  #1
Old 12-26-2011, 10:37 AM
RichLMM's Avatar
RichLMM RichLMM is offline
Default leaky fuel rail fitting
I've had a PPE dual fueler kit on my truck for awhile now and the other day at the grocery store i noticed a fuel odor coming from the truck i went in came back out and saw a small puddle under the truck got home and searched for awhile and figured it was coming from the drivers side fuel rail pinpointed it to the fitting at the end of the rail for the dual fueler took the line off to try and tighten the fitting its as tight as i can get it put the line back on ran the truck and still leaking its driving me insane has anyone else had this issue or have a solution for me? thanks
__________________
2001 2.6 truck the other woman
2013-2014 shootout productions 2.6 points champ
thanks to caleb baker@blackout performance
  #2
Old 12-26-2011, 01:17 PM
RichLMM's Avatar
Default
just replaced the oring on the fitting its still leaking this is irritating not being able to drive my truck i have no idea why it would start leaking after 9 months of being on there
__________________
  #3
Old 12-26-2011, 08:13 PM
RichLMM's Avatar
Default
no one? i was hoping dan would see this and chime in
__________________
  #4
Old 12-26-2011, 08:21 PM
JD Dave's Avatar
JD Dave JD Dave is offline
In way over my head
Default
Is it coming from the adapter or the line fitting? I had to tighten then heck out of my adapter to get it not to leak. Also the oring wasn't a common size, your sure it was the right one? I put a little fatter one in and mine leaked. why not just take the dual fuelers off since you won't be pulling with that truck anymore.
__________________
Special thanks to: HSPDiesel.com, Wagler Competition and S&S Diesel.
  #5
Old 12-27-2011, 05:21 AM
RichLMM's Avatar
Default
Quote:
i'm gonna be taking them off but its so damn cold out right now and i dont have a garage to work on it in my hands go numb after a few minutes so i'm just gonna remove it all when we have warmer weather...i'll go to the dealer and get the exact oring for the FPRV that way there i'm not fishing around looking for one
__________________
  #6
Old 12-31-2011, 03:41 PM
xtremebikr04's Avatar
xtremebikr04 xtremebikr04 is offline
Default
If I remember correctly when i put the dual cp3 on my lbz you dont use an oring on the adapter fitting on the back of the driverside fuel rail.
__________________
2006 2500HD ccsb 4WD LBZ
  #7
Old 12-31-2011, 04:12 PM
Harbin_22's Avatar
Harbin_22 Harbin_22 is offline
Turning it back up!
Default
Let me know when they go up for sale
__________________
10' CCSB
Carrillos, Fingers 16.5:1 Cast Pistons, 3388AF Cam, PPE Dual CP3's, Exergy 200% inj, Danvile Billet 72R, HSP tripples/2-SXE369's, Limitless Diesel All Billet Comp Trans with LD TC, DHD lock up, Air Dog, Banks, RDL, CalTracs, QA1, M/A, Isspro, Novakanes/420's, 30x14 cheaters
Tuning from Mark@Danville
1,101HP/1727ftlbs
6.56@111 1/8
10.12@138 1/4
  #8
Old 12-31-2011, 05:16 PM
RichLMM's Avatar
Default
Quote:
yea i was told that and for 9 months it didn't leak...i guess trying th oring on it might help?
__________________
  #9
Old 12-31-2011, 05:30 PM
LBZrcks's Avatar
LBZrcks LBZrcks is offline
Default
X2
__________________
17' Denali HD CCSB Z71 Stock
Previous Dmax's
06' Chevy 2500HD CCSB 4x4, EFI Live, PPE GT40/GTX45 Twins, Socal 60s, Mike L. Trans
08' Sierra LMM CCLB Z71, Mike L. Trans, EFI Live, McRat Racing Tune 12.97@102.73
06' Sierra LBZ RCLB 4X4, Mike L. Trans, EFI Live, McRat Racing Tune 12.25@111.30
06' Chevy LBZ CST 9-11 Candy Red and Chrome
04' Chevy LB7 FabTech 8" Suncoast III w/TTS Converter
  #10
Old 12-31-2011, 07:02 PM
Dan@PPE's Avatar
Dan@PPE Dan@PPE is offline
Diesel Enthusiast
Default
Quote:
Originally Posted by LBZrcks View Post
X2
This is correct! Its not needed on the fitting that goes into the rail.
I am working on this via PM's with the OP.
__________________
2500HD CC/SB LB7 2 Wheel drive 950+ RWHP
11.17@126 in the 1/4 with a 7.2x@100 in the 1/8th.
NEW BEST in the 1/8th 6.95@102, 10's Here I come!!
2500HD CC/LB LB7 4X4, Towpig
2500HD RC/LB 4X4.............. 9 seconds of fury!!!
Pushing the D to the MAX........
  #11
Old 12-31-2011, 08:01 PM
D-MAX Mafia's Avatar
D-MAX Mafia D-MAX Mafia is offline
Hood down, smoke up!
Default
Dads truck leaks right out of the top of the drivers side rail @ the pressure relief port. Had to install a catch can to keep from dumping diesel everywhere. It has a PPE Dual Fueler also.
On the Droid X
__________________
Ben
2007 Classic LBZ CCSB LT3 4x4 "Nightmare"
Low and clean on factory LML 20's, CF wrapped hood and roof, PPE: GT4094R, V Trans, Manifolds/Up Pipes, Dual CP3, Lift Pump & Intercooler, DSP5 by Mark@Danville
@currey_racing on IG
  #12
Old 12-31-2011, 09:37 PM
Dan@PPE's Avatar
Diesel Enthusiast
Default
If its leaking out of the port then the issue is either..... The fitting is not tight enough, the seat on the fitting is damaged or the inside of the rail is damaged. You should NOT have ANY leaks with our kits....
__________________
  #13
Old 01-01-2012, 08:31 AM
RichLMM's Avatar
Default
i didn't for 9 months lol now its driving me nuts!
__________________
  #14
Old 01-03-2012, 12:30 PM
Default
Quote:
This is on the black truck. I think it has 8000 miles on it. It started leaking a while back. I hadnt touched it since it left the shop. Tore everything down and all was good and tight, reinstalled, same problem.
On the Droid X
__________________
Ben
  #15
Old 01-03-2012, 01:38 PM
Dan@PPE's Avatar
Diesel Enthusiast
Default
Ben,
Call me!
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
