline
Default
Quote:
Originally Posted by JMK777 View Post
Nice write up
X2
__________________
CTS-V Sedan, Stuff, 724RWHP
16' ATS-V Coupe, Frost White Edition
Previous Dmax's
06' Chevy 2500HD CCSB 4x4, EFI Live, PPE GT40/GTX45 Twins, Socal 60s, Mike L. Trans
08' Sierra LMM CCLB Z71, Mike L. Trans, EFI Live, McRat Racing Tune 12.97@102.73
06' Sierra LBZ RCLB 4X4, Mike L. Trans, EFI Live, McRat Racing Tune 12.25@111.30
06' Chevy LBZ CST 9-11 Candy Red and Chrome
04' Chevy LB7 FabTech 8" Suncoast III w/TTS Converter
  #6
Old 06-10-2012, 02:42 AM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
Very cool and very clean install Glad to help!
__________________
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.85 @ 145
06 Cummins cc/sb EFI by Hardway.
Tailgate Member #1 I prefer the backdoor
  #7
Old 06-10-2012, 04:17 AM
blk smoke lb7's Avatar
blk smoke lb7 blk smoke lb7 is offline
<-----Lots of green $
Default
Very awesome and nice write up and thanks for passing on the info
__________________
04 LB7 CC/SB EFI live, S366,S483 , Born again 08/10/2011 11.64@117
Some wicked tuning by Bo-Bo (Bob olson) Thx Bob
Quote:
Originally Posted by flyinelvis11
i'll let you use anything i got except my wife and my truck; it's too easy to throw a rod in either one):h
Quote: Carter 44
Boost is like a hot girl with an STD...you know you want to hit it but your afraid of the consequences
rollncoal07:Twining is wining
Quote:
Originally Posted by McRat View Post
You come off as a Timeshare Condo salesman on this site.
If you were helping folk with problems, or asking for input on your problems, it might be different, but from where I see, you are only a little different than the Russian spammers selling iPads that we delete.
Act like more of a human, and less like a spambot, and you'd probably catch less heat. This is "family", and it's our corner bar, and a group of guys with grease all over them leaning over fenders of somebodies truck that ain't making the right boost.
It's also one of few sites with more hardcore wrenches and racers than wannabees.
You're welcome to be a member here, and post about your build, but don't expect people to shower you with roses yet. That comes with seat time on the site, and on the track.
  #8
Old 06-10-2012, 06:42 AM
super diesel's Avatar
super diesel super diesel is offline
<<<< Under Pressure
Default
Very clean write up and install! Way to go and thanks for the info and pics Sir. This is coming along nicely. Lets see some more of these.
Also, for those using the factory GM lower valence that lives in hotter climates, you may need to slit it open some on the bottom and top for increased air flow to the cooler. GM didn't give us much to work with there and zilch on some of the chevs. The LMLs Have a nice big opening to work with.
__________________
FOR REAL POWER: Remove the static wire from ovulation bearing and let her run!
McRat Racing, SoCal Diesel, Ridge Runner, Mike L. Special, PPE, Creatures of the Night Performance
Michael
OIL COOLING CLUB
CC LB7 4X4 Dually GMC with Fluidyne oil cooler
CC LLY 4X4 3500 SRW with oil cooling coming (stock with a few goodies)
Currently for street driving and towing GT4202 and Dual Fueler from PPE
Carrillo rods, Heads, balancing, cut pistons, Head studs, Injector clamps from Guy at SoCal
Tune by Tony at Ridge Runner (Clark Kent special)
Moded LBZ CP3s and special fuel system by Super Diesel
SC Trans w/snake oiler and cooler by Mike L.
Blowoff and Wastegate by Tial
Various machining touches, built and fabed by Super Diesel
Broke motor #2 becomes built motor #4
New motor and trans oil purifiers available (dual and single elements) and vital fluid cooling components. Start saving your truck today!
SUPER DIESEL 720-404-7553 Please leave message if no answer.
  #9
Old 06-10-2012, 08:01 AM
Dragonsfireloki Dragonsfireloki is offline
Default
Looks damn fine, can't wait to hear how the results turn out.
__________________
06 ECSB- My toy- lots of PPE goods, ARP, lifted, TDK grill guard, stock bottom end
07 CCLB- Work truck- stock so far
EFI and Fabtech traction bars coming soon
  #10
Old 06-10-2012, 08:30 AM
05chevy's Avatar
05chevy 05chevy is offline
Default
looks great. Where can I get one of thise adapters?
__________________
05 lly, s475, 40% nozzles, stock cp3. 11.69 @115
685hp/1100ftlb
97 12valve
  #11
Old 06-10-2012, 09:06 AM
SIKDMAX's Avatar
SIKDMAX SIKDMAX is offline
Highway Burnouts!
Default
Neat!
Do you have any type of aftermarket oil temp gauge or are you relying solely on the cluster to tell some sort of change?
__________________
Matt...2008 Chevy DMax CCSB 4x4 LTZ LMM
Carillos, Mahles, ARP 625s, SoCal Cam, Stage 1 Heads, 60% sticks, PPE Dual CP3, HTT 66SS/GT4718R Stainless Steel Twins, PPE High Flow Intake Manifold, Up Pipes and Headers. 6" MBRP single stack. Mike L. Suncoast 4 w/ 1057
  #12
Old 06-10-2012, 09:22 AM
Getting faster
Default
Think he has a oil temp gauge Matt. Although oil pressure can tell how hot the oil is getting...
__________________
"OldManTan"
  #13
Old 06-10-2012, 09:24 AM
SIKDMAX's Avatar
Highway Burnouts!
Default
__________________
  #14
Old 06-10-2012, 09:29 AM
1953drtelco's Avatar
1953drtelco 1953drtelco is offline
Default
Just curious on the use of the adapter. I already have the remote bypass Oil Filtration from Amsoil. Would it be possible to tap off the output of the Amsoil adapter and run it through the Oil Cooler before it passes through the oil filters?
__________________
(SOLD) 2005 HD2500 Silverado 2WD
2015 Silverado (Duramax) 4X4 Mostly stock, but upgrades are already being planned.
  #15
<<<< Under Pressure
Default
Quote:
I'm modding them for folks. The way it comes there is not enough flow through it to supply at the higher RPMs. I double the flow through it to insure oil starvation is never a problem there. They come from www.summitracing.com .P/N: EAR-503ERL. Some folks just ship them straight to me and I send it to them fixed up.
__________________
Michael
OIL COOLING CLUB
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
