  #1
Old 05-18-2012, 05:41 PM
Devon's Avatar
Devon Devon is offline
broke my curse
Default Airdog 150 only running 5-6psi?
Ok so I hooked my fuel pressure gauge up to the factory fuel filter bleeder. Using a Glowshift gauge with a electronic sender unit in te bleeder port. The truck runs strong but it is only reading 5-6psi? And will drop close to 2-3psi WOT, which I know will happen. But shouldn't the pressure be atleast 8-10psi? I put a new fuel filter on and waiting for my Airdog filters to come in so I can change them aswell. Would a dirty AD fuel or WS filter make the pressure lower? I am contemplating on stretching the spring some if the filters don't fix the issue. Good idea?
__________________
04.5 CC/SB LLY SLT
DJM/McGaughy 2/4 drop,BigDipper Stage IV Trans kit!w/precision converter,S472 single turbo,Tuned by Tony Martino(moonshine)
12.95@103.5 1.79 60'(stock turbo)
  #2
Old 05-18-2012, 06:13 PM
JRODS*LB7's Avatar
JRODS*LB7 JRODS*LB7 is offline
Default
i have the same prob! does your guage bounce around?
__________________
06 ccsb
efi live dsp5 BT tunes
4"mbrp
Airdog 165
Built Trans (BT DW)
20x12 -44 off fuel Hostages
Rancho 9000 xl
  #3
Old 05-18-2012, 06:53 PM
03_DMAX's Avatar
03_DMAX 03_DMAX is offline
Default
Probably the junk glowshift gauge
  #4
Old 05-18-2012, 08:39 PM
Grizz3500's Avatar
Grizz3500 Grizz3500 is offline
Default
My AirDogII 165 came with the pressure set at 11-12 psi according to my gauge. Gauge seems to bounce around a little, but no more than .5-1psi.
__________________
2006 Chevy 3500 4x4 EC/LB, LBZ (40,000 miles)
IdahoRob, Mike L. IV/Cooler, Danville 66mm, II 40's, Adrenaline Y-Bridge/Trans Brace, AirDogII 165, S&B CAI, Merchant Pump Rub & Sleeves, Diamond Eye DP, MBRP 4'', SportComp II PC gauges, Rancho 9000's, 62" Traction Bars, Cognito Braces, Airlift Wireless Air & PacBrake Bags
Patrick
  #5
Old 05-19-2012, 12:17 AM
Devon's Avatar
broke my curse
Default
Hell yeah, it jumps around. Piece of shit
__________________
04.5 CC/SB LLY SLT
  #6
Old 05-19-2012, 03:43 AM
JRODS*LB7's Avatar
Default
Quote:
Yeah dude same here im gonna ditch the biatch and throw a reliable guage right on the test port My boost and pyro are fine , just the darn fuel psi
__________________
06 ccsb
4"mbrp
Airdog 165
Built Trans (BT DW)
Rancho 9000 xl
  #7
Old 05-19-2012, 05:29 PM
Devon's Avatar
broke my curse
Default
Same here lol
__________________
04.5 CC/SB LLY SLT
  #8
Old 10-24-2012, 03:13 PM
1slomax's Avatar
1slomax 1slomax is offline
Default
dont feel bad about the gauge moving my auto meter cobalt does that to
__________________
06 lbz SoCal engine Big Dipper trans big single 60s dual pumps 3/5 drop
  #9
Old 10-24-2012, 04:15 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Default
Yes filters will lower psi a little. As long as you have positive pressure at wot then don't mess with the ad.
__________________
2006 ccsb Lbz Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples
  #10
Old 10-24-2012, 04:24 PM
1SIKDZL's Avatar
1SIKDZL 1SIKDZL is offline
Default
I have been through three glow shift fuel gauges in the past year. I just got a replacement in the mail 2 weeks ago and it started bouncing around this weekend and is now stuck on 30 psi all the time. Pyro and boost have never given me probs, just the damn fuel gauges.
__________________
05' LLY, EFI Live, FASS 150, AFE Intake, 5" straight pipe, Diamond eye down pipe, ProFab EGR delete, PPE ported fuel rail fitting, PCV rerouted, resignator plugged, LBZ mouth piece, 10" cognito lift, 37s, Cognito HD tie rods and steering braces, steel braided brake lines, blue LED interior conversion, 10000k HIDs and fog lights, AMP electric steps, Color matched plastics, Escalade white face gauge cluster
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
