  #1
Old 01-02-2012, 06:50 PM
bullfrogjohnson's Avatar
bullfrogjohnson bullfrogjohnson is offline
Big Girl!
Default LB7 Tool No Mechanic Can Live Without
If you have owned and LB7 and do your own work, you have seen this picture before. One of my biggest LB7 fears is fuel in the crankcase. Everytime I have pulled injectors and return lines, I worry about leaks from the banjo seals. Either that, or I have seen trucks that had slow fuel dilution over time, and I wanted to figure out whether it was a leaking return or cracked injector body. I stumbled across a gm spec for the LB7 fuel return system. GM says that the fuel return system under the valve cover should 15inHG of vacuum, so I came up with this rig
It consists of a Mighty Vac hand held vacuum/pressure gauge and the clear tube it comes with, the end of an old lb7 fuel return line, fuel return line bolt and banjo washer.
Install the fitting on the fuel return outlet of the cylinder head. The passenger side port is on the inside front of the head. The drivers side port is on the inside back of the head.
Passenger side
Drivers side
Once you have finished you fuel system repair, you can check the return line system by pulling 15inHG vacuum and watching for 30 seconds. If one didn't seal off, it will show its ugly face. There is no more putting the whole motor back together and crossing your fingers that everything sealed up.
If you have one that does not seal up, you can pressurize the return system to no more than 15psi. Squirt some oil around each return bolt banjo seal, and you will see the air bubbles coming front the leaking seal.
__________________
Travis
03 CCSB lb7
06 2500hd ECLB 6.0 gasser
2010 Straight Diesel 2.8 Points Champion
special thanks:
B&B Pulling and Greene's Diesel Performance, Fully Spooled Motorsports, Johnboy, Simon, Ed, ProFab Performance, Hamilton Cams, Extreme Prejudice Racing, Ridge Runner Diesel
  #2
Old 01-02-2012, 06:53 PM
rgullett83's Avatar
rgullett83 rgullett83 is offline
Default
very nice
__________________
Riley
Mine: 01 CCSB Siverado frame off restored with various parts from 01-06 built lly motor, built 03 trans, 2xcp3, 100% exergys, billet s366 and much more that I wont fill this space with...
Hers: 07.5 CCSB GMC Sierra SLT LMM, XD Spys, Tuned and deleted
  #3
Old 01-02-2012, 07:06 PM
duratothemax's Avatar
duratothemax duratothemax is offline
<--- slippery roads
Default
Cool! Great idea, thanks Travis! Every time I do an LB7 injector job, Im always paranoid that im going to spend hours getting it all back together, only to find that I have a leaking return line. Knock on wood Ive never had a problem, but I think Ill be making one of these setups ASAP.
__________________
2012 Denali - R&D testbed for upcoming new products.....
2005 Silverado LT - Blown up/broken too many engines and parts to care about making it fast anymore, so its back to mostly stock - The best names in the industry for parts/advice/help...MikeL.Guy-SoCal.Rob-ATP.Evan-Limitless.McRat.BigDipper.Bobo.Tony-RRDP.Fingers.Eric-MA.EFILive...
BT DieselWorks, LLC - EFILive tuning - Duramax/Allison/gasser STANDALONE HARNESSES - Allison lockup controllers - Allison tapshift kits - Digital DSP-5 switches - full assortment of great electronic improvements and gadgets for your GM truck/SUV
All products available for sale through our online store at www.btdieselworks.com
Be sure to "like" us on Facebook at www.facebook.com/BTDWorks
Be sure to "follow" us on Instagram @btdieselworks
  #4
Old 01-02-2012, 07:12 PM
95 z71's Avatar
95 z71 95 z71 is offline
SUDDEN IMPACT
Default
That's awesome Travis!
Thanks
__________________
2001 chev ec/sb 4x4. Built motor and trans.
Danville Performance Tuned
  #5
Old 01-02-2012, 07:15 PM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
Nice Travis. Good job! I prefer to not worry about it, though I can see how it might worry you LB7 guys
  #6
Evan@LimitlessDiesel's Avatar
Evan@LimitlessDiesel Evan@LimitlessDiesel is offline
yerp
Default
Great idea, I know I will be making one up.
__________________
Limitless Diesel Performance
413-770-3585
  #7
Old 01-02-2012, 07:35 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Way to go Travis! Nice work!
__________________
Tom
"BBT" 2003 GMC CC/SB 4x4
12.14@111.15
"Flyin' Brick" 1999 Chevy 1500 RC/SB 2wd -- in progress
2014 Chevy Cruze Diesel -- the DD
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
From mufflerguy on yb,
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!"
  #8
Old 01-02-2012, 08:25 PM
cafryer's Avatar
cafryer cafryer is offline
Default
sweet
__________________
Chavis, 2001 rc/lb Lots of air, Lots of fuel, Lots of spray.
2003 rc/lb zf6 South bend dual disk 64/75 compounds 30% injectors
  #9
Old 01-02-2012, 08:30 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
Thats sweet!!! Im sure as hell gunna make one. Thanks travis!
__________________
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #10
Old 01-10-2012, 09:08 PM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
Travis
Great post! We did this last year on Abby trying to rule shit out and it does work great
We actually used a fitting I think it 10x 1.25 to connect the head to the pump....... It's been a while on the fitting though so don't take my word on it
__________________
07 RC/LB 2wd
A/D lift pump,Tunes from Josh H, BD Manifold and custom up pipes, P&I supports, PPE tie rod sleeves
05 CC/LB
EFI ,A/D lift pump,Cognito 7"lift /P&I supports / Banks air and exaust /ARP head studs/ Mike L stage 4 trans / EPR twins. SOLD
Abby 01 RC/LB 10.28@144mph
Arias pistons/ Howards rods / S475 & PBK twin turbos from EPR/PPE 2 CP3 / SoCal stg 2 heads & cam / 100 over sticks /Socal flexplate & dampner & girdle /DPR oil pump / 47RE /BD intercooler / Ted at MPL / Turbo blankets from Levi FOR SALE
  #11
Old 01-10-2012, 09:10 PM
jmaz268's Avatar
jmaz268 jmaz268 is offline
Lead from the Front
Default
Holy cow that is ingenius!!! Wish this would have been here awhile ago before I put my valve covers back on lol
__________________
John
http://www.duramaxdiesels.com/forum/signaturepics/sigpic5837_2.gif
  #12
Old 01-11-2012, 06:37 PM
1chevy02's Avatar
1chevy02 1chevy02 is offline
Default
Nice !
__________________
02 Chevy loaded LT package
4x4 ccsb
Efi live
305/65/17 Procomp Extreme AT on dodge wheels lbz cp3 dsp5
Suncoast Gmax 5 and Precision Converter installed by me! Thanks George at Suncoast!
high idle, Stewart Warner guages, PPE boost increasing valve, full Cognito kit, various other mods, ported and polished turbo intake elbow
FASS 150, MBRP downpipe, Diamond Eye Exhaust.
  #13
Old 01-22-2012, 11:06 PM
durallymax's Avatar
durallymax durallymax is offline
Default
awesome , wish i wouldve saw this a little while ago, just finished a HG job, no leaks, but im always worried. Ive had one leak, and it ruins your day.
Making one tomorrow have to do a set on tuesday. A+ great idea. Thanks.
__________________
Wife:2010 Jetta TDI "Cup Edition" Thunderbunny. Stg 2 Malone, Rawtek Straightpipe
Me:2000 Jetta TDI/5spd VNT-17, DXD S2 Clutch
Sis:2006 Jetta TDI/DSG
Puller:2003 LB7 GMC
Toy:1973 Kenworth W923
Farm:02,11,13 Duramax/Allisons
  #14
Old 08-03-2012, 11:33 PM
2500HeavyDuty's Avatar
2500HeavyDuty 2500HeavyDuty is offline
Book 'em, Danno!
Default
want
__________________
theres a new sheriff in town
Team Borrowed Time Member #17
Danny@dieselbombers.com
  #15
Old 08-04-2012, 08:39 AM
02ilduramax's Avatar
02ilduramax 02ilduramax is offline
Default
nice
__________________
build it til it breaks
2002 lb7 cc/sb afe stage 2 intake, MBRP 5in exhaust, airdog-165, efi live tuned by dans diesel performance, tie rod sleeves, stage 4 trans by mike l
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
