  #1
Old 03-12-2012, 10:48 PM
Bonestock's Avatar
Bonestock Bonestock is offline
Default Lmm Injector Removal????
Hello all I am removing the Injectors on my LMM and having a tough time with cylinders 1,3,5. I got the rest of them out but these injectors are stuck in the bores? Any suggestions I would greatly appreciate it. Thanks, Randy.
__________________
The LMM -Limitless Built Trans -Suncoast 1054 Converter - DHD Lockup Controller -Exergy Sportsman Cp3 - Airdog 165 -Stock Turbo - Stock Fuel -EFI DSP5 PPEI Tuning. *sold*
The LB7 -Limitless Built Trans 6 Speed Drum - Precison ML Converter - DHD Lockup Controller - Fass 150 - Stock Turbo - Stock Fuel - EFI DSP5 Tuning by me.
16 Denali......Stock for now.
  #2
Old 03-12-2012, 10:53 PM
paint94979's Avatar
paint94979 paint94979 is online now
Beer Nazi
Default
Quote:
pry bar under the hold down? try warming up the area around the injector?
__________________
LLY's are COOL
HUGE Thanks to Chris, Mike L., McRat Racing, Total Performance Diesel, PPE, Trent, Wicked Diesel, Mike, Henry of Creatures of the Night, Exergy Engineering and the rest of Team Salad<--My Tailgate's Always open for all of you!!
11.84 @ 115
Tailgate Crew Member #2
  #3
Old 03-12-2012, 10:56 PM
Bonestock's Avatar
Default
Ya, I had a pretty good size pry bar under the hold down. I am just worried I am about ready to break something. I usually do a pretty good job on something when I get western with it if you know what I mean. I thought about building some sort of slide hammer that would thread onto the injector threads and try to pop it out that way? Maybe I need to get a bigger pry bar and give it a bit more. I soaked it in liquid wrench a few minutes ago. I will let it soak overnight and hit it again tommorrow. Bummer I was gonna ship injectors off in the a.m.
__________________
  #4
Old 03-13-2012, 12:00 AM
gmduramax's Avatar
gmduramax gmduramax is online now
Shits broke
Default
You can't use liquid wrench cause the o ring will stop it from getting down in there. Use a pry bar under the hold down and behind the threads for the fuel line. If that dont work use a slide hammer with a cable wrapped around the hold down. If that doesn't work, get a tractor and put tension on the injector, remove the upper valve cover and pull the top of the injector out. Use a pipe wrench to twist the injector back and forth until it pops out.http://www.duramaxdiesels.com/forum/...ad.php?t=32128
__________________
2008 GMC duramax crew cab short bed 2500.
10.98@124mph
Thanks to Mike L, SoCal Diesel, and Abel Chevorlet.
Tailgate Crew Member #1
  #5
Old 03-13-2012, 05:55 AM
Bonestock's Avatar
Default
Thanks.
__________________
  #6
Old 03-13-2012, 12:28 PM
Bonestock's Avatar
Default
Gonna be going the farm tractor here pretty soon!
__________________
  #7
Old 03-14-2012, 11:35 AM
Bonestock's Avatar
Default
Well I got the injectors out & headed to Trent. I had to whale on the injector #3 and #5 with Snap On Injector puller that threads onto the high pressure tap. After 5 hours I got them out. They were carboned up real bad. I could not get the high pressure line off one of the injectors so I removed the Injector with the line still on the injector. I then put the injector in a vise and used a 17mm line wrench / crows foot with a 3/8 to 1/2 adapter and 1/2 breaker bar. It broke the threaded part that has metal tips that go into the casting and then appears to be pinned.
Is there any part to fix this or am I hosed and have to buy a new injector?
__________________
  #8
Old 03-14-2012, 06:54 PM
DIESELMAFIAPER.LB7's Avatar
DIESELMAFIAPER.LB7 DIESELMAFIAPER.LB7 is offline
<----twinz
Default
Id say new injector
__________________
2003 GMC CC/SB: billet 66/83mm compounds, dual pumps, exergy injectors, built trans (by me) tune 3 11.61 @ 119 !!
2012 mega cab 6.7: Tuned and deleted (reliable) sold! (should have kept it)
2016 CCSB custom sport lml ltz deleted with sotf tunes by me
  #9
Old 03-14-2012, 08:32 PM
Bonestock's Avatar
Default
Ya its a bummer I think that is what I will have to do. Called Industrial and DDP and they didnt sound like it was a serviceable part. I dont know why because it threads right out of the body but is pinned in? Anyhow hopefully all is good now. Thanks.
__________________
  #10
Old 03-14-2012, 08:40 PM
paint94979's Avatar
Beer Nazi
Default
call Exergy... they might be able to help you out. FYI II is not certified to work on Bosch components last I heard
__________________
LLY's are COOL
11.84 @ 115
  #11
Old 03-14-2012, 08:42 PM
Bonestock's Avatar
Default
Quote:
Thanks man will do!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
