  #1
Old 05-29-2012, 12:38 PM
xtremebikr04's Avatar
xtremebikr04 xtremebikr04 is offline
Default Need help replacing leaf spring bushings.
I attempted to put my 3 inch drop shackles in over the weekend and ended up having to cut a couple of the bots and fully remove the springs from the truck. Upon doing so I noticed my leaf spring bushings are all cracked and should be replaced. Whats the best way to go about removing the old bushings? I was planning on replacing with energy suspensions poly bushings.
__________________
2006 2500HD ccsb 4WD LBZ
  #2
Old 05-29-2012, 01:02 PM
TrentNell's Avatar
TrentNell TrentNell is offline
Finally underway !!!!!
Default
I have always used a "shop press" , and pressed them out , I have heard of guys "burning" the rubber out and then using a hammer and chisel to get the metal sleeve out in a pinch but have never tried it .
__________________
Trent Nell
01 DMAX 2500 HD = Extreme Prejudice -> EPR Triple turbo Kit, EPR Allison Transmission, Aria's Forded Pistons, Howards Xbeam Rods , Built Engine, Ported Heads , Stage 2 cam, and Gorilla Girdle all by Randy's Engine And Machine , PPE Dual CP3's with 120% stroker pump , DDP 47LMP Injectors , 2-BD Diesel 165 GPH lift pumps , Frozen Boost W/A Cooler , 4link with coil overs at every corner , and a bunch of stuff I am probably forgetting.
9.87 @ 143.56, DA=6550
www.extremeprejudiceracing.com
2001 GMC CC/LB "The tow rig" , EPR Triple Turbo's EPR Trans , EFI live , RDL Headers and mouth peice, 305/55 R20 Coopers , 5" exhaust .
  #3
Old 05-29-2012, 01:10 PM
Default
Quote:
In all my searching I was seeing people would burn them out but i dunno if I wanna go that route. Probably just be easier to find a shop to press them out. Do the poly bushings need to be pressed in?
P.S. Engine should be ready in the next few weeks
__________________
  #4
Old 05-29-2012, 01:53 PM
Leadfoot's Avatar
Leadfoot Leadfoot is offline
Needs Bigger Tires!
Default
I've burned them out, pressed them out, combinations of those two, etc.
Burning is a PITA and smells and smokes, plus the rubber ends up being burn your skin hot.
If you use a drill and drill the rubber repeated around in a circle between the outside edge and inside collar, then press them out (balljoint press with big "cup") works best. Then a hammer and chisel to collapse the outter sleeve and pull it out. Takes a little bit of time, but works well, no smell and no fuss. The biggest "issue" is the shavings created by repeatedly drilling the rubber but that's easy cleanup with a vacuum or dust pan.
__________________
2006 GMC CCSB 4WD McRat EFI Live , Kennedy dual lift pumps, Champion Stage IV tranny, Mike L converter, cooler and C3 oiler, Suncoast Brace, Eaton E-Locker, Caltracs, homemade pulling hitch, homemade limit blocks, H2's and cooper STT's, Predator, MBRP Cool Duals (not kitty or muffler), EGR blocker, Finger Stick, and all on headlight mod.
80 K20ish Reg Cab Long Bed, Full Roller 496, Manual TH400, Torque Converter Techniques converter, 3:1 planetary setup, NP205, High Angle driveshafts, 4.56's, 35's, Lockers F&R, Dakota digital dash, and custom interior.
www.matpa.org
  #5
Old 05-29-2012, 03:47 PM
TheBac's Avatar
TheBac TheBac is offline
Default
I took a chisel and wedged it into the slit where the spring eye comes back around. This "opened" the area surrounding the bushing just a little. Sprayed some lubricant between the spring eye and the bushing, too.
I then took an air chisel and folded the lips that overhang the spring eye back over onto the bushing on one side. There is one side that has shorter lips than the other, I did that side.
Then I just switched to the air hammer, and using a socket as large as the outside of the side of the bushing with the folded lips, I "pushed" it right out.
I installed the Caltrac aluminum bushings using the air hammer and socket, so I think it would also work for OEM style too.
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"Flyin' Brick" -- 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the fun little DD
"The Bigger Boat" -- 2011 Workhorse P700 - 6.0LS/Allison - what I drive at work
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #6
Old 05-29-2012, 03:53 PM
Evan@LimitlessDiesel's Avatar
Evan@LimitlessDiesel Evan@LimitlessDiesel is online now
yerp
Default
I ground the outer lip off,set the leaf on a couple blocks of wood and beat it through with using some PB a big hammer and a socket. I could of brought it down to the shop and pressed it out but whats the fun it that.
__________________
Limitless Diesel Performance
413-770-3585
  #7
Old 05-29-2012, 05:17 PM
Default
these are some good ideas guys! I might end up giving one and or a combinatoin of these a try and see what happens.
__________________
  #8
Old 05-29-2012, 05:41 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
Why the need to fully remove the springs for 3" shackles? I just put mine on my LB7 this weekend, took an hour.
__________________
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.72 @ 150.
06 Cummins cc/sb EFI by Hardway.
15 Cruze diesel
Tailgate Member #1 I prefer the backdoor
  #9
Old 05-29-2012, 05:44 PM
yerp
Default
Quote:
I know on mine the bolt in the upper shackle was so frozen I had to take the pack out to get it out.
__________________
413-770-3585
  #10
Old 05-29-2012, 07:17 PM
Getting faster
Default
Then im lucky, mine slid right out
__________________
"OldManTan"
15 Cruze diesel
  #11
Old 05-29-2012, 08:58 PM
jmaz268's Avatar
jmaz268 jmaz268 is offline
Lead from the Front
Default
Mine was the same way....had to press the bolt out. Shit sucked.
__________________
John
http://www.duramaxdiesels.com/forum/signaturepics/sigpic5837_2.gif
  #12
Old 05-29-2012, 09:19 PM
jlawles2 jlawles2 is offline
Default
To remove my bushings, I fired up the propane burner on low, set the spring on there and watched it burn/melt. After that was done, I took the air hammer and a punch and folded it in on itself on the small side and it slid out.
To put the new urethane bushings in, I used grease and stood on it. If that does not work, get a piece of threaded rod and a large socket. Use the threaded rod and a washer to pull the bushing into place.
__________________
Silver Birch Metallic 2004.5 GMC K2500HD with 265/75's
Banks super scoop, tubing, intercooler, and cat back with the IQ on the Window (for now). BD driver side Exhaust manifold.
Airdog 150 on frame rail. Amsoil synthetics for lubrication, and dual Amsoil filters on the driver frame rail. PPE centrifuge install.
EGR blocked. PCV rerouted. Resonator blocked (reinstalled for looks). Bladerunner installed. Dead kitty by MBRP (front pipe) and down tube replaced with the MBRP (heat wrapped from the turbo down to the front pipe).
Performax Gauges by ISSPRO in pod over mirror and overhead console (console pod by PPE). Mike L Transmission.
----Looking to do an onboard air with a set of truck air horns. Want Nathan K5LA's but not in the budget at the moment.----
06 GMC CCSB 2WD LBZ SLT package. Traded for '17 Denali
18 Denali CCSB 2500 4WD Mineral Metallic with Cocoa/Dark Sand Interior
  #13
Old 05-30-2012, 04:14 PM
Default
The upper bolts were seized right into the spring themselves. Had the hitch and bottom bolts out in 30 min and thought man this is going way to easy....
It was a success getting the bushings out tonight after work. I used the drill method running it around the outside and it actually slowly worked the bushing right out. Then used an air hammer to get the sleeves out. Id say took about 1 1/2 hours. Most of the time was firguring out the first one. Thanks guys for your help!
__________________
  #14
Old 05-31-2012, 05:37 PM
moss's Avatar
moss moss is offline
<--good vibrations
Default
X2!!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
