  #1
Old 02-26-2012, 05:38 PM
mcrae08lmm's Avatar
mcrae08lmm mcrae08lmm is offline
FNG
Default installed quadzilla stock no dpf program keeps going into regen?
Just installed a downpipe back exhaust on my 08 lmm. Installed quadzilla stock no dpf program, and it seems to keep going into regen process at idle. Rpms go up and its has a weird noise that is unusual for about 5 to 7 seconds. Which from what I have been told is the indication of a regen. Truck runs awesome and sounds freakin sweet. But I deleted the Dpf to try and gain every mpg I can, and what seems to b a continuous regen
isn't helping. Lol. I'm new to this forum and this is my first diesel so any info would b greatly appreciated. Thanks
__________________
2008 GMC 2500 HD
6 in rough country lift, 35 in Nitto's w/ 20 x 12 moto metal, cognito uca's, rare parts tie rods, moog pitman and idler, super steer pivot assembly, rancho 9000 adj shocks, EFI live tuning by ATP trucks, Airdog 2 165, AFE Intake, Diamond Eye Exhaust, Edge insight cts guages, Egr blocker, Alligator tranny lines, 2 in rear spacers, NFAB nerf bars, Recon headlight, taillight and cab lights, 5000 k HID's, Switchback turn signals, Custom self made studded upper and lower grilles. Color Matched bumper
  #2
Old 02-26-2012, 06:26 PM
JD4440's Avatar
JD4440 JD4440 is offline
<< Lo-Carb Monster
Default
Sounds like the vane test cycle on an LBZ/LMM
__________________
Chris
EFILive(Tuned by JoshH),SC IV,PPE,TTS,Big Dipper,Ect.
O.S. 6128--508hp/12.26@107.4 so far.......Thanks Josh
Quote:
Originally Posted by Trentnell :
Politicians are the only people in the world who create problems and then campaign against them.
  #3
Old 02-26-2012, 06:38 PM
Houser04lly's Avatar
Houser04lly Houser04lly is offline
Default
you have to shut the regen cycle off I thought the dpf delete on the quadzilla would take care of that. even tho there is no dpf the sensors may still read dirty from soot through the pipe.. maybe im wrong but thats what figured..
__________________
04.5 LLY EFI ARP Studs Grade Cs Airdog 150 Race Valve EGR Gone RareParts Tie Rods Braces Solid Centerlink Caltracs Double Adjustable QA1s with Coilovers Front T Bars gone Single QA1s Rear PPE Stage 5 Trans BT Lockup Controller
Best 1/8 so Far 8.17 1.81 60 @ 83 mph
  #4
Old 02-26-2012, 06:54 PM
08txlmm's Avatar
08txlmm 08txlmm is offline
Gearhead
Default
Quote:
There shouldn't be any dpf related sensors in the exhaust. Usually the sensors are removed and any of the remaining electrical connectors are taped off to prevent getting any dirt in them.
To the OP are you sure the rpms are increasing? Or does the exhaust go from a hissing sound to more of a v-8 gas engine type sound? If this is the case it's just the vane position sensor and is normal. I'm pretty sure there are some gauges within the qzilla where you can see vane position, rpm, and maybe even regen cycle. This might give you a better idea of what's going on.
__________________
08 Chevy 2500HD LMM CCSB 4x4: 4" MBRP with a DiamondEye DP, S&B intake, All Season EGR Delete, PCV Reroute, Cognito uca's and Bilstein 5100s, Frontier replacement bumpers, B&W hide a hitch, Black KMC XD Spy's, Transgo jr, DSP-5 by IdahoRob, HID's, and a few other interior extras...ready for a built trans and a lift pump
  #5
Old 02-27-2012, 07:04 AM
mcrae08lmm's Avatar
FNG
Default
I did tape off the 2 connections and i taped off the flexible diff presure hoses and zip tied them back to the frame. The noise that occured now that its mentioned did sound like a gas type v8 sound and rpm prolly did stay the same. It was just really weird in the time that i have had the truck i have only heard that noise 1 other time, but in the couple hours after changing the exhaust and removing the dpf it happened 3 or 4 times. if it was the vanes from the turbo is there a reason it does this and y would it happen so frequently after i changed the exhaust?
__________________
2008 GMC 2500 HD
  #6
Old 02-27-2012, 07:10 AM
Dirtymaxx03's Avatar
Dirtymaxx03 Dirtymaxx03 is offline
Default
Sounds like the vanes sweeping. The truck does this everytime you turn it on. It's to self check the vane position sensor. The reason you never heard it before is because the stock exhaust does a great job muffling the sound.
__________________
Sean
2003 Lb7
Efi Live
The Rabbit-build in progress
1984 2wd SB c10
Quote:
Originally Posted by hondarider552 View Post
big balls if you measure in seconds of duration
  #7
Old 02-27-2012, 08:01 AM
mcrae08lmm's Avatar
FNG
Default
ahhh that would make perfect sense.Everytime it happened it was within a short amount of time of a startup. Thanks for the help guys much appreciated
__________________
2008 GMC 2500 HD
  #8
Old 02-27-2012, 05:49 PM
mcrae08lmm's Avatar
FNG
Default
Ok don't mean to beat the dog here guys but today when I got home I went to the store. The noise before mentioned happened upon start up, twice at the first stop light and twice when I got to the store letting it idle for a min. It happened 5 times within about 10th min. Is this still normal? I completely understand a vane test upon start up but that many times seems excessive.
__________________
2008 GMC 2500 HD
  #9
Old 02-27-2012, 06:57 PM
08txlmm's Avatar
Gearhead
Default
I'm not sure that mine does it that often but I am so used to it I rarely notice it any more. I would say its probably normal especially if the truck is driving fine. You might double check and make sure you loaded the non-dpf tunes for qzilla and not the dpf tunes.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
