  #1
Old 03-01-2012, 07:36 AM
WisconsinHick1's Avatar
WisconsinHick1 WisconsinHick1 is offline
Default Fuel Cooler
How important is the fuel cooler?
I am thinking of removing mine when I install my FASS. I understand it helps cool the fuel that is returning off the motor and of course cooler fuel is better for performance. However neither Ford or Dodge have one.
Am I missing something?
__________________
Green Bean Out
The Rag In
  #2
Old 03-01-2012, 08:05 AM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Ford now has one maybe two on their new truck. I think they are important.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #3
Old 03-01-2012, 08:11 AM
BHoward6.6's Avatar
BHoward6.6 BHoward6.6 is offline
West Coast
Default
I have seen my fuel temp hit 195*.
  #4
DMAXchris's Avatar
DMAXchris DMAXchris is offline
Here we go again
Default
I want to add another one somewhere.
__________________
06 Chevy LBZOlympic White Built Motor/Trans Bullseye s375 45% Injectors Stock CP3 Built and Tuned by Blackout Performance 11.76@115.12
08 BMW 528xi
Alpine White Brown Dakota Leather Premium/Cold/Smoker Pkg LED AEs MTec D1S 50% tint
2000 Buick Regal GS
Bright White Lowered Homemade CAI 4500K HIDs Supercharged Beater
  #5
Old 03-01-2012, 08:15 AM
Default
Wow 195˚ but you are also in a hotter climate then me.
Still kind of interesting that there is that much fuel being pushed back into the tank.
__________________
Green Bean Out
The Rag In
  #6
Old 03-01-2012, 08:24 AM
BHoward6.6's Avatar
West Coast
Default
In all fairness the 195* fuel temp was typically seen at low OAT's (50*80*). Mostly because I was pulling my 5th wheel from sea level to 4000'.
IIRC fuel temp's are around 140* while emty at highway speeds.
I would leave the fuel cooler.
  #7
Old 03-01-2012, 08:25 AM
super diesel's Avatar
super diesel super diesel is offline
<<<< Under Pressure
Default
When it's really COLD out side (sub zero), as I'm sure you see as well, I put a cover over mine to help the fuel warm up in the tank.
__________________
FOR REAL POWER: Remove the static wire from ovulation bearing and let her run!
McRat Racing, SoCal Diesel, Ridge Runner, Mike L. Special, PPE, Creatures of the Night Performance
Michael
OIL COOLING CLUB
CC LB7 4X4 Dually GMC with Fluidyne oil cooler
CC LLY 4X4 3500 SRW with oil cooling coming (stock with a few goodies)
Currently for street driving and towing GT4202 and Dual Fueler from PPE
Carrillo rods, Heads, balancing, cut pistons, Head studs, Injector clamps from Guy at SoCal
Tune by Tony at Ridge Runner (Clark Kent special)
Moded LBZ CP3s and special fuel system by Super Diesel
SC Trans w/snake oiler and cooler by Mike L.
Blowoff and Wastegate by Tial
Various machining touches, built and fabed by Super Diesel
Broke motor #2 becomes built motor #4
New motor and trans oil purifiers available (dual and single elements) and vital fluid cooling components. Start saving your truck today!
SUPER DIESEL 720-404-7553 Please leave message if no answer.
  #8
Old 03-01-2012, 08:48 AM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
I have a big tank blocking my fuel cooler, im sure I dont want to see my fuel temps in the 115* summers
__________________
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.72 @ 150.
06 Cummins cc/sb EFI by Hardway.
Tailgate Member #1 I prefer the backdoor
  #9
Old 03-01-2012, 09:21 AM
quentomania's Avatar
quentomania quentomania is offline
Gearhead
Default
Should be a more efficient burn with cool fuel. Big trucks used to have warm returns and they pulled a little better when you just fueled up imo. These new 550 cummins have fuel coolers too.
__________________
Scott's sdp twins with billet wheel s475
dsp 5 Robs tunes ATP and 30 over nozzles
airdog II 165
Mike L trans with ML-G converter
Turbo performance blankets
Shiny parts from Dan at PPE
Duramax Store Ultimate 3 front end kit
With Cognito supports, end links
Thanks to all above for great service and everything you guys do!
  #10
Old 03-01-2012, 09:50 AM
Mike L.'s Avatar
Default
Quote:
You are losing power at those temps. 75F is the optimum fuel temp according to Cummins. The problem is, it is difficult to to even get it to ambient temps in the summer or under a pulling a big load. Dual fuelers will also raise temps past 175F. When the temps get close to 200F and above, the ECM pulls power back.
There was a thread a few years ago at DP where the dealer installed a big tank and didn't have enough room for the cooler so they left it off. He was towed back a few days later with a fuel boiling issue under load. The dealer reinstalled cooler and solved the problem.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #11
Old 03-01-2012, 09:59 AM
05_LLY's Avatar
05_LLY 05_LLY is offline
Out-A-Time
Default
I have seen trucks with fuel temps in the 230s, running a truck low on fuel seems to increas temps especially when towing in warm weather!
__________________
Caleb
Ours~ 15 LTZ CC/DRW Tow Rig ,PPEI tuned
My DD~ 06 D/A Lt3, Grocery Getter~ WCFAB 475/stocker twins, 40's, FPE CP3, Blackout tuned and Trans, 11.92@118mph @ 7400Lbs
Her DD~ 17 Z71 Colorado 2.8 MiniMax
Hers~04.5 D/A CC/SB- 3.0LPSD puller "Girl's Night out"---2015 Power Pulling Productions 2.6 Champion, 2011&2012 USA East 2.6 diesel Champion, 2012 Diesel Motorsports (NADM) 2.6 Champion,
Blackout Performance Built and tuned with help from Diamond Pistons, XSpower, Wagler, WCFab
  #12
Old 03-01-2012, 10:03 AM
JD Dave's Avatar
JD Dave JD Dave is offline
In way over my head
Default
Most of the pulling trucks don't have a fuel cooler. Do you think it would be worth while running my return through my ice/water box then. I only have a 5 gallon fuel cell so I'm guessing yes.
__________________
Special thanks to: HSPDiesel.com, Wagler Competition and S&S Diesel.
  #13
Old 03-01-2012, 10:09 AM
Mike L.'s Avatar
Default
Quote:
The fuel in our trucks is mainly cooled by the fuel in the tank and not the cooler. The lower the fuel level in the tank, the hotter the fuel gets. I found this out with a infra red camera.
My old buddy LosLobos in Oregon tested this with his camera and follewd the fuel back to the tank. The camera showed Red ( hot ) to the cooler and Red out of the cooler and Gray ( cool ) when the return fuel hit the tank.
We then installed my fuel cooler and the fuel showed Red to the cooler and Gray when it left the cooler.
It was a very interesting study.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #14
Old 03-01-2012, 12:17 PM
Default
So you found that the stock cooler does nothing. However your cooler does the job.
One of the reasons I bring this up is my truck gets drove maybe 5000 miles a year and will be more on the lines of 3000 miles after I finish my motor build. I just looked at the FASS instructions and saw I needed to remove it to hook everything up so I figured maybe I'll just delete it.
__________________
Green Bean Out
The Rag In
  #15
Old 03-01-2012, 12:39 PM
Texas Chevy's Avatar
Texas Chevy Texas Chevy is offline
Default
since fuel temps effects power does it also effect mileage?
__________________
07 silverado classic. CCLB sold
2011 LML 2500hd CC/LB LTZ. H&S xrt pro. auto meter boost and pyro guage. Big thanks to Jake@Diesel Mafia
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
