  #1
Old 04-26-2012, 05:45 PM
LeRoy LeRoy is offline
FNG
Default Tank Size Question
I wasn't sure where to post this question, so I'll throw it in here.
I just bought a new (to me) 2005 Chevy Silverado 2500 with the Duramax Diesel. When we took it on our first trip, I was very disapointed at how fast I ran out of fuel. I kept thinking, how could I be out of fuel already. I was under 1/4 tank, and and it took only about 17 gallons.
I later did a google to find out what size tank came on it, and everything I read showed 34 gallons for the diesel, 26 for the gas. So I thought that my gauges must be off, right?
Tonight I climbed under and inspected the tank. There is a sticker on it that says 26 gallons.
Would someone have swapped out the factory 34 for a 26? Why? Or was the 34 an addon option?
  #2
Old 04-26-2012, 05:50 PM
thneill's Avatar
thneill thneill is offline
Whered all my $ go
Default
I just bought an 08. I hear that it depends on the bed. Short bed gets the 26 gallon tank and the long bed gets the 34 gallon tank. My gauge reads empty after about 15 gallons. Gets annoying.
__________________
2008 GMC Sierra 2500HD 6.6L D/A 4X4 CCSB
sitting level, 18x9 XDs, Tuned by Rob
2003 Chevy 2500HD 6.6L DMAX RCLB 4WD ZF6
7" BDS, 20x9 -12 Helos
2001 Chevy 2500HD 6.6L D/A RCLB 2WD
45 over exergys, 42 over cp3, Tuned by Rob
2002 C5Z
droniest exhaust ever installed by previous owner
  #3
Old 04-26-2012, 06:01 PM
x MadMAX DIESEL's Avatar
x MadMAX DIESEL x MadMAX DIESEL is offline
<<<< No Horsepower
Default
You can rescale your gauge voltage with efilive to show it empty at a different level. Maybe your pick up broke off? Stock speaking though on 2006 and 07 forsure, the gauge shows 20 gallons and the empty light turns on with 6 gallons left.
__________________
Ben
LBZ Stock Charger
12.26@108.8
7.78@87.7
2.5 puller in the Mecca!!
Manual Mafia
Quote:
Originally Posted by BgBlDodge View Post
Al gore invented driving the turbo.
  #4
Old 04-26-2012, 06:05 PM
thneill's Avatar
Whered all my $ go
Default
Id definitely like to get it changed. Probably wont tune the truck for quite some time though. Gonna put some funds into the 02 first. Ill just have to live with it. Thanks for the info though.
__________________
2002 C5Z
  #5
Old 04-27-2012, 06:08 AM
MACKIN's Avatar
MACKIN MACKIN is offline
Smell My Finger...
Default
http://www.duramaxdiesels.com/forum/...ad.php?t=38545
__________________
I have nothing want nothing because what I have cost me to much to have.
01 Big Dually (Gone but not forgotten)
05 Fat-Boy (gets it done)
83 CJ7 (slug but cool)
07 Audi A4 ( I like German Girls they're HOT!!)
LIFES JOURNEY IS NOT TO ARRIVE IN HEAVEN SAFELY IN A WELL PRESERVED BODY,
BUT RATHER TO SKID IN SIDEWAYS,
TOTALLY WORN OUT, SHOUTING,HOLY SHIT WHAT A RIDE!
  #6
Old 04-27-2012, 06:48 AM
JustinD's Avatar
JustinD JustinD is offline
Plow Truck
Default
Mine always takes 20-22 gallons when the light comes on.
__________________
2001
II S366
12.65 @ 105 stock turbo
Thanks to:
Samson
Jeff Toman
Johnny
James Dow
James R
Jeremy and the guys @ WDP
  #7
Old 05-10-2012, 09:09 PM
FNG
Default
So I've run it a few times until the light comes on, and then driven it a bit further. Every time, it takes at most 19 gallons, usually 18.something. This just doesn't seem right that I can't use 7 gallons (27%) of my fuel tank.
I'm going to have the truck into the dealer for something else, I'm going to have them look at this. The truck is under after market warranty, so hopefully there is an issue that is covered.
I will keep you posted?
  #8
Old 05-13-2012, 08:33 PM
FNG
Default
It went into the shop on Friday and they had to replace the fuel level sensor. It was around $400 to replace, and covered by the extended warranty.
When I dropped it off at the shop it was on the line just above the red line. When I picked it up, it was on the line just over 1/4 tank.
I drove it around all weekend and finally the light came on. I drove another 5 or so miles, then got fuel. When filling the pump kicked off just under 23 gallons, and i was able to top it off adding another 1/2 a gallon.
Their fix got me back an additional 4+ gallons of my existing tank. I'm very happy that it was fixed and even happier that it was covered by the warranty and didn't cost me anything.
  #9
Old 01-26-2015, 07:16 PM
gkchevy gkchevy is offline
FNG
Default
Well I believe that I have the same problem. But it had not always been this way I don't believe. But I can be bone dry on the fuel Guage and I can only put in 21 gallons.
I know my sending unit has shown empty when the tank was full before. I would have to cycle the engine a few times or pull the battery cable and then it would read full. But that seemed to one day correct itself.
So do I need a new unit or do I need to reprogram?
  #10
Old 01-26-2015, 07:22 PM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is offline
<<<Future tuna killer
Default
All CCSB trucks have 26 gallon tanks untill 2011, then they went to 36...
Most read empty at 18 to 21 gallons, If yours is acting up you most likely got some water in your fuel at one point. I had mine gong to empty if the truck sat still for a few minutes or so for years, I pulled the sender and cleaned it with clr and it worked like new. It had rust and white gel on it from water contaimination...
__________________
2001 LB7 ECSB SL Built trans, batmo, lbz cp3, everything else, etc... Sold...
2006 LBZ CCSB SLT < My first, Superchips Flashpac... Sold...
2008 LMM CCSB SLT < Blue beast. way too much to list.... Sold...
2015 LML CCSB Denali < Lifted 20's/35's Deleted Airdog ETC. Sold...
2016 LML CCSB Denali < Lifted 22's/35's >I officially need help.
2010 1500 RCSB Denali clone <Lifted 22's/33's, 5.3, 6L80, TVS1900, Mayhem tuned, etc ...
2015 Corvette Stingray LT3 White on Black
  #11
Old 01-26-2015, 07:31 PM
zf>allison's Avatar
zf>allison zf>allison is offline
you never had your car.
Default
My gauge don't work at all so be thankful.
__________________
04.5 single cab lly zf6 barely not stock.(the jalopy)
05 single cab lly zf6
Arp studs, welded water pump, 100 overs, dual fuelers, valair 1000 hp triple disc, danville efi live, fass 150, custom single s400 kit,
serious weight reduction
28x10x16 Hoosier slicks on pyos
Down on 2 leaves, t bolts gone.
best
11.219 at 122.95 mph, 1.660 60 foot
dynoed 743 hp current raceweight unknown
Instagram-636zf6
  #12
Old 01-26-2015, 08:50 PM
dirtymax36 dirtymax36 is offline
2nd place is last
Default
My gauge on my 04 CCSB fuel low light comes on when i put 16 gallon in it. I run out of fuel very quickly according to my gauge and i know it has to have a 26 gallon or so tank on it because of the manual in the glovebox stating it does. Does anyone know the specifics on how to rescale the gauge with EFI? I will be doing this myself.
__________________
04.5 LLY CCSB Built Motor/trans. Some fast spinny things.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
