  #1
Old 12-15-2011, 09:10 AM
LarryJewell's Avatar
LarryJewell LarryJewell is offline
Back with his honey :)
Default Symptoms of water in fuel ?????
Idles fine, drives fine until a little fuel is given, cuts out in cruise, fuel pressure gauge bounces, rail pressure gauge is erratic under acceleration, and it appears there may be water droplets when I drained the fass water seperator. What to do?
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #2
Old 12-15-2011, 10:10 AM
wrcknkrw's Avatar
wrcknkrw wrcknkrw is offline
Default
When mine had that issue with mine sometimes it ran great other times it would sputter and buck. All power would drop and she would smoke pretty bad, kind of a greyish white smoke. A few seconds later it would clear up run fine and then start again.
__________________
04 LLY sc lb 4x4 twins,trans,efi live,fass 150,edge insight,5" strait pipe
  #3
Old 12-15-2011, 10:16 AM
Default
how did you fix it, Ive dumped in some sea foam and will be changing the filter pretty soon
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #4
Old 12-15-2011, 11:14 AM
paint94979's Avatar
paint94979 paint94979 is offline
Beer Nazi
Default
Drain your tank, change all filters, run an additive that claims to dispense water, and for me I ran a piss load of 2 stroke oil a quart to 5 gallons of fuel to lube my injectors
__________________
LLY's are COOL
HUGE Thanks to Chris, Mike L., McRat Racing, Total Performance Diesel, PPE, Trent, Wicked Diesel, Mike, Henry of Creatures of the Night, Exergy Engineering and the rest of Team Salad<--My Tailgate's Always open for all of you!!
11.84 @ 115
Tailgate Crew Member #2
  #5
Old 12-15-2011, 07:04 PM
White Duramax's Avatar
White Duramax White Duramax is offline
Default
Water in the fuel will kill LLY injectors in quick order. Not just a few drops in the filter. I had one that I had to put 6 new injectors because of water.
__________________
06 CC/SB 4x4 LBZ/Allison
  #6
Old 12-16-2011, 09:13 AM
wrcknkrw's Avatar
Default
Quote:
Not necessarily true. My truck had quite a bit of water in the transfer tank that got mixed throughout. I had to drive it for a while to get to the next city so i could drain it. After draining both tanks and changing filters it still had water in the lines. Roughly 20-25 minutes of driving finally flushed it. 40k miles later on the same stock injectors they still have great balance rates.
__________________
  #7
Old 12-16-2011, 02:09 PM
Default
so far my balance rates are fine
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #8
Old 12-16-2011, 02:17 PM
Relentlesscummins Relentlesscummins is offline
Unhappy
Mine as same symptoms. Did urs toss any codes? Mine has no codes which leads me to believe its the fuel
  #9
Old 12-17-2011, 09:26 PM
Default
Quote:
Wish I could say that for my buddies truck. First injector started acting up within 20 miles of filling up. They next 2 right after the first was replaced and the last 3 shortly after. 3-4 filter changes also and ended up dropping the tank and cleaning it out.
__________________
  #10
Old 12-19-2011, 02:55 PM
Default
2 pints of Sea Foam, 1 pint of Diesel Kleen (Grey bottle) and a quart of 2 Stroke (walmart brand), probably drained 3 or 4 gallons fuel out of Fass water seperator. Down to 1/4 tank of fuel now and seems to have cleared up, balance rates never did get bad. New Fass filter going on later this week, Been driving around on a 10 micron Fass filter since I deleted the factory filter head assembly, going back with a 3 micron.
Never got a code, never smoked, just ran bad, did have an instance where it limited to 2000 rpms. It always started right up too.
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #11
Old 03-09-2015, 10:48 PM
kodywillkomm kodywillkomm is offline
FNG
Default
Im not sure if I had bad fuel or water in the fuel I have a 2005 duramax I did the cat adapter on it when I did my head gaskets and y bridge but I went to Missouri to pick up a car for a buddy of mine and we made it down there no problems and topped off truck which was at half and drove aways stopped for food and like 20 miles after the food truck threw 2 codes one I don't remember and one was for Injector 3... I think the first one had something to do with Injector control mod... I would clear the codes with the truck off and once I got above 30 would do the same it misfired bad soo I limped it to a gas station when 6.4 codes were cleared called a few ppl and they thought I had water in fuel I threw some liquid heat in it let it idle for like a hr and she was good and I drove it home the 4 hrs left but idk if that was for sure the problem
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
