  #1
Old 03-26-2008, 06:30 PM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Default GM Trouble Codes - Master List:
Free From GM - OBDII Trouble Codes and troubleshooting checklist
This will be updated as necessary by GM and doesn't require $$$ subscription fees.
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
  #2
Old 03-26-2008, 06:37 PM
mvnvltn's Avatar
mvnvltn mvnvltn is offline
Part's Limit Tester
Default
Nice
__________________
2002 C/C Dually LB7
It has some (broken) stuff
  #3
Old 10-25-2010, 09:00 PM
wberg wberg is offline
wberg
Default code
Great Good to have
  #4
Old 10-25-2010, 10:14 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is online now
Default
Cool! Thanks!
__________________
  #5
Old 10-26-2010, 05:06 PM
smarquis's Avatar
smarquis smarquis is offline
Triple Turbo LBZ
Default
Is it accurate? For 2006, they don't list the LBZ.
__________________
2006 Chevy 2500 HD CCSB EPR Triple Turbos with a Cheetah 68, Turbosock, Air Dog II, Snow Performance MPG Max, EFI Live Tuning by Idaho Rob/Trent Nell, magnaflow converter, 4" Exhaust, EPR Stage Transmission with a SunCoast converter, and trans cooler from SunCoast/Mike L, Brake-man larger brakes up front with Brake man rotors/pads in the rear; 4" Cognito Lift with UCAs, heavy duty tie rods, front anti-sway bar, Pitman/Idler Arm Support Kit and steering braces, Zulastic shackles, Atlas Rear springs, air bags, and 285/65R20 BFG A/Ts on 20x9 BMFs.
  #6
Old 10-26-2010, 05:09 PM
McRat's Avatar
Diesel Hotrodder
Default
GM had a brain-furt in 2006. The LBZ was originally ID'd as LLY, badged at 310HP, made about 335 in real life, and has ZERO parts interchangeability with the LLY (maybe the fuel filter? Maybe not...)
__________________
Pat and Kat McSwain
  #7
Old 10-27-2010, 09:03 AM
smarquis's Avatar
Triple Turbo LBZ
Default
I pick my trucks well, "the year of the brain fart!" LOL.
So I take it that this list is no good to me anyway?
__________________
  #8
Old 10-27-2010, 09:59 AM
McRat's Avatar
Diesel Hotrodder
Default
2006 LLY should have mostly identical codes/procedures to 2006/2007 LBZ since all the sensors and computers are the same.
It is most likely an oversight on whoever manages that website that LBZ is not included with LLY (should be LLY/LBZ).
__________________
Pat and Kat McSwain
  #9
Old 11-15-2010, 08:41 PM
turfcat1 turfcat1 is offline
I AM Commercial Grade
Default Need help with trouble codes
Codes P0380 and P0540
Well, I just completed an injector replacement on my '02, and after a few tense moments of cranking, it roared to life. I've since driven it about 150 miles, and it's doing great. However, it threw two codes out (checked these at Autozone) related to the intake air heater. Out of the whole operation, the one thing I was uncertain about was reconnecting the glow plug controller. I couldn't remember with absolute certainty which wire went where. Anyway, I understand that, once the issues are addressed, the "check engine" light will go out. I did do a cursory check of the connections down at the glow plugs themselves, and found the left side front had a loose connection. Took care of that, but the light comes on and stays on.
Other than these two codes popping up, everything else is perfect - truck runs awesome. I'm still not sure about the connections up at the controller. I've looked throughout this forum board, and others, but I can't locate a diagram or photo that shows how the wires are connected. Can anyone give me specifics as to which wire goes where. A pic, or even some sort of drawing would really help a bunch.
Thanks!
  #10
Old 02-15-2012, 06:53 AM
weistie's Avatar
weistie weistie is offline
FNG
Default
great resource printed what i needed thanks a million !
__________________
05 silverado 2500hd 4x4 crewcab long bed alli 1000 stock replacement k &n filter , oversized 16 's and its sad i know but thats the only mods, i use truck to pull a trailer full of bread so i make money with her trying not to spend money on her
  #11
Old 02-15-2012, 07:26 AM
jkaps jkaps is offline
FNG
Default
great find, thanks
__________________
06 GMC cclb drw LBZ, transgo jr, pump rub mod, diamond eye downpipe, PPE deep trans pan, line-x, B&W turnover ball & 5th wheel adapter, pcv reroute, BD exhaust manifold, MBRP 5" SS downpipe back exhaust,EFI live by Idaho Rob w/dsp5 switch,EGR blocked,Air Dog II 165, PPE race valve,EDGE CTS insight monitor,MAG-HYTEC rear diff cover,bilstien 5100's,AFE stage 2 intake
02 Dodge qbsb 2500 6 spd cummins Smarty,egt/boost/fuelpressure gauges, fass pump, volant airbox, cipa mirrorrs,line-x,bilstien 5100's mag-hytech rear diff cover,adjustable boost elbow
84 Chevy K30 srw restored inside and out to much to list, occasional sled puller
82 Chevy K30 drw work truck/beater
  #12
Old 03-11-2013, 02:25 AM
Donny Boy Jr Donny Boy Jr is offline
FNG
Thumbs up Codes
Thanks this is great!!
  #13
Old 04-06-2013, 01:23 PM
IGS27639's Avatar
IGS27639 IGS27639 is offline
05 duramax
Default
Thanks
__________________
2005 Crew Cab / BDS 6" Lift / Edge Juice W/CTS / 5" MBRP Exhaust / 35" Goodyear Duratrac Tires
  #14
Old 10-08-2013, 12:37 PM
Summitsmoke403's Avatar
Summitsmoke403 Summitsmoke403 is offline
Default
Thanks!
Mines doin the same thing did you ever figure it out?
04 Lb7 cc/SB new guy to the forum
__________________
04 lb7 CC/SB dsp5 EFI live by Bob Olsen, big head waste gate actuator, air raid intake, air dog 100, high flow driver side exhaust manifold, 3" profab downpipe, 5" MBRP exhaust sac 45% over sticks, WCF 3" y bridge, ported intake horn, ati dampner, lbz cp3, cat filter head/filter.
piece by piece!
  #15
Old 10-27-2013, 04:25 PM
DirtyMax32's Avatar
DirtyMax32 DirtyMax32 is offline
Default
Same here. My 01 LB7 threw P0380 and the intake heater code and I replaced both glow plug relays but that didn't fix the engine light. So I unplugged the power going to the glowplugs since I live in Texas.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
