  #1
Old 02-17-2012, 06:21 PM
Houser04lly's Avatar
Houser04lly Houser04lly is offline
Default 08 LMM EGR Delete?
I have a friend I am trying to help out so all replies would be greatly appreciated. He has an 08 lmm and he wants to do EGR delete. He is using Quadzilla Stealth 2 For his DPF delete but they didnt have a update for EGR delete to clear the codes.. Any suggestions I have been researching alot and cant seem to get any further.. Thank you for any help.
__________________
04.5 LLY EFI ARP Studs Grade Cs Airdog 150 Race Valve EGR Gone RareParts Tie Rods Braces Solid Centerlink Caltracs Double Adjustable QA1s with Coilovers Front T Bars gone Single QA1s Rear PPE Stage 5 Trans BT Lockup Controller
Best 1/8 so Far 8.17 1.81 60 @ 83 mph
  #2
Old 02-17-2012, 06:34 PM
Mpsoldier's Avatar
Mpsoldier Mpsoldier is offline
That just happened!
Default
charge him 100 bucks for a efi license
  #3
Old 02-17-2012, 06:43 PM
Default
there are 120 now lol.. I wouldnt charge him but I did offer to help with efi ..ill do whatever I can to give a hand.
__________________
  #4
Old 02-17-2012, 06:59 PM
Default
Anyone?
__________________
  #5
Old 02-17-2012, 07:03 PM
Mpsoldier's Avatar
That just happened!
Default
shit everything going up total forgot until i seen the 4$ a gallon fuel again
  #6
Old 02-17-2012, 07:05 PM
Default
ya no kidding rediculous ..
__________________
  #7
Old 02-17-2012, 11:53 PM
08txlmm's Avatar
08txlmm 08txlmm is offline
Gearhead
Default
Are you sure the stealth 2 doesn't delete the egr codes? I thought it did. I know it tries to command the egr closed so I thought it also deleted any codes.
http://www.quadzillapower.com/produc...SB-Updates-LMM
After looking at this is looks like it is egr delete capable for the 09-10 but not the 07.5-08? Not sure why it would be available on one but not the other so you might try contacting them to make sure that's correct. As far as EFILive is concerned the 08-10 operating systems are the same so the 09-10 update might work on the 08 with the stealth.
__________________
08 Chevy 2500HD LMM CCSB 4x4: 4" MBRP with a DiamondEye DP, S&B intake, All Season EGR Delete, PCV Reroute, Cognito uca's and Bilstein 5100s, Frontier replacement bumpers, B&W hide a hitch, Black KMC XD Spy's, Transgo jr, DSP-5 by IdahoRob, HID's, and a few other interior extras...ready for a built trans and a lift pump
  #8
Old 02-18-2012, 08:15 AM
Default
I will check that out it wouldnt hurt to just block the egr though even though it might command the egr closed it still may pop open... thanks for the input
__________________
  #9
Old 02-18-2012, 05:30 PM
08txlmm's Avatar
Gearhead
Default
When I first bought my truck it had the stealth 2 and didn't have a blocker plate in and I could hear and feel it pop the egr open every now and then. Putting a blocker plate in definitely helped the drivability and kept it from pushing open but I still didn't like how laggy the truck felt that's why I eventually went to EFILive.
__________________
  #10
Old 02-18-2012, 06:33 PM
Default
so the stealth 2 does disable the egr? Because you have an 08 ..
__________________
  #11
Old 02-18-2012, 07:43 PM
mcrae08lmm's Avatar
mcrae08lmm mcrae08lmm is offline
FNG
Default
Thanks for the help Brock gonna call quadzilla on monday.
  #12
Old 02-18-2012, 07:49 PM
08txlmm's Avatar
Gearhead
Default
The most I ever had done when I had the stealth 2 was the egr blocked and dpf deleted but I never had any codes for either. I completely deleted the egr after I got EFILive.
One thing to try is to unplug any connectors going to the egr and see if it throws any codes...if it doesn't an egr delete shouldnt cause any problems since it is essentially the same thing(as far as electronics are concerned anyways). It should throw codes for the grid heater if you delete it with the egr delete though since the stealth doesn't delete those codes.
__________________
  #13
Old 02-18-2012, 08:18 PM
mcrae08lmm's Avatar
FNG
Default
I will def give that a try I heard its 50/50 of it will throw a code or not. Only had this truck a couple months . My first diesel, gift a lot to learn. Thanks for the help
__________________
2008 GMC 2500 HD
6 in rough country lift, 35 in Nitto's w/ 20 x 12 moto metal, cognito uca's, rare parts tie rods, moog pitman and idler, super steer pivot assembly, rancho 9000 adj shocks, EFI live tuning by ATP trucks, Airdog 2 165, AFE Intake, Diamond Eye Exhaust, Edge insight cts guages, Egr blocker, Alligator tranny lines, 2 in rear spacers, NFAB nerf bars, Recon headlight, taillight and cab lights, 5000 k HID's, Switchback turn signals, Custom self made studded upper and lower grilles. Color Matched bumper
  #14
Old 02-18-2012, 08:54 PM
08txlmm's Avatar
Gearhead
Default
Mine is my first diesel also. I don't know much compared to most of the guys on this site but everything I learned, I learned from here. Stick around here for awhile and you'll learn plenty.
__________________
  #15
Old 02-20-2012, 07:04 AM
Default
No problem glad I could be somewhat of a help.. hope it all works out
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
