  #1
Old 05-05-2012, 05:55 PM
workin' diesel workin' diesel is offline
factory tuned
Default High Output Alternator
Mt alternator is going to crap. The bearing is squeaking. I need something high output at low RPMs. Found one by power bastard that puts out 125amps at idle and 250 amps at 1,200 RPMs. Sound good to you guys? Any recommendations? I already have an extra harness for the high output. Any of the vendors here sell something like it? I plow snow, so it is a necessity! Thank you!
  #2
Old 05-06-2012, 06:51 AM
rcr1978's Avatar
rcr1978 rcr1978 is offline
Default
The ones that come on 06 to I think 2010 Dmax's are bigger don't remember exact specs maybe someone else will speak up. I know they fit I put one on a 02 a few months ago because I had a spare laying around wish I would have put it my 04 instead.
__________________
04 LB7 ECSB Built motor, Wagler billet narrowed Rods, Callies billet crank, Mahle Race Cast pistons, Randy's Girdle, Wagler/Callies Stage 1 alterfire cam, Exergy 100% SAC's, dual CP3's, Randy's race ported heads, Profab cast flow/up pipes, and S475 over stock twins for now more later.
2010 LMM CCLB-Tuning/Exhaust
2015 LML Cab and chassis- Tuning/Exhaust
  #3
Old 05-06-2012, 07:03 AM
S Phinney's Avatar
S Phinney S Phinney is offline
Default
You can by a 145 amp from Oriellys for about 160 bucks. The OEM is 105 amp.
__________________
03 GMC 4x4 CC/SB Intake, Dual Exhaust, built motor by Me, Cognito Kryptonite Suspension upgrades, Custom Traction Bars by Me, Suncoast Trans, 1055-1 Convertor, Two AirDog II 200's, Billet Sump, Venom Tuning AKA Me, Custom Fabbed Fuel system, Flexlite Fans, Best Time to date 7.14 at 98.21 mph 1211.8HP 1954.5 FT/Lb torque
2013 LML Daily Driver, 5" FloPro Exhaust, Venom Tuning, Ad 165 4G Lift Pump, Upcoming HSP Billet Bridge And Piping, Upcoming CP3 Conversion
  #4
Old 05-06-2012, 08:20 AM
DougSmith DougSmith is offline
Default
If you buy an alternator for less than $250 your getting junk! Been there, done that TWICE!
I got a mean green Alternator hand made in Latrobe Pa that spits out 220 amps and idles at a TRUE 90 amps, not some drummed up numbers.
$279, I picked it up. Had it in 2 trucks now. My 01 first, transplanted into my 06. That is 6 years old fellas! You can keeo that O reilly's junk!
www.mean-green.com
Sent from my PC36100 using Tapatalk 2
__________________
Stealth Gray Metallic CC/LB LBZ 2006
Running all Schaeffer Lubricants
Edge Evolution CTS RACE
MBRP Full 4" exhaust, AFE Pro Guard 7 intake system
Nicktane Fuel Filter
Fingered and Stuck by Fingers himself
Dieselrite Coolant filter
Green Machine 220amp alternator
Extang EnCore folding hard cover
  #5
Old 05-06-2012, 09:12 AM
1953drtelco's Avatar
1953drtelco 1953drtelco is offline
Default
X2 on the O'reilly junk. My cousin didn't have enough money to buy a GM starter for her Saturn. Bought one at O'reillys (Lifetime guarantee) Which for me is a lifetime replacing her starter (So far on # 2, within 2 years) On the plus side, I'm getting really good at removing and installing the new starter
__________________
(SOLD) 2005 HD2500 Silverado 2WD
2015 Silverado (Duramax) 4X4 Mostly stock, but upgrades are already being planned.
  #6
Old 05-06-2012, 09:54 AM
THEFERMANATOR's Avatar
THEFERMANATOR THEFERMANATOR is offline
LEGALLY INSANE
Default
The stock alternator is an AD-230 and is 105 amp. The AD-244 was an option from 01 on for high output single applications(130 or 145 amp applications are both the same alternator), and is a great upgrade. They will put out an honest 80-90 amps at idle, and top out around 140 amps or so when they are hot. If you need alot of power, then I would do the dual upgrade option and go with dual 130 amp units. That should cover any power needs you would run across.
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, little of this, a little of that,
DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, custom tuning by me, KENNEDY single pump and pump rub kit.
  #7
Old 05-06-2012, 11:11 AM
MadMaxx61's Avatar
MadMaxx61 MadMaxx61 is offline
Devilmaxx
Default
I have the stock dual 125 amp alternators and love it I am never in need of more power.
__________________
Steve
2008 2500HD 4X4 LTZ Z71 6.6L LMM
Mods: EFILive, MBRP 4" DPF Delete, BD Manifold, SD Manifold, SD Center Link, SD Sleeves, S&B Intake, FS-2500, PPE Trans Pan, Bushwacker fender flares, PPE Oil Centrifuge, And other non-go-fast things.
Things still need to put in: PCV Re-Route,Air Dog AD-200.
1984 GMC Jimmy 2-Door
1998 Buick Century Limited
Sold It will be missed. 1985 Mercedes 300SD - Running still need work.
Sold It will be missed. 1995 C/K 3500 4X4 Dually 6.5L
Mods: K&N air intake, 80Hp chip, 97 cooling, twin fans, #9 Resistor, FSD Heat-Sync, Full Pillar 3 Gauge (EGT, Boost, Transmission),
  #8
Old 05-06-2012, 12:42 PM
ChevyTruck's Avatar
ChevyTruck ChevyTruck is offline
Boats an Hoes!
Default
Off Topic Question: If a truck is not equipped with dual alternators, would the wiring harness be equipped with the plug for the second alt?
__________________
-RJ
13.88 @ 101.96, 2.20 60'
2K4.5 Silverado 2500HD LLY Duramax
Big Dipper Level 4 Allison Transmission
MoonShine
www.COTNP.com
  #9
Old 05-06-2012, 01:58 PM
factory tuned
Default
I have gone through a lot of alternators too. Hoping to look for something really good. The one from power bastards was $360! THe curent one on my truck is supposed to put out 119 @2000rs and 209 @ 6000rs.
  #10
Old 05-06-2012, 02:03 PM
ChevyTruck's Avatar
Boats an Hoes!
Default
Can you over charge a battery or even do damage?
__________________
-RJ
MoonShine
www.COTNP.com
  #11
Old 05-06-2012, 02:23 PM
Default
Cant overcharge as ling as the regulator is good.
No stock alternator will put out 90 amps at idle, get a voltmeter and read it. 40 to 50 if your lucky. Max output will vary by manufacturer by as much as 20 amps and 1,000 rpm.
If you have a camper with dual deep cycle batteries plus the 2 in the truck, plus lights, AC, Radio, fans and a couple cell phone chargers, you will be overtaxing a 145 amp alternator. You would be ok with duals.
I have a coolant filter mounted where the 2nd alternator would be, so I had to go bigger single. Mean Green is american made, stand by it and worth every cent. Like I said, mine is 6 years old and strong as the day I put it in.
Can you get cheaper? Yep. Can you get a better alternator? Nope.
6 years and 2 trucks later, still got mine and before that I had 2 in 2 years at $200 a pop. Mean Green was my choice for a reason. I had 5 batteries hooked up and a 2,000 watt stereo with dual dvds.
__________________
  #12
Old 05-06-2012, 03:34 PM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Default
I would do duals. Its been a few years since I was heavily into car audio, but we could never find dependable HO alternators.
IIRC you just have to buy a harness for the 2nd alt and its plug and play. Merchant was selling them at one point.
__________________
06 GMC 2500 CCSB SLT LBZ 4X4
These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
  #13
Old 05-06-2012, 06:07 PM
Default
I guess Dozer Boy never purchased a Mean Green. Must have been getting those cheap chinese ones.
__________________
  #14
Old 05-06-2012, 06:25 PM
LEGALLY INSANE
Default
I know my old bone stock CS-144 would put out an honest 80 amps at a 550 idle on my 6.5(could run all 6 lights, both airs on high, and never had a problem holding 14 volts at an idle). The AD-244 is doing just as good as it has never had a problem holding 14 volts with both airs, headlights, and the travel trailer hooked up running the fridge and charging the batteries in it.
__________________
  #15
Old 05-07-2012, 05:34 PM
factory tuned
Default
So I poped the belt off today and then spun the pully on the front of the alternator. It squeaks/chirps. The mechanic where we work says if I want to save a few dimes I could pull the altenator apart and put graphite dust on the bushings. Seems kind of temporary.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
