  #1
Old 05-15-2012, 05:16 AM
madmax02 madmax02 is offline
Gearhead
Default Batmowheel questions
Do you have to pull the turbo on a lb7 to install a batmowheel? Seems like most guys like them for a cheap effective power upgrade.
__________________
2005 Sierra LLY
Huron Speed 3" Bridge, 3" Cold & Hot Charge Pipes
4" Intake, LBZ Mouthpiece, 5" Exhaust, 3" Downpipe, Edge CTS
MoonShine Autocal
Egr delete, PCV Reroute.
  #2
Old 05-15-2012, 05:27 AM
Porno Joe Porno Joe is offline
Default
no
  #3
Old 05-15-2012, 06:25 AM
Gearhead
Default
Does the downpipe have to be unbolted and pulled away or basically pull the turbo inlet out unbolt and pull old wheel off and slide new one on?
__________________
2005 Sierra LLY
MoonShine Autocal
  #4
Old 05-15-2012, 06:50 AM
jmaz268's Avatar
jmaz268 jmaz268 is offline
Lead from the Front
Default
Will need to pull the downpipe at least out of the way to you get access to the backside of the shaft to put a ratchet on it.
__________________
John
http://www.duramaxdiesels.com/forum/signaturepics/sigpic5837_2.gif
  #5
Old 05-15-2012, 06:53 AM
JustinD's Avatar
JustinD JustinD is offline
Plow Truck
Default
All that work, you mine as well upgrade the turbo?
__________________
2001
II S366
12.65 @ 105 stock turbo
Thanks to:
Samson
Jeff Toman
Johnny
James Dow
James R
Jeremy and the guys @ WDP
  #6
Old 05-15-2012, 07:10 AM
05dmaxdriver's Avatar
05dmaxdriver 05dmaxdriver is offline
KCCO
Default
batmo kinda a waste of time and money imho
__________________
05 LLY
  #7
Old 05-15-2012, 07:13 AM
Dirtymaxx03's Avatar
Dirtymaxx03 Dirtymaxx03 is offline
Default
Quote:
X2
__________________
Sean
2003 Lb7
Efi Live
The Rabbit-build in progress
1984 2wd SB c10
Quote:
Originally Posted by hondarider552 View Post
big balls if you measure in seconds of duration
  #8
duramax hd's Avatar
duramax hd duramax hd is offline
Default
The turbo does not have to come out to upgrade the wheel. The comp cover is a mother to get off though. Be prepared to take the y-bridge out and cut up some wrenches to get it off. The downpipe does need to be un-bolted and moved out of the way as stated above.
__________________
2001 Dmax/Alli CC/SB Pewter
RIP stock Rods and block....9/2/12....Built motor 12/12/12-Failed. On the road back to stock. Moonshine Tuned, Dipper trans, Mike L. Cooler,Ultra Predator 8's on 285/55/20 BFG G-Force's
  #9
Old 05-15-2012, 07:16 AM
Default
I did the batmo on my lbz, because i was doing a full egr delete at the time and right then and there its not much more work. I really like it.
Yes you would have to disconnect the downpipe to get to the nut in the exhaust housing so you can unbolt the compressor wheel.
  #10
Old 05-15-2012, 07:19 AM
JustinD's Avatar
Plow Truck
Default
A down pipe on an LBZ is walk in the park compared to an LB7, if your lucky the bolts will come out, if they are seized its a bitch.
__________________
2001
II S366
Thanks to:
Samson
Jeff Toman
Johnny
James Dow
James R
  #11
Gearhead
Default
Ok. Plans would be 3" downpipe at the same time. So the compressor housing(front of the turbo) has to come out to?
__________________
2005 Sierra LLY
MoonShine Autocal
  #12
Old 05-15-2012, 08:09 AM
Default
Yes, thats where the wheel is.
But i forgot like Justin said downpipes are different on the LB7 so this could be a royal pain in the ass for you
  #13
Old 05-15-2012, 08:25 AM
Gearhead
Default
Yes I heard it is...
__________________
2005 Sierra LLY
MoonShine Autocal
  #14
Old 05-15-2012, 08:47 AM
Bustedknuckles's Avatar
Bustedknuckles Bustedknuckles is offline
Honey Badger
Default
Totally not worth it.
__________________
04 lb7: 06 front clip, EPR s366, 30% over injectors, ARP head studs, Idaho-Rob tunes, airdog, PPE trans, Precision ML converter, etc......
  #15
Old 05-15-2012, 08:52 AM
bluecollar's Avatar
bluecollar bluecollar is offline
Default
I. Would do it again... wish. I would if dynoed my truck before the wheel for results but I put down 561hp
Posted via Mobile Device
__________________
01 cc dually, 33/12.5/16 truxus sts, s463, dual fueler, 100% injectors, 5inch intake, air dog 200, lml bottom end, head studs, dts built trans, ddp tuning
700hp/1400tq
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
