  #1
Old 06-05-2012, 07:24 PM
REW_388's Avatar
REW_388 REW_388 is offline
FNG
Default LB7 Batmowheel Review
Long story short its worth the money but not worth the work.
**Before you start buy a 2.00 gasket for the oil drain (dont use silicone it will leak TRUST ME) and a metal flange gasket that goes between the inlet and exhaust side of the turbo in the v band groove, also I used some high heat red silicone for the turbo front cover and black silicone for the intake horn.
I did this install about a month ago and so far am loving it. I have yet to have my truck retuned for the wheel but with running the same tunes as before I have seen a difference. The turbo definately flows more air now and power is increased throughout the entire rpm range but I can tell my turbo definately is lighting faster. Where I have really seen this part shine is in throttle response but most of all with towing. Running on the same roads with the same load as I have done numerous times with the stock charger I needed tow haul mode I now am no longer using that unless I feel the need for the grade braking feature. For those of you who are looking for whistle this wheel definately gives you that, from 3psi and up you can hear this baby whistle at ya (even over my 35 mts and dual 6" stacks). A part I would definately recommend is a Banks or BD wastegate; I ran this wheel with my stock waste gate for a couple weeks and had the problem of it making my stock wastegate blow off prematurely (dont ya hate it when that happens :rofl ). I talked to Tim at SJD about this observation and he said that another alternative to the wastegate would be a ppe boost increase valve but neither of us have tested this idea out.
Now to the negative. The price is right for these wheels but damn does it suck to put this part in. If you have ever takin your turbo apart or have a friend that has then this will be a breeze but if you have never done it before then put aside a whole weekend to do it. One big mistake I made that ate up alot of my time was I tried to take off my front cover prior to splitting the turbo apart at the v band. There are people that can do this according to this forum but after three hours of trying to get one bolt out and numerous trips to town to borrow tools and buy wrenches to bend in numerous ways I decided to undo the band clamp and take the turbo apart there then take off the front cover. The other recommendation I would make is wait till you have to change your injectors or your cp3 to do this install. I have done both and wished I had this wheel when I did those installs cuz to install this wheel the entire valley of the block has to be cleared out. Intake, air horn, ficm, fuel lines, y-bridge, coolant lines, wastegate, and Im sure a few other things I am forgetting; which all have to be removed to do an injector pump or injectors. Also this would be a good time to put a portedx intake horn on or a ProFab intake horn if you ever plan to do one.
On this install my best friend was a magnet and 1/4" drive socket set, get one in metric with numerous extensions and a swivel joint. Most every other tool I used can be found in most everyones tool box; screw driver set, 3/8 drive socket set, metric wrench set, 3/4 combination wrench, chisels/punches, allen wrenches, pliers of different sizes and I know I am forgetting something.
I will try to get pictures up soon but if anyone has any questions send them my way and I will do my best to answer them. I would have done a write up but my install started at about 2pm drug on till 3am then started over at 6am the next morning so I wasnt really in the mood to type everything I was doing on my phone. Sorry guys
  #2
Old 06-06-2012, 08:12 PM
REW_388's Avatar
FNG
Default
  #3
Old 06-06-2012, 09:16 PM
duramaxdiesel's Avatar
duramaxdiesel duramaxdiesel is offline
Dmax Nut
Default
Nice write up and info
Nick
__________________
2001 Chevy K2500HD Duramax/Allison Ex/Sb...Waaayyyyy far from stock;-)
2001 Chevy 3500 Dually Reg. Cab Duramax/Allson...Stock other than a Juice Box
2008 Chevy 2500HD Duramax/Allison CC/SB with some more info to follow...
  #4
Old 06-07-2012, 04:55 AM
JustinD's Avatar
JustinD JustinD is offline
Plow Truck
Default
How do you think it would be with a ZF in a CC dually?
__________________
2001
II S366
12.65 @ 105 stock turbo
Thanks to:
Samson
Jeff Toman
Johnny
James Dow
James R
Jeremy and the guys @ WDP
  #5
Old 06-07-2012, 06:01 AM
streetwise's Avatar
streetwise streetwise is offline
Default
You are dead on it is a pita. I have the wastegate problem I did this install two weeks ago. All of the things you talked about removing and add cali emissions. My banks wastegate will be here on Friday. PPE boost valve does not work tried it. My wastegate is blowing open at 6-8 lbs. I agree Batmowheel is worth the money a great upgrade but the install is not for everyone. With some tuning it will be well worth the install. I will be having Mark at danville tune it in a few weeks.
__________________
2007 Silverado 2500HD - MBRP 5" Turn Down, MBRP Down pipe, MBRP Hot Side Intercooler tube, PPE Manifolds and Uppipes, Flex a Lite Electric Fans, Edge Insight, AEM HD intake, FASS 150, Merchant MA700, Merchant Pump Rub Kit, BDS 7" High Clearance Lift with Fox Shocks, American Force Evo SS 22x10, Nitto Trail Grapplers 325/50/22. Amp Research Power Steps, Weatherguard 28" toolbox, Custom Extang Solid Fold cover for 28" tool box, Tuned by Mark Broviak at Danville, Wagler Efi Commander, Garrett AVNT4094, SDP EGR Delete, Merchant PCV Reroute, Merchant transfer case brace, Merchant Motor mounts. Crank it up Sleeves and centerlink, Traction Bars by Kat Kustoms.
  #6
Old 06-07-2012, 06:38 AM
SparkZ03DMAX's Avatar
SparkZ03DMAX SparkZ03DMAX is offline
Default
Could we see a video?
__________________
2001 Chevrolet LB7 Duramax
S366, ARP Head Studs, 5" intake, Suncoast Trans, Airdog 165, Trac Bars, 5" Exhaust, Dsp5, 50 coats of wax.
Special thanks to: ATP Trucks, Suncoast Transmissions, and Mr. Poole
  #7
Old 06-07-2012, 08:12 AM
bluecollar's Avatar
bluecollar bluecollar is offline
Default
For the bottom bolt on the cover that is the worst..I took all the rest of the bolts our then took a rubber hammer and tapped on the cover and turned it until I could get to that pita. Bottom bolt hope this helps
__________________
01 cc dually, 33/12.5/16 truxus sts, s463, dual fueler, 100% injectors, 5inch intake, air dog 200, lml bottom end, head studs, dts built trans, ddp tuning
700hp/1400tq
  #8
Old 06-07-2012, 09:45 AM
CrewCabMax CrewCabMax is offline
Double XL
Default
You shouldnt have to remove the front cover in the truck if your going to split the charger, correct?
__________________
2004 GMC CCSB LB7
Stock
  #9
Old 06-07-2012, 10:20 AM
streetwise's Avatar
Default
You are correct.
__________________
  #10
Old 06-07-2012, 10:38 AM
bluecollar's Avatar
Default
Quote:
Originally Posted by streetwise View Post
You are correct.
X2 just wanted to let ppl know u can get to that bottom bolt if there set against splitting the charger
__________________
700hp/1400tq
  #11
Old 06-07-2012, 11:37 AM
Double XL
Default
Split it and forget it! LOL It is much easier on the bench! LOL
__________________
2004 GMC CCSB LB7
Stock
  #12
Old 06-07-2012, 12:05 PM
streetwise's Avatar
Default
Little late for that bit of information. Hind sight is 20/20. By the time you get through the Cali emissions garbage that bolt not to bad.
__________________
  #13
Old 06-07-2012, 12:09 PM
bluecollar's Avatar
Default
Quote:
Lol ya I hear ya.. I guess that's just the way I did it didn't read up on it much before I did.. took me 8 hours.. and X2 one the wastegate issue that ppl are having after the wheel.. my wastegate also opened sooner after
__________________
700hp/1400tq
  #14
Old 06-07-2012, 01:17 PM
streetwise's Avatar
Default
I did no research just listened to a friend on how easy it was going to be. We did not take cali into account. Now I am preparing for a heads up emissions delete. Going to teach that #h!t a lesson.
__________________
  #15
Old 06-08-2012, 10:16 AM
REW_388's Avatar
FNG
Default
Justin d I think it would go great with a zf6 cuz this gave me more bottom end which on a heavier truck like yours that would be a great thing and with that manual you will be able to hold that higher boost level for a lot longer
Also as for splitting the charger vs removing the front cover I prefer splitting it simply so I can hold my exhaust wheel to remove the nut for the inlet wheel. After 290000 miles that nut was on there pretty damn good and the last thing I wanna do is bend my shaft
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
